New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      10-26-2009, 02:33 PM   #1
MilitaryE89
Drives: 2008 328i, 2009 sDrive30i
That "normal" knocking sound when shutting off the engine...
Am I alone in my concern over this? I mean, I know basically why this happens...counter-weights rotating in different directions kinda clattering together, but man, it just sounds rough. It kinda sounds like junk when you shut if off and all this noise comes from the engine...kinda embarrassing when people turn and cock their heads at why a car like this makes that noise. Essentially, what I am getting at is whether or not I am alone with the noisy car? Anyone else experience this and perhaps taken it in to have it examined? This is on a 30i...don't know if the 35i is plagued with this but I would assume so
      10-27-2009, 01:10 AM   #2
Otago
Drives: 09 Z4 sDrive 30i manual
I am manual 30i owner, no such sound you mentioned when turn off the engine.
      10-27-2009, 04:23 AM   #3
Joey_T
That's me...
Joey_T's Avatar
17
Drives: 135i
Put the clutch in when you shut the engine off and the noise will go away...
      10-27-2009, 02:42 PM   #4
MilitaryE89
well hell...thanks Joey T...never would have figured that out, as simple as it was.
      10-28-2009, 02:44 AM   #5
Joey_T
That's me...
Joey_T's Avatar
17
Drives: 135i
      10-28-2009, 05:05 PM   #6
Z4 Beemer
Z4 Beemer's Avatar
Scotland
85
Drives: 2009 Z4 sDrive 23i
2006 E92  [0.00]
2004 Z4 2.2i  [8.00]
Must try that, as I noticed mine makes a bit of a clunk when you press the STOP button.
E89 Z4 sDrive 23i... for the more discerning driver
      10-28-2009, 05:41 PM   #7
VM1
Italy
Drives: Z4 3.0 (2009)
Angry
I have the same problem, with 3.0
      10-28-2009, 11:28 PM   #8
GT Sounds
Drives: Z4
Like others, when I turn my car off, I'm pressing on the clutch while I'm putting the car into first and turning on the e-break before pressing the start/stop button. Never heard a knocking noise from the engine.
      10-29-2009, 07:49 AM   #9
Roadstergal
Roadstergal's Avatar
Drives: 2010 Z4 35i
Of course you are going to hear clunking if you turn off the car while in gear. You would get the same noise if you stalled out or stopped at a light without engaging the clutch or throwing it in neutral.
      10-29-2009, 11:31 AM   #10
MilitaryE89
the "clunk" is heard if you are in neutral (manual trans) and shut the engine off without depressing the clutch. its more of a heavy object rattle. Never was one to put the car in gear when i shut it off. just seems to me that it is putting additional stress on the trans, however minimal, that i don't need since everything is flat right around where i live. but as for my rattle...depressing the clutch definitly does the trick to eleminate it!
zpost
