10-08-2009, 01:08 AM | #1 |
Rep 1,432
Warranty Void!!!
There is no news like bad news.
Guys, If you are tuning your ECUs, better be careful. I had a ticking noise after a track session and it was related to a bent exhaust valve. I sent it in to my dealer and they told me its normal and subsequently, sent me a letter like this below. I am beginning to see quite a few engines with this problems with bent exhaust valves even on stock standard cars. Which makes me think at all if there is really a problem with these engines. A few experienced mechanics here have preliminarily told me that the exhaust valves may have been too hot and there is not much clearance between the pistons and the valves. I have a ticking sound now and I am waiting to get it fixed here. I am not sure what is wrong until I strip the engine and find out whats the problem. I find it funny that both my engine and drive train warranty has been void. Initially my dealer put in the wrong oil for my DCT gearbox and extended 6 months warranty on it. Now they are voiding that as well in attempt to save cost on replacing it if it kabooms. Must be a great opportunity to void things they can while they can. Untill now, there is no proof that the ticking sound in the engine is due to the tune and why the drivetrain warranty was also voided and how that is related to the tune as well. I ahve no problems whatsoever with my drivetrain so I am quite stumped actually. I was surfing through these forums so far and found out that this guy looks to have 100% the same problem as I have. http://www.m3post.com/forums/showthread.php?t=307802 Anyway I think you guys should be careful nonetheless. I dont think BMW is looking at cars with engine problems with fixing or replacing it in mind even if there is a problem with tuned or stock standard cars. At least for me that was the case. I will just fix the engine on my own cost since it was tuned in order to reduce the sensitivity of the O2 sensors for the Akrapovic Exhaust and some power. Not crazy stuff. I am interested to know those on stock cars who have this problem. Another service by a loyal M3poster.
2018 F80 LCI II ZCP ///M3 Mineral White M-DCT| Sakhir Orange Interior| |M Performance Exhaust| Last edited by satinghostrider; 01-05-2010 at 03:43 AM.. |
10-08-2009, 01:17 AM | #2 |
Rep 209
how long have you had the tune for? and is it a custom?
Remus Race Exhaust, AA X-Pipe Castles, AA SSK, AA ECU Tune, Evo Sport Pulleys, AFE Filter & Air Scope, HRE P40 20, H&R Springs ... |
10-08-2009, 01:30 AM | #3 |
Rep 1,073
Ouch. Sorry to hear that. I do think that if push came to shove they will have a very tough time proving your tune did anything to the engine/drivetrain.
10-08-2009, 01:46 AM | #4 |
Rep 1,432
Had it for 5 months with 0 problems. I only had the ticking sound after the second track day. First track day was flawless with the tune and I actually pushed it harder the first time than the second time around.
2018 F80 LCI II ZCP ///M3 Mineral White M-DCT| Sakhir Orange Interior| |M Performance Exhaust| |
10-08-2009, 01:48 AM | #5 | |
Rep 1,432
For sure they will have a hard time proving, since its only 2 lines of vague information on why they are voiding the car. And they took 3 days to make the decision after seeing the car. I find it extremely quick for otherwise reasons that dont prove anything beyond doubt. Also, we dont have this kinda laws like the Magnuson Moss warranty to fall back on here since there is not much customer protection in places here.
10-08-2009, 01:49 AM | #6 |
yodog
197
Rep 5,025
How'd they find out? They send your ECU to Germany or something? I heard a dealership can't find out themselves and have to get the ECU shipped somewhere...
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
10-08-2009, 01:56 AM | #7 | |
Rep 1,432
Well now I know and we know.
10-08-2009, 02:00 AM | #8 | |
Rep 1,432
I have a feeling that is what BMW will say to bent valves and valve springs as all the posts by some of those with these problems are told the same thing. I know I have hit the limiter a few times at 8,250 rpm but I dont hold it there for sure. I immediately shift. I had this problem with the old software where there was lag in the time you shift and the time the ECU shifts the gears. I dont see how a DCT can overrev either. Unlike conventional manual trannies, the dct has a prevention for over-rev.
10-08-2009, 02:13 AM | #9 |
8 tracks of madness
62
Rep 2,735
We all know that manufacturers leave a margin of error for safety but yes, any increase in power using a part not offered can be grounds for warranty voiding. All they have to say is you increased the HP level over the stock levels which strained the parts beyond their designed tolerance. Also, because of the extra HP the engine is making the trnasmission is stressed more as well.
Do I think ANY tune on an NA motor has enough of an increase in HP to be a problem? Not even a little. But as PG said, if the rev limiter was raised then you're screwed. But push comes to shove, you modded the engine and you have to live with the consequences. I mod all of my cars and I accept that some of what I do may void the warranty on some things. Ya gotta pay to play. |
10-08-2009, 02:18 AM | #10 | |
Rep 1,432
I am paying for this for sure but am absolutely sure the rev limiter was never touched. Pretty freaking sure abt that.
10-08-2009, 03:02 AM | #11 |
8 tracks of madness
62
Rep 2,735
I think it's a CYA thing. Most service departments aren't up on aftermarket gear and what the OEM components are rated for. All they know is "if it's not BMW it's bad."
I went through a warranty issue with BMW for one of my old installers and you can elevate this to a regional guy who can reinstate certain parts of the warranty. It kept my installer from having to pay 10 large to have his car rewired to have his warranty reinstated on his entire electrical system. The OEM navi failed in his 3-series and when he took it in they said it was because we had installed aftermarket amps and speakers, like they're even remotely interrelated. it took some arguing and prrof from our side but it can be done. I'd gather up as much evidence as you can supporting your case and schedule an appt. with the regional warranty guy. Good luck. |
10-08-2009, 03:15 AM | #12 | |
Rep 1,432
2 BMWs in 2 years that was fucked for me. 335 sold within 1 year because of wastegate issue that was not well done by the dealer. Had continual CEL lights and got rid of it. And now this. Is it just my luck or is BMW really focusing on cost cutting? I used to think BMW really had great after sales support and customer service. With this, I wont ever touch another BMW as long as BMW Asia and my dealer is in the picture. Ah heck, my dealer lost the M division anyway. Thats 1 down. Fucking incompetent.
10-08-2009, 03:19 AM | #13 | |
Rep 3,622
You would have an extremely hard time fighting BMW. Good luck going one on one with BMW, if they void your warranty. Whether you think you are right or not, you can't fight a giant company like that. Class action lawsuits are only thing that get BMW's attention. Not some random guy with a M3, that put a tune in his car. |
10-08-2009, 03:25 AM | #14 | |
8 tracks of madness
62
Rep 2,735
10-08-2009, 03:29 AM | #15 |
yodog
197
Rep 5,025
So should I be scared to bring my car into the dealer since I got a ECU tune?
10-08-2009, 03:44 AM | #17 |
Rep 2,097
No they dont check for regular maintenance nor do they care. And unless you have a problem they cant void it just cause they're bored. But if you do have a problem flash it back by the same guy that flashed your car before taking it in no big deal.
10-08-2009, 03:44 AM | #18 |
Rep 3,157
I bring it back all the time! But I have GIAC flash and I think they only raise the rev by 50-100 something like that.
Past: Gintani stage3 M3, Cayman GTS present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW |
10-08-2009, 04:17 AM | #19 |
Rep 1,432
I can tell you that itself is grounds to deny warranty even if nothing related to that is found. They will try to void whatever they can it seems. And no shit luck if BMW Asia happens to be the one to see your car. More often than not, look out for this guy Ralf Beck from BMW Asia. If he is the one looking at your car, you might as well try to solve it yourself. HONESTLY.
2018 F80 LCI II ZCP ///M3 Mineral White M-DCT| Sakhir Orange Interior| |M Performance Exhaust| Last edited by satinghostrider; 10-15-2009 at 01:08 AM.. |
10-08-2009, 04:19 AM | #20 |
Rep 4,381
I don't see the problem...you messed with the cars ECU, you now have an engine problem and BMW aren't prepared to fix it or continue giving you a warranty on it..sounds perfectly normal.
10-08-2009, 04:24 AM | #21 |
Rep 1,432
That's fine. But I don't see how voiding the drivetrain warranty had anything to do with the ECU. I don't have problems on the drivetrain and my dealer once screwed the job up by changing the wrong oil. I am more worried abt that part of the car later down the road if anything. As for the engine, I am fixing that at my cost. Essentially it's the drivetrain and the engine that makes the car. Some may argue it's related of course.
10-08-2009, 05:40 AM | #22 |
Just call me J.J. McClure
156
Rep 2,834
+1
MODS: Meisterschaft GT Racing Exhaust / BMC Air Filter / UUC SSK & DSSR (Modded)/ RPI Scoops / Passport SRX Hardwired / Custom Wrap 3M Clearbra / 20% Tint / 50% Windshield Tint / Key Hole Delete / Matted Out Accessories / VRS Type II Diffuser / Smoked Reflectors / Euphoria 6K LED Interior Lights / Rear Fog Light Mod / 6000K HID's / 6500K LUX H8 Angel Eyes / RDash License Plate LED Kit / LED Xenon Reverse Lights
"M3 drivers have no friends" |
