      03-01-2009, 02:58 PM   #1
1013mm
aka 1013MM
1013mm's Avatar
Hong Kong
1263
Drives: pokingly flush
2009 135i  [8.26]
Changing the H8 = Fail
I failed to put back on the bitch cover for the headlamp on the passenger side man.... big time FAIL.... the cover is secure enough to not fall off but I can't seem to align the bottom two holes with the cover inserts. Its half way sealed and should protect enough. What do you guys think I should do I tried aligning it for 2 hours still failed. Any of you guys in the same situation? Will it fall off?
The drivers side was too easy....
      03-01-2009, 02:59 PM   #2
AlBel1214
AlBel1214's Avatar
52
Drives: past 135i, now c6, future M3??
Dude I feel your pain... I shaved off some of the teeth to get it back in correctly...
-----LS3 C6-----
z51 suspension, NPP dual mode exhaust(wild2mild),20% tint, zr1 replica wheels, gloss black fender stripes
R.I.P SGM 135i w/ some mods
      03-01-2009, 03:09 PM   #3
matt
Germany
61
Drives: munichs finest
use a torch, get it in the 2 inserts first, then its real easy.
the angle you use to get in the two inserts is really flat, almost upright.
just remember you you took it out
f*ckin' love my car <3
      03-01-2009, 03:20 PM   #4
mynew135
assistant to the regional manager
mynew135's Avatar
Drives: 135i
2009 135i  [0.00]
You can do it the way Noize did it here:
http://www.1addicts.com/forums/showt...=212882&page=2
It took me a few times before I got it connected. Had to take a break and calm down and then tried again.
      03-01-2009, 03:48 PM   #5
TP 135i
TP 135i's Avatar
Drives: 2008 135i SGM MT
Additional tips here
http://www.1addicts.com/forums/showt...ght=bitch+clip
2008 135i SGM
      03-01-2009, 04:00 PM   #6
MadMan77
↓↓↓ Ex-Con ↓↓↓
MadMan77's Avatar
Guam
34
Drives: Jet Black '08 135i
I have changed those lights three times and have not had a hard time disengaging the clips any of those times. How are you guys trying to pull them off?
      03-01-2009, 04:24 PM   #7
Simon_135i
Collecting dust!
Simon_135i's Avatar
55
Drives: 135i
2008 E82/135i  [0.00]
The clips are easy if the cover is aligned. Problem is getting the cover back on and into the bottom slots ... I will see if I can get a video for DIY on how I do it. It gets easier when you taken it apart like 20 times
Mad- or anyone - If you have a code error with the bulb does it stay on constantly? I had one it came on but it went away....
      03-01-2009, 04:53 PM   #8
MadMan77
↓↓↓ Ex-Con ↓↓↓
MadMan77's Avatar
Guam
34
When I put the Luminics bulbs in and they threw a code, it would only throw a bulb-out indicator when the headlight was on for a couple minutes. I don't remember if the indicator would turn off if I turned the headlights out but it did reset when you turned the car off and then back on.
      03-01-2009, 07:55 PM   #9
Simon_135i
Collecting dust!
Simon_135i's Avatar
55
Drives: 135i
Strange... I had no problems for 3 days and then I changed the bulb alignment and the damn error came up...
      03-01-2009, 09:59 PM   #10
KeithLM
Proud 1er
KeithLM's Avatar
Drives: Crimson/Coral 135i
jzhang, give it another try. I did this a while back, I'd never messed with the lights before and I managed to pull it off. It was a struggle, but it'll go back. Take it all the way out and look over everything real close and see if you can see how it's supposed to work, then give it another try.
      03-01-2009, 11:20 PM   #11
bozola
Unloved BMW Addict
bozola's Avatar
Drives: Z3 Coupe, 3 318Ti
1999 Z3 Coupe  [10.00]
1998 318Ti  [0.00]
1998 318Ti  [10.00]
2008 128i  [9.00]
Video would be cool....
      03-02-2012, 03:28 PM   #12
R0n1n
R0n1n's Avatar
Drives: 2010 BMW 135i Alpine White
Yeah I got the error code too. 1-2 hours and my back was hurting and my hands were cut up. I have avoided changing my AE's since....
_______________________________________________
2010 Alpine White 135i
      03-02-2012, 04:04 PM   #13
Dackelone
European Editor
Dackelone's Avatar
Germany
10616
Drives: N54 e82
OP - you want to make sure those covers are back on correctly bc... if not you will get moister in the headlight housing. Then... you might burn up the HID bulb/ballast or worse the headlamp itself has some circuit boards inside the headlight housing. It is BIG $$$$, as in $1500 per side to fix COD. I have a second go at it tomorrow. GL.
      03-02-2012, 04:19 PM   #14
KeithLM
Proud 1er
KeithLM's Avatar
This happened 2 years ago, hopefully he's fixed it by now.
Stett Performance Charge Pipe with DDV, Cold-Air Intake, Front Mounted Intercooler, and Stage 1 Oil Cooler.
I've recently moved my photos to Google's web albums. Photos can be found here, here, and here.
      03-11-2012, 08:25 PM   #15
1ToBeOn2Wheels
Freude am Fahren
Drives: B9 Audi S5 Coupe
You are gonna want the cover to be fitted correctly and sealed. Otherwise, you will get moisture, the adaptive headlights motors will fail, xenons will fail. Ask me how I know...
      03-11-2012, 08:43 PM   #16
BFD99
The Stig!
BFD99's Avatar
Drives: 2008 135i 6MT
2008 BMW 135i  [10.00]
I was able to knock both of mine out in about 30 minutes, removed the evap balls on the passenger side, gave me alot more room, and removed the clips and pulled cover up and pulled it out a little bit, not all the way, just enough to squeeze my hand in there and swap in the BMW 4 LED bulb. No problem at all!
2008 135i - FBO + JB4 15ohm + Water Meth
http://www.1addicts.com/forums/image.php?type=sigpic&userid=136481&dateline=13270  10872
      03-12-2012, 07:42 PM   #17
asaborio
asaborio's Avatar
Drives: 2008 135i vert
Used the "Noize" method to replace mine, but when I was putting the canisters back in my ratchet extension fell down. I have spent the last hour reaching around trying to find it and it is gone! I drove the car around a few times the block to see if it would fall or if I could hear it rattling and it is not, so I hope no damage comes from that!
1addicts
