08-20-2009, 04:00 PM | #1 |
Rep 1,011
Drives: very slow and courteous
Leak from bottom of doors
I have a leak from the middle bottom of my doors (specifically passenger side) with grease/oil residue. I've noticed it from washing my car and always having to clean that spot time and again. Is this how it's designed? I can't understand how it would serve as a sort of drain by design but then leak a greasy residue.
I went to the dealership to see if other 1rs had the same stain - some did but not all. Anybody know if this is normal? If it is, what's with the residue? Could this be a factory defect issue? Thanks |
08-20-2009, 04:02 PM | #2 |
Most interesting Roadster
70
Rep 2,224
Drives: '01 Z3.0 Roady;'10 C300 Sport
I have it
I can't complain, but sometimes I still do........Life's been good to me so far.
- Joe Walsh |
08-20-2009, 04:04 PM | #3 |
↓↓↓ Ex-Con ↓↓↓
34
Rep 1,874
It is just the residual corrosion preventative coating from shipment. It will continue for quite some time since it is utterly impossible to remove all of it. It will slow over time though.
08-20-2009, 04:30 PM | #5 |
Rep 3,547
I noticed the sealant a couple places my first wash/wax. It was not just at the bottom of doors but I think that was one place I noticed it. It was yellowish and waxy. If yours is a different color, it may be something different or may have mixed with grime or a lubricant. I just removed it and figured I might see some more. I'd rather deal with a little of this now than rust later.
Jim
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09 |
08-20-2009, 06:13 PM | #6 |
Rep 4,070
Yeah I have the same thing as well.
08-21-2009, 01:53 PM | #7 |
Rep 1,011
Is this a guess or did you by chance get this answer from BMW? I'm just not convinced that this is an intensional design by BMW. Why would water be washing this stuff out through the door? Just doesn't seem right. Thanks for the reply.
08-21-2009, 03:30 PM | #8 |
エアーマンが倒せない
279
Rep 2,041
I think we all have it. I've seen it on other members pictures, as well as other 1ers in person.
09-06-2009, 09:54 AM | #12 |
Rep 3,350
If there was no drain in the door, then water would collect inside the door cavity. The sealant inside the door is a necessary evil. If you don't have the problem, then it means your drain is plugged which is worse,
09-06-2009, 10:08 AM | #13 |
Rep 4,070
BTW this has been going on for years. I used to have it on my old E39 as well.
09-06-2009, 10:53 AM | #14 |
Rep 130
I get streaks on both sides of my car... figured it was just road grime from where the water flows down since those are the lowest points on the car. Wipes right off when I wash it.
09-29-2009, 03:04 PM | #16 |
Rep 667
Drives: 135i Coupé
I have it too. It can be removed by claybar but it will come back.
09-29-2009, 03:07 PM | #17 |
エアーマンが倒せない
279
Rep 2,041
It actually gets better over time. I have less and less of it between washes since when I first got the car.
09-30-2009, 01:16 PM | #19 |
aka 1013MM
1266
Rep 9,545
everyone has it welcome to the club you're not an alien.
10-03-2009, 03:24 PM | #20 |
Rep 1,288
I've got it coming from under the roundel on the hood... both doors and a nice snail trail that shows up under the rear license plate.
I've had my car for well over a year and the stuff just keeps leaching out. *shrug* |
