11-24-2008, 07:32 PM | #1 |
Rep 24
When do you actually use 6th gear?
I ve noticed that unless i'm doing 80 + mph I not only lose power using 6th gear but the gas mileage drops. Wondering if anyone knows when BMW suggests 6th gear. Almost a waste of time so far. rare occasions that I can actually drive anywhere faster than 80.
.........curious |
11-24-2008, 07:37 PM | #2 |
Rep 1,254
mmmmm interesting, i use it on back roads (40+ speeds) and have noticed i get better gas mileage. Def loss of power but im not looking for power, as much as gas savings.
11-24-2008, 08:00 PM | #4 |
Rep 884
Drives: 2007 BMW 335i
I typically use 6th when cruising on the highway (which I don't do all that often). You definitely lose power, and I can't comment on gas mileage. I would assume that you would get better mpg unless you going up hills or something that would be better suited for using lower gears. But our 128i sees mostly city driving.
Maybe I will do a little test when we drive to NC around Christmas. That should give some extended highway time. I figure to use the electronic mpg and do about 30 min in 5th and 30 min in 6th and see which is better... hopefully with similar flatness of the terrain...
Current: 2007 335i sedan
Alpine White | Sports | Premium | Cold | Comfort Access FORMERLY: 128i coupe Alpine White | Sports Package | Black Leather |
11-24-2008, 08:00 PM | #5 |
Rep 1,254
Yea I understood what you stated. I seem to find the opposite when it comes to the more gas use.
Being on back roads i dont see more than 50 maybe 55 MPH.
11-24-2008, 08:07 PM | #6 |
Dangerous Curves
98
Rep 1,148
Drives: better than the boys ;)
I drive on the highway 80 miles a day 5 days a week and always use 6th.. my current gas mileage is 24.2.... Not all that bad? oh, I also have a JB3...
11-24-2008, 08:49 PM | #7 |
Rep 1,027
Anytime you are thinking about going to 5th...just go to sixth (unless you are in third and thinking about skip shifting to 5th)
torque...it does a body good
Just like Indiana...I love my whip
11-24-2008, 10:26 PM | #8 |
Rep 884
You may have missed the fact that he is a 128i owner. So 6th gear is rather weak compared to the 135i. 5th gear is still reasonably peppy on the 128i at highway speeds.
11-24-2008, 10:27 PM | #9 |
Rep 2,474
I never use 5th, to each his own though!
AW 135i w/ blackette, performance short shift kit, BMW alarm, Performance rotors, APEX ARC-8 wheels, Direzza Star Spec 235/275, Dinan stage 3 suspension, M3 wishbones/tension rods/front sway/rear subframe bushings and thats all folks! |
11-25-2008, 08:30 AM | #11 |
winter mode
62
Rep 2,057
Drives: 08 135i, 88 M3
5th gear...so last season
88 M3: BMWCCA J Sport
08 135: because streetcar |
11-25-2008, 08:37 AM | #12 |
Rep 790
I too often skip 5th and jump into 6th as soon as I hit the highway. Still enough power to overtake, only gear down for quick maneuvers...say, around a rock-throwing semi.
11-25-2008, 12:06 PM | #14 |
Rep 2,474
JuiceBox 3, it is a tune, make car go fast
11-25-2008, 12:24 PM | #16 |
Santa Fe Concorso
104
Rep 2,984
Interesting, less power understood. Do you have any sources to validate less milage claim for the 128i, robert?
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
11-25-2008, 06:14 PM | #17 |
Rep 628
I don't see why you would use more gas in 6th. I use 6th all the time even when I'm not the highway. Anytime I don't need the power and I'm going fast enough that the engine will bog down, I'll shift to 6th to save gas.
Waiting on a 2015 M235
11-25-2008, 06:42 PM | #18 |
Rep 24
Try the momentary mpg on the dash
No the only specifics I have is momentary mpg readout on the dash. I've just noticed that unless I'm doing over 80 the momentary mpg are higher in 5th when the rpms are closer to 3000. it seems like i'm getting better milege and more power, both of which I;m completely happy with. I don't often get to go above 80. haven't really had it out yet , only 2 months old.
My real question is has anyone else noticed this. If not give a shot when you can (if you like) It seems like the car runs more efficiently at a higher rpm. next time your in traffic at say 65-70 mph in 6th downshift to 5th and see where those momentary numbers fall. i don't even have a clue how accurate those number are, but i can read them. I was surprised, pleasantly i might add .... still curious
Cheers
Bob |
