BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 Marketplace > SPONSORS Classifieds/Groupbuys/Specials Area > Suspension | Brakes | Chassis | Handling
European Auto Source (EAS)
      10-14-2009, 07:11 AM   #1
THEGERMAN
THEGERMAN's Avatar
Drives: 2009 BMW M3 Coupe, 6-Speed
6000km and breaks squeek
So I got about 6k km on my car and when I break and am about to stop my breaks squeek. Is that normal or are my break already gone bad and need to be replaced. Come on. only after 6k?
---Street-Racing is not a crime---
      10-14-2009, 08:35 AM   #2
jblaze
Drives: 05 range rover vogue SE
i live in france, on a mountain, beautiful twisites and roads, but all of my cars have had this horrible sound, its a matter of the dust, dirt and whatnot getting on the pads/disc or a combination(dont quote me as expert though). i think youll find that if its the case ur car is fine and happens to alot of people
      10-14-2009, 08:36 AM   #3
kmac1980
Drives: '19 540xi
check your manual... these brakes squeak/squeal under normal operation. nothing to worry about
      10-14-2009, 10:41 AM   #4
swiss_cornholio
swiss_cornholio's Avatar
Drives: E92 DTC M3 (AW/PS)
The standard pads should last for >10'000km (when not used on a track). And they never sqeak. Check the thickness of the pads.
      10-14-2009, 10:45 AM   #5
kmac1980
Drives: '19 540xi
not true, read your manual
      10-14-2009, 11:26 AM   #6
SUB-ZERO
SUB-ZERO's Avatar
294
Drives: 2018 M2 + Spur, DB11, F12, X5
Use a pressure washer to clean your wheels/rotors/calipers. I think it may be because of brake dust.
      10-14-2009, 02:04 PM   #7
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000 TT3
You probably have something on the rotor or the pad causing the squeak. Perform a pad bedding process and the noise should go away.
King Tut
2012 BMW M3 Individual: Sold lsb.ridedomain.com
1987 BMW 325is SpecE30: spece30.ridedomain.com
2009 BMW M3 Coupe: Sold e92.ridedomain.com
      10-14-2009, 02:15 PM   #8
gr8000
gr8000's Avatar
Greece
72
Drives: E92 M3 - DCT
I have tracked my M3 twise, I am otherwise not giving an easy time on the M3 and I have 26,000km. No indication in iDrive that I need new pads.
I think one can "reasonably" expect pads to last close to 30,000km. 10,000km is too low (by ">10,000km" I guess you don't mean anything above 10,000km, eg 100,000km!).
To the OP: IT IS NORMAL, IT IS IN THE MANUAL!
      10-14-2009, 03:50 PM   #9
swiss_cornholio
From my experience:
standard pads: 20'000km when used off track
performance pads: <=10'000km when used on track; to be precise: this April I bought new performance pads, in September after about 8'000km including 90 laps on the nurburg ring I had to replace the front pads.
      10-14-2009, 08:26 PM   #10
VanM3Lover
VanM3Lover's Avatar
20
Drives: 4.0 V8
Yes, It's normal.
It only squeeks when you're just about to stop, while applying the break lightly.
I can also reproduce the squeek by breaking lightly while turning either to the right or left slowly.
      10-14-2009, 08:31 PM   #11
VanM3Lover
VanM3Lover's Avatar
20
Drives: 4.0 V8
>10,000km is a piece of cake. I already have 13,000km and my iDrive shows front 47,000km and rear 50,000km until the breaks need to be changed. I never tracked and always braked gently.
      10-14-2009, 10:44 PM   #12
r53s65e90
8300
r53s65e90's Avatar
Drives: r53 s65e90
Brake squeal is normal. Pads when installed are coated with anti-squeal compound (a.k.a. plastilube) where there is metal to metal contact with the caliper. But plastilube is not a guarantee in general and can come off I suspect. I changed front pads recently and they squeal more than the old ones, probably because anti-squeal compound was not applied in the best way.
Your front/rear pads new measure 20.3mm/17.3mm in compound thickness. Unless they are at less then 3-5mm they should not need changing for normal street use. iDrive is not accurate at all from what I can tell by looking at the pads.
As far as break life is concerned, you can easily expect 30000 miles when driven normally on the street. If driven like an M3 should you would expect shorter life. For example: 280min @ Laguna Seca, 160min @ infineon (half on wet) some 200mi of spirited santa cruz mountains, rest normal driving = 7500mi fronts and 9700mi rears.
m3post
