KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
04-29-2009, 01:42 AM | #1 |
Rep 924
Drives: Ford Falcon Ute, Ducati 1198S
What size spacers for ET20 offset fronts? (photo included)
Hi guys,
My car is now lowered on Eibach springs with VMR V713 wheels. The rear V713s have an offset of 22 (stock 23) and I have fitted 10mm H&R spacers giving the rear a great look. The fronts are offset 20 (stock 29) yet still look too far inside the car compared to the rears and I want to bring them out with spacers but not sure what size to go with. I see that 15mm spacers on the front are fine on lowered cars with stock rims, given the offset of my V713s is 9mm further out is it as simple as using 5mm spacers to give a better look?
BMW E92 M3 6MT, G-Power SKII supercharged, custom exhaust with 100 cell cats and Remus Sport mufflers, Brembo 380mm BBK, BMW Performance steering wheel, LUX H8 angel eyes, CF CSL boot, Hamann CF diffuser, Vorsteiner CF lip, CF grilles, CF gills, CF bonnet vents, BMW Performance stripes, RAC RG63 wheels, Eibach lowering springs, camber modifications.
04-29-2009, 03:50 PM | #2 |
Rep 3,039
5mm should do it
You're looking good as is, I don't know if i would do anything. You're already 9mm extended from stock set-up so if you want to mess about 3 to 5mm is all you need |
04-30-2009, 03:56 PM | #4 |
yodog
197
Rep 5,025
Looks good as is, but if you're not satisfied I'd go 5mm front.
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
04-30-2009, 04:10 PM | #5 |
BimmerPost Supporting Vendor
520
Rep 3,612
to look as aggressive as the rear, you would need an 8mm, but I dont think those are available anywhere, so a 5mm is the most aggressive you can run on that. If there was an 8mm spacer, it would look similar to how the guys with 18mm front spacers look
