06-30-2009, 01:58 PM | #1 |
BimmerPost Supporting Vendor
518
Rep 3,612
▀▄ eas | H&R Sport & Sport Plus springs for e9X M3 - In stock!
The most popular spring in H&R's line-up, Sport Springs will lower your vehicle an average of 1 inch for a lower center of gravity, improved handling and a more aggressive appearance. Sport springs feature more control than that of the OE Sport spring, but is still comfortable for daily use. Sport springs are an excellent choice for street and occasional track use.
Features - Aggressive ride stance with moderate drop - Superb ride quality - ISO 9001 Certified, TÜV Approved - Crafted from special 54SiCr6 spring steel that provides the spring with unparalleled tensile strength and resiliency - Lighter and more durable than other automotive coil springs - Compatible with EDC-equipped systems Approximate Front/Rear Lowering: Front: 1.0" Rear: 0.6" H&R Sport Springs - BMW e9X M3 (Coupe/Sedan) http://www.europeanautosource.com/pr...oducts_id=2370 H&R Sport PLUS Springs - BMW e9X M3 (Coupe/Sedan) http://www.europeanautosource.com/pr...oducts_id=2371 H&R Sport Springs - BMW e9X M3 (Convertible) http://www.europeanautosource.com/pr...oducts_id=2372 All e9x M3 H&R springs are in stock for local will call or shipping at our own facility - no drop shipping like other vendors. This way we have full control on shipping times, tracking and delivery confirmation to your door. Feel free to PM me directly for any questions, or install appointments. |
07-09-2009, 06:40 PM | #7 |
yodog
197
Rep 5,025
Isn't the drop the same?
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
07-09-2009, 07:00 PM | #8 |
8265
Rep 18,849
08-05-2009, 04:56 PM | #14 |
257
Rep 4,048
08-07-2009, 01:57 AM | #15 |
Rep 136
Please PM me if you have a set in stock, i might step by tomorrow and pick them up
Also can you recomend me the best spacers size with OEM 18s plus the springs? Thanks |
08-07-2009, 11:25 AM | #16 | |
518
Rep 3,612
As for the spacers, if you want to max out the stance, you can get away with a 15mm rear spacer and 18mm front- this will bring both the front and rear wheels to the edge of the fender equally. If you want a slightly less aggressive stance, but still a very noticeable one, go with the 12mm rears and 15mm fronts. Both set ups are in stock at the moment! PM me if you want me to set them aside for you |
09-10-2009, 01:04 PM | #17 |
8265
Rep 18,849
In stock - ready to ship.
09-10-2009, 04:12 PM | #18 |
Rep 1,920
Tom/Brandon,
I am considering some H&R's for my E90 M3. I am also considering spacers. Can you comment on ride quality/differences/performance with spacers? Asside from the cosmetic differences, are there any handling changes? One would think that with a wider stance, the car would be a bit more stable...just curious...TIA
Tim <--- apparently likes "3" cars
2014 E63S -- The Rocket 2014 F30 328i -- Kids car 2008 E90 M3 -- Sold 2004 GT3 -- Sold 1997 M3/4 -- Sold 1995 M3 -- Sold |
09-10-2009, 04:22 PM | #19 | |
8265
Rep 18,849
A very common configuration on a stock M3 would be the springs and a 15/12mm spacer package.
09-21-2009, 11:25 AM | #22 |
257
Rep 4,048
There are several benefits to having a stiffer spring. The most obvious is to lessen the body roll throughout the car, as well as adding a more stable feel through corners. By lowering the car as well you're adding a lower center of gravity so the car can go through corners at higher speeds.
