05-23-2009, 10:41 PM | #1 |
Rep 31
Dice with Analog DSP Install--please help
I attempted an installation today of the Dice Silverline Pro kit (which I just received) in my 2004 Z4 2.5i with Analog DSP. Everything looks to me like it's installed correctly, but all I'm getting is the text display on the Business CD, but no audio.
Pertinent facts: 1) I'm using a 2nd Generation iPod Nano 2) I spoke with Tom at EAS and ordered the DSP kit because there was the small coax wire connected on the amplifier by the battery 3) I'm getting ID3 info on the Business CD display but no audio Steps I took: 1) I connected the DSP kit by tapping into the thick red wire which the factory has running along the amplifier mount near the battery (per Bavarian Soundwerks instructions)--I stripped insulation from the red wire and from the 12V+ (white stripe) wire on the kit, wrapped the 12V+ wire tightly around the red wire, soldered that connection, then wrapped it all with electrical tape. I connected the ground by stripping insulation and then wrapping it around the negative terminal bracket between the nut and the washer that tightens everything down, because the bavsound instructions said I could ground directly to the battery 2) The DSP kit is hooked up by tapping power as listed above, plus the gold-tipped coax cable from the kit is installed from the adapter into the factory amp (Carver) by the battery 3) The DSP adapter is tucked under the amplifier (?) that is mounted to the firewall behind the seats, with the 3-pin connector hooked into the cable I fished out of the car (red wire in the middle, brown wire on the side). However, in that same location, there's a coax connector on a black wire of the same size that isn't connected to anything. 4) When no sound would play, I did a reset of the iPod Nano (Menu + Select until the Apple logo displayed) What happens: I hook up the iPod on the connector and it takes a little while and then shows the DICE logo and "OK to disconnect." When I hit the #6 button on my Business CD, it shows all the software and iPod version numbers. When I hit #1, it "plays" the songs off the iPod, but there's no audio, just the ID3 (track, artist, album) information displayed on the head unit. I've switched modes to FM and CD to make sure the audio volume is at an audible level, but I still get no sound when I go back to the iPod (CD Changer) mode. I'm wondering if maybe I'm not getting power to the DSP adapter, but I don't know how to test. I disconnected the power connector on the DSP adapter and everything performs the same, if that helps you guys with more info. So, what do you think? What do I need to do to get this working? Maybe I'm way off, but it seems like I'm really close and just missing a small step. Thanks in advance, everyone! |
05-24-2009, 12:24 AM | #2 |
Rep 18,849
The DSP adapter is not needed, all 2006+ models were analog DSP equipped.
Remove the DSP converter and connect directly into the 3/6 pin adapters and your audio will return.
05-24-2009, 07:30 AM | #3 | |
Rep 31
I was thinking about it overnight and I wonder if I should have something connected to the coax that's near the firewall for the seats. Are the connections supposed to go: Carver DSP Amp (by battery) -> DSP kit -> 6-pin connector (which is what I have done so far) or Coax by firewall (next to the 3-pin wire) -> DSP kit -> 6-pin connector (but if that's the case, what's the coax wire for in the kit?) Thanks in advance! Please let me know if you want pictures of anything. |
05-24-2009, 01:08 PM | #4 |
Rep 31
Photos taken
In hopes that this would help, I took some pictures of my installation.
The pictures, in order (I tried to keep file sizes reasonable!) are: 1) The power source I tapped for the DSP unit--it's the large, red wire. I stripped insulation, wrapped the 12V+ wire around the red wire, soldered the connection, then taped it. 2) The ground to the nut on the negative battery terminal 3) The connections into the DSP adapter, which I tucked under whatever that thing is on the firewall for the rear seats 4) A shot of whatever that thing is 5) A shot of the connectors and showing the unused coax that's lying there. Thanks again, everyone! |
05-24-2009, 01:50 PM | #5 |
Rep 18,849
The connector in the last picture should be plugged into the coaxial port of the DSP adapter - assuming its still connected to the factory amp.
05-24-2009, 02:24 PM | #6 | |
Rep 31
I took the iPod inside and hooked it to my Logitech portable player and it played fine, so at least I know that it does work to play from the dock connector. I took an older MP3 player out and hooked up its headphone jack to the Aux-In on the DICE, pressed button 5 and switched to Aux mode, and there's still no sound. I suspect it's a problem with the DSP unit--is there any way to verify that it is receiving power correctly? Have you done installs tapping that red wire as Bavsound recommends? Like I said before, I've tried disconnecting the power adapter to the DSP unit and everything performs the same. That's why I think maybe the unit isn't getting powered properly, but I don't know how to check. |
05-24-2009, 02:30 PM | #7 | |
Rep 18,849
Next verify all DIP switches are in the UP positions. Also - there is a remote chance you have placed the DICE in AUX mode if buttons were pressed at random on the radio. Pressing CD5 and the left arrow once will revert back to iPod mode, then pressing CD1 will exit SourceSelection mode.
05-25-2009, 10:26 AM | #8 |
Rep 31
Tom, thanks again for your weekend/holiday support--I really appreciate it! Latest update:
1) I connected the DSP unit with +12V to the positive terminal, ground to the negative. Same result--text display but no audio from the system. 2) Verified that all four DIP switches are in the UP position. 3) Verified that the DICE is in IPOD mode. Where can we go from here? Is it possible one or both of the units is defective? I read the official thread and I tried the reset method (although I wasn't able to touch the terminals--they wouldn't reach one another--can that be done using jumper cables to avoid the stretch? I'm sure they can reach each other if other people have done so--I just didn't want to stretch mine out). I did let the car sit with both terminals disconnected for 5 minutes, reconnected positive, reconnected negative, reset the iPod...same result. |
05-26-2009, 12:27 PM | #9 | |
Rep 18,849
Have you tried plugging the coax included with the DSP module to the factory amp? There is a possibility your existing cable is damaged/severed. A continuity test would confirm the cables are working fine. Otherwise, we have no problem exchanging the equipment if needed.
05-26-2009, 04:16 PM | #10 | |
Rep 31
First thing I tried was hooking the provided cable into the Carver amp and then into the DSP unit. When that didn't work, I reconnected the factory cable to the Carver amp and connected the coax at the firewall to the DSP unit as you instructed earlier. Am I right in thinking that has accomplished your request--the connection has been attempted using both your cable and the OEM cable? I tried leaving you a VM earlier but I don't think we're going to be able to connect on the phone. Thanks again for all your help so far--I hope we can get this working soon! |
05-26-2009, 08:40 PM | #11 | |
Rep 18,849
06-13-2009, 06:28 PM | #12 |
Rep 8
Did you either fix or find out the problem. I have the same issue with mine. I plugged in the RCA cables before the DSP adaptor and got music but will not work through my car stereo.
06-15-2009, 12:49 PM | #13 |
Rep 18,849
We we positive your Z4 is equipped with Digital DSP?
06-15-2009, 06:01 PM | #15 | |
Rep 18,849
https://www.europeanautosource.com/s...mod_id=2&id=11
06-15-2009, 06:50 PM | #17 |
Rep 18,849
Yes, this would signify Digital DSP.
06-15-2009, 07:22 PM | #18 |
Rep 8
Okay thanks for your response. Now I have tried several different DSP adaptors with no success. As I said earlier if I plugged a radio into the RCA cables that go to the DSP adaptor I get satelite radio but once I plug it into the DSP port on the amp I get nothing, but I get the information on the car radio screen. Does this mean my amp is bad or?????
06-15-2009, 07:29 PM | #19 | |
Rep 18,849
Look for a 6-pin adapter instead, which is typically bundled near your 3-pin adapter.
06-15-2009, 08:08 PM | #21 | |
Rep 18,849
A CD Changer plugged into the amp as verification will determine the connectors are working properly.
09-27-2009, 12:50 PM | #22 |
Rep 8
Its been awhile since my last post. I just received another amp and plugged the coax from the DICE adaptor and still no sound. I can plug the rca cables that go to the DICE into a radio and I get music. I am at my wits end on this and don't know what to do now.
