02-25-2009, 11:13 PM | #1 |
yodog
197
Rep 5,025
H&R spring suspension problem?
I just got H&R springs on my car. I got them installed by a reputable local shop.
I noticed the front left has about 1cm more fender gap than the right side. Also the rear left has like maybe half a cm more fender gap than the right side. Is this normal? I was thinking it's like that to accomodate the drivers weight or it was installed wrong. I would think it's unlikely they installed it wrong bbecause the springs have to go in a groove, plus they've worked on many BMWs and other high performance cars. Anyone with H&R springs notice the same thing I noticed?
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
02-25-2009, 11:21 PM | #2 |
Bored at work....
891
Rep 5,393
I believe that the springs may need a few miles/days to settle properly. Also, tend to agree with the weight thought.
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
02-25-2009, 11:33 PM | #3 |
Rep 666
Yea should be normal. At least stock it's normal. It's due to offset drivers weight
2008 E92///M3 - | Alpine White/Fox Red Extended Novillo | Technology | Premium | Cold | Mods: | 19" Avante Garde | Macht Schnell Filter | RPi Scoops | Rogue SSK | MS Spacers | ACM Test Pipes | ESS Tune | Remus Race | LUX V4 Angels | KW V3 | |
02-26-2009, 02:02 AM | #4 |
yodog
197
Rep 5,025
Bump, can anyone else with H&R's check and see if their front drivers sides fender gap is about 1 cm more than the passenger front side? Here's my car...
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs Last edited by MrHarris; 02-26-2009 at 04:28 AM.. |
02-26-2009, 12:07 PM | #5 |
365
Rep 5,859
Drives: Vorsteiner E60 M5
Location: 1460 White Oaks Rd. Suite F. Campbell, CA 95008
That's pretty straight I've not yet heard of it. I believe it does have to do with the springs settling and countering for driver weight... did you get the right model?
JL |
02-26-2009, 12:22 PM | #7 |
Rep 1,504
i had the same problem, took it back to the shop the following wk. i think the srping wasnt seated properly. when i got it back it was level on all 4 corners. see my post http://www.m3post.com/forums/showthread.php?t=226705
02-26-2009, 12:45 PM | #8 |
yodog
197
Rep 5,025
I'm getting an alignment today, Ill ask them what they think. It's almost been 2 weeks, so I'll probably go back to the shop after the alignment then after back for another alignment. How annoying.
02-26-2009, 01:42 PM | #10 |
yodog
197
Rep 5,025
Darrin at west end checked the height and it's 1/16th of an inch higher on the drivers side. When I get in the car it's exactly even. I guess the install was fine.
