08-06-2009, 12:51 PM | #1 |
Rep 50
premium gas
how important is putting premium in the 1? does it need it
A careful driver is one who honks his horn when he goes through a red light.
08-06-2009, 01:26 PM | #3 |
Rep 619
Do you really want to find out by saving 20 cents a gallon?
Best case: Loss of hp Worst case: Potential engine damage over time I don't put much stock in "top tier" bs. Some do, I haven't noticed any variance what so ever although I don't put no-name stuff in either. Sunoco/Hess/Shell/Mobil all seem to run fine. |
08-06-2009, 03:25 PM | #6 | |
Unindicted co-conspirator
67
Rep 1,734
Drives: to work, mostly.
From the manual (p. 105):
08-07-2009, 06:08 AM | #8 |
Rep 166
Premium no matter what. You can get by on 87, but did you buy this car just to get by on it?
128i/Jet black/6MT/Sport/Premium/Blk. Boston/Heated/Xenon/Prem. HiFi/iPod
08-07-2009, 03:08 PM | #10 | |
Rep 5,970
Quoted for truth. You don't have to run Premium in the car, and it's not even remotely "risky" to run 89 in it, you're just not going to get the full power out of it. (That statement is made assuming it's running on the stock tune. On a tuned car you may very well be running the chance of engine damage using lower octane fuels) |
08-07-2009, 03:11 PM | #11 |
Detailer & Fitness Freak
23
Rep 514
you will not only make less of power than you would running 93, but you also will not get the same kind of fuel economy either. you will effectively save 15-20 cents a gallon running midgrade on a 135i, but your economy will suffer to the point that it will cost you more running the cheaper gas. not worth it in the turbo...makes ZERO sense/cents. just run the good stuff. you getbetter power...better fuel economy...no brainer.
135i coupe...Alpine White // Glacier Silver Aluminum Trim // Heated Coral Red Leather Seats // M-Sport Package // I-pod // PDC // 6-Speed Manual
08-07-2009, 03:20 PM | #12 | |
Rep 5,970
08-07-2009, 05:36 PM | #13 |
Rep 14
Teach us oh great Internet
The octane rating of gasoline tells you how much the fuel can be compressed before it spontaneously ignites. When gas ignites by compression rather than because of the spark from the spark plug, it causes knocking in the engine. Knocking can damage an engine, so it is not something you want to have happening. Lower-octane gas (like "regular" 87-octane gasoline) can handle the least amount of compression before igniting.
The compression ratio of your engine determines the octane rating of the gas you must use in the car. One way to increase the horsepower of an engine of a given displacement is to increase its compression ratio. So a "high-performance engine" has a higher compression ratio and requires higher-octane fuel. The advantage of a high compression ratio is that it gives your engine a higher horsepower rating for a given engine weight -- that is what makes the engine "high performance." The disadvantage is that the gasoline for your engine costs more. http://auto.howstuffworks.com/fuel-e...uestion901.htm |
08-07-2009, 07:14 PM | #14 | |
Nerd!
11
Rep 222
Ordered 7/6/09 : Delivered 8/15/09
6MT, Hotchkiss front sway. |
08-08-2009, 02:16 AM | #15 | |
Rep 5,970
08-08-2009, 12:12 PM | #18 |
Rep 388
According to the 1 series brochure I got from my dealer, the compression ratio for the 128i is 10.7 and 10.2 for the 135i. Therefore the 128i needs 93 octane more than the 135i.
08-08-2009, 12:36 PM | #19 | |
Rep 5,627
For the R1200RT motorcycle, BMW actually published a spec of 8% reduced peak HP using regular (Euro) 93 octane vs. premium 98 (US approx. 88 vs. 93). Of course, this is with an air/oil cooled motor with 12:1 compression, but the concept of reduced power due to computer managed timing adjustment is common to both bike and cage. Whether that translates into improved fuel economy in normal use is a good question, but anecdotal evidence seems to indicate that it does by at least 5~10%. Tom |
08-08-2009, 12:45 PM | #20 |
Rep 5,970
You're forgetting that the 135i is using forced induction, which effectively raises the compression ratio.
08-08-2009, 01:29 PM | #21 |
Girls can drive just as fast
Rep 39
First of all the135i needs at least 92 octane im pretty sure, my vw gti was turbo needed at least 92 bcz itsa turbo, my mini cooper s needed at least 92 octane also bcz it is supercharged, and my 135i on the way is going to have at least 92 octane in it at all times, come on ppl im a 20yr old girl and i even kno that lol, and im guessin if its a 128i its not turbo or supercharged it could live without premium gasoline
08-08-2009, 01:36 PM | #22 | |
Rep 5,970
Manufacturers selling cars in the US have to build them to run at rated power on 91 octane. That's as high as premium goes in most of CA, and a few other states. The manual states that you can run on 89 with no problems, but you're not going to make rated HP. |
