03-25-2010, 07:54 PM | #3 |
J1V3.455.7URCK3Y
Rep 134
Back from the dead. Can anyone comment on fitment issues with the BMW performance exhaust and an aftermarket mid-pipe? Does the mid-pipe give an appreciable increase in sound w/ the BMW PE?
03-25-2010, 08:01 PM | #4 |
Rep 257
Yes, more grunt with 2nd cat eliminate mid pipes. I personally couldn't run with just the BMW performance system. Just still too quiet for my taste...this coming from someone with a Roush and longtubes and 5" race cans....
03-25-2010, 08:02 PM | #5 |
Rep 257
...and yes, my CPE midpipes bolted up to the axle back section of the performance exhaust. You may want to try just midpipes b/f the performance, as it bolts to axle back section, so the resonator section is eliminated with midpipes in any event...
03-26-2010, 09:18 AM | #6 |
Rep 1,609
Try mix it up with Maddad mid-pipes, I think it will amplify the sound by another 20-30% more.
7/08 135 Coupe, Crimson Red, 6 SP, Sport, Taupe Lette/Aluminum. Performance Mods: JB4 on Map 5, BMS DP Fix V3, Injen polished intake, AR Catless DP, Maddad resonated mid-pipes, aFe exhaust polished tips, ST Suspension Coil Over and Hotchkis front sway bar. Others: BMS OCC, BT Scanner, Mud Flap. Next Mods: AA Front Strut Brace.
03-29-2010, 12:36 PM | #7 |
Resident Kerbalnaut
478
Rep 10,703
Where exactly is the cutting done on the stock midpipe done to mount the perf exhaust? I havent had my car in the air in awhile to check. Im thinking about doing a bit of a frankenstein exhaust. AR Catted DPs, Berk Midpipes, and the perf exhaust that I already have.
06-14-2011, 01:21 PM | #8 |
Bimmer Newbie
24
Rep 312
Drives: CSM N54 Prem/Comf/Sound
