01-27-2009, 04:32 PM | #1 |
Rep 99
DIY: The 135 Muffler Innards Mod
I was going to mod the inside of the 135i muffler for a bit more sound.
Here's the story: http://home.comcast.net/~david.johns...MWMuffler.html Dave J.
2009, tuned 135i, gone, but not forgotten.
Fear of dying exceeded thrill of speed. (and coordination.) |
01-27-2009, 04:39 PM | #2 |
1addict, and proud
40
Rep 1,019
hmmm can you post a before and after sound clip?
*grin* EspressoBoy PS I had to ask...... I just had to. I am also a pirate! But not sure how long more.... (see flag) I don't make a very good pirate... I drink too much espresso and not enough rum. |
01-27-2009, 05:13 PM | #3 |
Rep 99
If I put it back together, sure.
I'm still trying to decide what to do. Dave J.
01-27-2009, 05:25 PM | #4 |
Rep 1,262
Doing this makes the exhaust sound quite a bit more aggressive than stock. Based on the pics, I'm not sure it'll offer much more performance; however I have heard the result of 2x cars with this done and it sounds great.
01-27-2009, 05:37 PM | #5 | |
Most interesting Roadster
70
Rep 2,224
Drives: '01 Z3.0 Roady;'10 C300 Sport
I can't complain, but sometimes I still do........Life's been good to me so far.
- Joe Walsh |
01-28-2009, 08:49 PM | #6 |
Rep 99
OK, I'll put it back together, and give it a go.
Suggestions on the proper way to provide good sound clips would be appreciated. I do have a DB sound meter, not sure if the still/mov camera has sound, and I don't think SHE will let me put HER laptop and webcam outside. (SHE is rather cautious when it comes to HER computer.) DJ
01-28-2009, 08:59 PM | #7 |
Rep 786
At "Pull that glass out of there, time for the real fun." on the site it looks like you scalped an AARP member!!!
'09 135i 6MT : Space Grey/Black ette : Cold Weather Package : Sport Package : Glacier Silver Aluminum Trim : iPod and USB : Nav : HD radio : Premium hi-fi system
01-28-2009, 10:59 PM | #8 | |
Rep 99
<on old guy memory> One of my heros in the 60's was an old guy. He had a repair shop in Fresno, for sports cars, last name was Cardwell. He was in his 70's, and drove a Cobra. In those days it was like American Grafitti, drag races from one light to the next. The cops knew him, knew he was not going to do anything stupid, never got a ticket. But he, and his wife, with her little scarf were out EVERY Saturday night. Taking on all comers, from one light, to the next. Never lost. He was out autocrossing several times, but there was no competition. </on old guy memory> DJ
01-29-2009, 09:15 AM | #9 |
Rep 1,254
subscribed. I am interested in hearing the before and after. Nice job on cuting it open and explaining how things are wokring. Unfortunatly I can't add any help as i dont' know enough about the flow in a muffler.
01-29-2009, 09:28 AM | #10 | |
70
Rep 2,224
- Joe Walsh |
01-29-2009, 09:38 AM | #11 |
Mr. Nice Says Hello
637
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
subscribed for soundclip
01-29-2009, 09:59 AM | #12 |
Rep 786
AARP was stuck in my head because I have been looking up my mothers benefits for her over the past week. Lol. I always wanted grey hair when I was little, as it comes in I still like it.
01-29-2009, 03:03 PM | #13 |
Rep 86
I am glad someone has decided to have a go at the stock muffler. I think about it every time I open the shed and step over the damn thing. Since I have the replacement installed, there is no burning need to get on it. From the photos of the inside, it appears that improvement will require experimentation. Flow improvement should be as important as increased sound level. Mechanicalmagic, if you haven't already welded yours up, you may want to consider the following:
The primary chamber with packing may impact sound levels only and the latter stages may yield better results. What I envision is something like this: 1) Design some sort of inexpensive flow meter to gauge the restriction and changes. A fairly high volume air sourch is needed. You may have or can borrow a dust collection blower--1hp motor connected to a fan with a 4" outlet. Other possibilities are a leaf blower, A/C blower, or a compressor with a large hose. Neck down to outlet to the size of the muffler inlet. Add a vertical clear plastic tube just before the muffler. The tube dia. should be just large enough for a ping pong ball to easily move inside and be longer than thought necessary to allow fine tuning. The size of the inlet hole and if necessary an outlet hole at the top will be determined by how the system reacts. 2) Take a reading with the stock muffler. 3) Cut and modify the innards. 4) Replace the cut panels and seal with duct tape, 3M putty tape, or whatever you have that works. 5) Take readings, reopen and try different mods, and compare results. 6) If possible, try the modded muffler on the car before welding it up. Use hi temp muffler patch tape, hi temp silicone, or some combination of things. If you warm the car up before switching and only run it long enough afterward to get a good sound recording, you may be able to get away with materials that don't do well at high temps. When satisfied, weld it. There are some unknowns that might make the whole effort worthless. Will the air source produce enough flow? Will the tube/ball be sensitive enough to indicate the differences? I am guessing that commonly available mechanical pressure gauges and shielding gas flow gauges are not sensitive at the pressures involved. Perhaps a flow bench will work but who has access to one? |
01-29-2009, 06:29 PM | #14 |
Rep 44
I'd use a golf ball in a clear 1.5" PVC pipe. I think the diameters are perfect from the days i made a golf ball cannon in high school (hair spray propellant, gas grill sparker for an igniter and a golf ball launched into the clouds).
Necking down a leaf blower could be difficult though and they provide quite a lot of CFM air. |
01-29-2009, 08:41 PM | #16 | |
Rep 99
I did TRY to setup a flow bench. I used my 1.5 hp shop vac blower motor. The three inch output fits into the input flange very nicely. I also got out a Dyer Pressure gauge (0-1" of water) with at least 100 increments. My first attempt using some rubber hose was just great. .26" pressure with the valve open, .96" with the valve closed. Then I tried to duplicate the test. Got negative pressure all the time (Venturi effect). So I tried all sorts of other ways to sample the pressure. No luck, got frustrated, F&#$ it. As an aside, with the shop vac motor running full blast, there was VERY little air coming out of the gaping holes. I could have used toilet paper to cover the holes, wet on the edges to hold it in place. I could have built a rotameter flowmeter, but didn't think about it. And after looking inside the muffler, I don't think there's any good way to reduce the restrictions, on a stock muffler. OK, if you were to cut the entire top, and bottom off, leaving just a band to hold things together, then you could cut off the top pipe, and fab a longer radius "S" pipe. weld it in. Then cut out the lower pipe, and fab a new one. Then weld up all the holes. I pondered filling the holes, but the access from the top only made it a no-go. (But that sort of defeats the purpose, it can be seen. As in "But officer, look it's got the stock muffler. BMW part numbers, look here".) And, for you sound nuts. I spent this morning trying to figure out how to get some sound clips, given what I got. (I even had to resort to RTFM on the camera.) My sound skills are not yet proven. And again, any suggestions on how to get a GOOD sound clip?
02-07-2009, 07:10 PM | #17 |
Rep 99
Page Now Has (bad) Sound
OK, I got the resonator on and did my best at some sound. Not my best work.
Click the third line: "Goto the Second Part of the story" for the details. I will be at some GGC BMWCCA events, car #223, Cashmere SIlver 135i. Dave J
02-07-2009, 09:01 PM | #18 |
Chemofski
54
Rep 1,295
Nice job. Would be great if you could make a table of your findings with each setting - stock, golf tee and hairless. Include the decibel reading at idle, 1000 rpm steady, 3000 rpm steady, etc. I'd also inlcude a notes section for each where you could include your personal thoughts and impressions.
Again, nice work.
'13 Individual Frozen Brilliant White ///M3 Coupe
Ordered 2/15/12 | Euro Delivery on 9/21/12 | U.S. Redelivery on 12/6/12 | Motor Dead on 7/15/13 '13 Space Gray/Mugello Red X5///M Pavement Punisher | Snow Muncher | Family and Board Hauler | Roadtripper |
02-07-2009, 10:28 PM | #19 | |
Rep 99
To do this right, I would need a chase car, with a GOOD microphone, or a track situation. Don't got it. If anybody has a good comparison vehicle, in the SF Bay area, I'm ready to do a side by side. I'm not happy with my sound clips, but I don't know how to make them better. I'm not going to do another swap just to make another useless sound file. More suggestions Please. Dave J.
03-27-2009, 05:20 PM | #20 |
Rep 657
Soo golf T myth does work
-135i BSM, CRBL ,custom front lip/Indianapolis red fade, blacked out tail lights/corner headlights, golf tee, BMS Air intake, SSTT, CF spoiler,Powdered coated OEM rims gunmetal high gloss,custom Rear diffuser Black/Indianapolis red fade |
