05-19-2009, 07:22 AM | #2 |
Rep 32
Drives: '85 Citroën 2CV / '09 BMW Z4
05-19-2009, 08:05 AM | #4 |
Rep 1,762
Drives: Porsche Panamera
Wow you now need to add an option to lower the roof by a key????
05-19-2009, 08:09 AM | #5 |
Rep 2,353
Drives: 2009 Z4 sDrive 23i
You can lower and raise the roof without having comfort access (certainly on UK cars).
E89 Z4 sDrive 23i... for the more discerning driver
05-19-2009, 08:45 AM | #6 | |
Rep 32
If you have comfort access the roof goes up a bit so it's easier to access luggage in the boot. Sorry for the misinformation!
My cars:
1985 Citroën 2CV Spécial ~ 28 horses 2009 BMW Z4 sDrive23i ~ 204 horses |
05-19-2009, 10:14 AM | #7 |
Ed
18
Rep 298
They say you can't open or close the roof when driving (3th brake light is not visible when roof is busy opening/closing)...
BUT what happens we you start driving during when the roof is busy opening? It just stop opening and you have to stop the car and press again the opening button? EdP |
05-19-2009, 11:28 AM | #8 | |
Rep 122
05-19-2009, 11:32 AM | #9 |
Ed
18
Rep 298
05-19-2009, 11:45 AM | #10 |
Rep 200
05-19-2009, 12:29 PM | #11 |
Rep 2,353
On the old Z4 you could hold the button in and then drive off, but keep the button held to complete the operation. If you let go of the button whilst the car was moving, the roof wouldn't move until you completely stopped! I think there will be a speed detector and the roof will only move if you are stationary.
05-20-2009, 06:12 AM | #12 |
Rep 1,297
I think if u are moving at speeds lower than 30km/h, the roof would still be in motion and won't make u look like an idiot with a half opened roof :-P
Wanna know my mods for my 335i? It's here! http://www.e90post.com/forums/showth...ght=blue+water
Lamborghini's Mica Orange E93 M3 Akrapovic Exhaust //Challenge Rear CF diffuser//ESS VT-575 Supercharger |
05-20-2009, 02:20 PM | #13 |
Rep 1,027
I was told on z4 you MUST insert the key in the door lock to open from outside or comfort access option to do it with the FOB
M Sport Line Estoril Blue
05-20-2009, 04:34 PM | #14 |
Rep 293
you can open the roof with the key and you can only cloesd it with the key if you have comfort access,
2015 M4 MG on SS.
X:2002 M3 ESS JeppeJ edition,2011&2010 335i DCT, 98 M Coupe, 10 X6 30d, 09 z4 23i +++++ |
05-20-2009, 06:25 PM | #15 |
Rep 5
05-20-2009, 07:12 PM | #16 | |
Rep 293
you have to hold it the hole time
2015 M4 MG on SS.
05-22-2009, 06:28 AM | #17 |
Rep 519
Comfort Access in the E89 works same-same as E93. Info above is mostly correct.
Close to car (13 feet for E93 and probably same for E89 - antenna range), press and hold LOCK on fob to raise roof, UNLOCK to lower. Car does not have to be running.Having lived with the hardtop for over two years now in my E93, these comments: Absolutely trouble-free (after early replacement of faulty interlock switches in top of windshield - no longer an issue in cars built after earliest runs).In all, no one should hesitate because of the roof. It's a BMW home run and the E89 has two years E93 design and field experience. |
05-22-2009, 08:24 AM | #18 |
freude am fahren ....scheiden freude...
17
Rep 299
05-22-2009, 09:57 AM | #19 |
Rep 62
05-23-2009, 04:50 AM | #20 |
Selling drugs to BMW addicts
17
Rep 468
US SPEC:
Lowering / Raising via FOB no problem /w ComfortAccess 302 The Roof will not move while driving. Reason Nr1: You will risk deforming it (the mechanics) since it will act as a big sail while moving. The Roof will stop moving and the car will inform you in a very -well- obvious way that the roof operation has not been completed.... PING PING PING No E-Brake needed. Just tried it outside..... Ray
Quality US Spec Used Cars for Military Members stationed in Europe. Specialized in BMWs and MINIs up to 10k miles. |
06-26-2009, 02:43 PM | #21 |
Rep 79
Hi,
I have just got this car without comfort opening and can open the roof with the key fob button but not close it, for that I have to use the key in the door lock. Z4 beemer guy, can you really do both with the key fob buttons. If so how? Thanks John |
06-26-2009, 03:02 PM | #22 | |
Rep 2,353
I tend to only operate the roof with the engine running as it apparently puts less strain on the battery.
