12-04-2008, 11:35 PM | #1 |
Rep 128
DIY: Install the dash top storage bin
I decided I wanted to install the dash top storage compartment that’s available outside of North America. A quick check of real-oem showed there is a retrofit kit available
Step 1 I ordered the storage compartment retrofit kit Part # 51450428424 from Tischer BMW, and it took 3 weeks to come from Germany and cost $85. It comes with a cutting template, fasteners, a wiring harness and the storage bin. It didn't come with the install instructions, but Jason at Tischer emailed them to me. These instructions are basically useless as most of the diagrams are missing or incorrect. Step 2 Cut out and align the cutting template and stick it to the dash. I used a marker to mark where to cut, than removed the template. Step 3 Now it’s time to cut a big hole in your dash. The install instructions say to use a vibratory saw for this but I don’t now where you would find one of these. I ended up using a rotary tool with a flex shaft and a rotozip bit. It mostly just melted through the plastic, but it worked fairly well. Step 4 Remove the center vent using a plastic trim tool at 4 points, where the indentations are on the dash panel. Step 5 Install the supplied metal clips in the mounting points in the dash Step 6 Connect the wire on the storage bin to the unused connector clipped to the steel tube in the dash. This is for the light in the storage compartment The Kit also comes with a wiring harness that is meant to tie into the glovebox light wiring. DO NOT USE THIS. The glove box light always has power so if you use this, the storage compartment light will always been on. The unused plug already in the dash is tied to the interior lights and is only powered when the headlights are on. Step 7 Remove the rubber matt from inside the storage compartment. Then install the compartment into the dash. Step 8 Install the 4 torx screws that secure the storage compartment to the dash Step 9 Reinstall the rubber matt, then reinstall the center vent Step 10 Vacuum up all the plastic shavings that are now all over your interior. And that’s it, you are done
[SIGPIC][/SIGPIC] |
12-04-2008, 11:49 PM | #3 |
Rep 128
I was thinking about using it to mount a scanguage or a portable GPS like in this thread:
http://www.1addicts.com/forums/showthread.php?t=19233 Jay
[SIGPIC][/SIGPIC] |
12-05-2008, 12:59 AM | #4 |
Ronnie
15
Rep 556
Holy Crap !! I can not see myself taking any electrically powered sawing device to the center of my dashboard ... you're a very brave man, well done !!
"Lucy" 128i / Sedona Red / Coral Red / Premium Package / Premium Sound |
12-05-2008, 07:46 AM | #5 |
Most interesting Roadster
70
Rep 2,224
Drives: '01 Z3.0 Roady;'10 C300 Sport
Nice job dude, you got big cajones to cut into your dashboard like that! I had a box like that on my X3, kept my sunglasses in there. You'll find a use for it I'm sure!
I can't complain, but sometimes I still do........Life's been good to me so far.
- Joe Walsh |
12-05-2008, 07:47 AM | #6 |
1 Love
Rep 255
Damn... that's a huge hole in the dash, and then a large open cover to just have a GPS up there. I put my Garmin in the ash tray above the shifter. It fits there perfectly and doesn't move when you wrap the cord just so.
But hey, whatever floats your boat... |
12-05-2008, 08:39 AM | #7 |
Rep 1,262
Alright, I cut the hole in my dash, but now I have this extra flippy thing with LCD sitting on my garage floor... Do I just throw it away?
J/K - nice work. Very clean install!
12-05-2008, 09:09 AM | #8 | |
Ronnie
15
Rep 556
With some glue, cable ties, and effort, you'll be able to mount the LCD thingy in the storage bin !!
12-06-2008, 05:26 AM | #9 |
19 X5 1998 M Roadster
64
Rep 1,503
Drives: 135i Alpine White / Terra
crazy...nice chunk of value just taken...from the car..
better yet, a set of cup holders would have added more value..
'09 135i Dinan In BMW heaven 09.28.2022 - Stage 2/Alpine White w/Terracotta /High Gloss Black Trim/ZCW/ZPP/ZSP w/313's /CA/PDC/Steptronic/
12-06-2008, 05:55 AM | #10 |
135i Coupe Owner!
46
Rep 1,009
Why do you say that? It's a genuine BMW part.. I wouldn't consider adding performance exhaust or CF diffuser etc. as mods that lower resale value compared to 3rd party aftermarket.
2008 BMW 135i Coupe
12-06-2008, 09:55 AM | #11 |
70
Rep 2,224
uh, no......he didn't affect the value by adding an OEM piece to the car
- Joe Walsh |
03-15-2009, 02:38 PM | #12 |
Rep 128
template
A couple of people have asked for the cutting template that came with the retrofit kit. so here it is.
[SIGPIC][/SIGPIC] |
03-15-2009, 03:13 PM | #13 |
Unloved BMW Addict
86
Rep 1,185
Drives: Z3 Coupe, 3 318Ti
Very nice. and Very Tempting!
03-16-2009, 02:02 PM | #15 |
Rep 5,970
04-11-2009, 10:13 PM | #16 |
Rep 52
Damn nice job... I think I will be doing this as well...
2004 Porsche 911 C4S, Seal Grey / Black, X51, Sport Exhaust, Carbon Fiber
2006 Porsche Boxster S, Guards Red / Beige 2001 Audi A4 1.8T Quattro, Laser Red / Black, APR Stage 2, H&R Coil Overs, Window Tints, BBS Wheels, Combination Pillar Boost Gauge/Airbag, Xenon Headlights 2008 BMW X5 4.8i, Black Sapphire / Saddle Brown |
04-15-2009, 01:42 PM | #19 |
Rep 4,070
Hmmm....very intriguing...I might do this one day...nice work man!
08-26-2009, 11:29 PM | #22 |
Rep 237
Drives: 2008 135i
I'm in Europe and have asked my dealer about doing this. They say it can't be done but now I have a part number and can see about getting it done. Great job!! Thanks!!
Mike
