11-05-2009, 07:07 PM | #1 |
Rep 181
HPFP
My HPFP went bad so it will be replaced and it only had 199 miles on the car. Just an fyi. It sounded like a humm or whine from the back driver's seat as others described.
11-05-2009, 09:06 PM | #2 |
Rep 276
I had mine replaced 2 weeks ago at 7K miles.
2020 BMW M340i xdrive
2016 BMW M4 (sold) 2015 BMW M4 (sold) 2014 Audi RS5 (sold) 2012 Audi TT RS (sold) |
11-05-2009, 10:11 PM | #3 | |
Rep 2,087
Dinan indicates that BMWs on board diagnostic software previously didn't issue a high presure vs low presure pump failure code. Due to all the known issues with the HPFP, dealership mechanics sometimes automatically replaced the HPFP but found out afterwards it was the tank pump. Clients had to go back for a "2nd pump replacement". Now BMWs has updated their on board diagnostic software to send a trouble code indicating which pump is bad. If you don't hear the humm anymore, it's likely they replaced the one in the tank. Last edited by teagueAMX; 11-06-2009 at 10:58 AM.. |
11-06-2009, 08:02 AM | #5 |
Rep 265
5500 miles and mine went. Took FOREVER to start and wouldn't idle. Then the next day it ran fine. Talking to others with this same engine/HPFP it's common.
Apparently the seals get eaten by ethanol in gas, so if you can avoid it you might consider doing so.
Current: 14 X1 35i - M Sport - Ultimate pkg - Mineral Gray ext / Black & brushed aluminum int.
Prev: 09 Z4 35i Black w/white napa leather & every option possible =) |
11-06-2009, 09:07 AM | #6 | |
Rep 2,087
Damn - seems to me all the gas in California has it. |
11-06-2009, 09:51 AM | #8 | |
Rep 181
How often does the rear pump fail versus the HPFP? This my first bmw, my previous car is a dodge viper gts and s2000 and they both had no problems of this nature. Thanks for stating its the one in the tank. I didn't hear the noise when I first picked up the car from the dealer (it was a bit less than 1/2 full). I also heard (within threads of this forum) that a full gas tank will produce a more whine/hum, versus a lower fuel tank. If so, that would explain why I didn't notice the noise when I originally picked the car up. I still have quite a bit of fuel, 3/4th's full, and I'm going to attempt to run it down and see if the sound disappears. And if it does, is this normal? I honestly can live with the hum/whine as long as its as intended. If not, they need to fix it. My appointment is on the 18th of this month. I had three techs check it out and they all state they can hear it. They even pulled in another Z4 next to mine to compare noises and the head tech said "yep, there's definitely a difference in the noise". -Chuck |
11-06-2009, 11:31 AM | #9 | |
Rep 2,087
I don't have information on how often they go out, but after reading a few very long threads on the e90post forum it's clearly a problem. The e89 Z4 (2009-2010) 35i have the same twin turbo n54 engine the BMW 335i uses which have been plagued by this problem for some time. BMW extended their HPFP fuel pump warranties to 120,000 miles. Even though BMW indicates they have a new HPFP design it doesn't seem to have helped considering that newer cars are still having the problem. A number of cars are using direct injection fuel systems these days so one has to wonder why BMW can't seem to get this problem corrected. BMW's new(er) 4.4 L v-8 design 1st used in the x6 50i has direct injection fuel systems and I haven't heard of this problem with their engines. Porsche's newer twin turbo have direct injection and to my knowelage no issue. Somebody else may heard something on it. As you stated the Viper and the Honda S2k haven't exhibited a premature failure scenario, either. BMW - what gives? Conventional advice for in-tank fuel pumps is try not letting your fuel levels drop below 1/4 tank as the pump needs to be submerged in fuel to stay cool and to last a long time (typ 80-100,000 miles). But if the problem as JeF4y pointed out, the ethanol blend is attacking the pump seals, there really isn't much you can do. If that's the case, it should be a no brainer to fix because ethanol based fuels ain't exactly new tek. The sound from the pump and the 1/2 vs full tank scenario seems counter intuitive to me. I would have expected the higher fuel levels to dampen the sound rather than enhance it, and the 1/4-1/2 full tanks to be louder due to a sound resonance in the tank, but oh well, you learn something new everyday. Cheers, FWIW and I hope it helps. Last edited by teagueAMX; 11-06-2009 at 01:29 PM.. |
11-06-2009, 11:54 AM | #10 |
Rep 181
01-01-2010, 09:38 PM | #14 |
Rep 1,162
HPFP failure is happening in every BMW line that uses the TT 3L engine. I don't have the numbers in terms of percentage but if you go to the bimmerfest 3 series board you will see lots of posts about HPFP failure. Unfortunately this will likely be the case with the Z4 as well. BMW has changed suppliers of HPFPs at least once and maybe twice. However, it seems even the latest FPs are subject to failure. Whether or not the cause is ethanol is still being debated.
Colonel (Retired), US Army/Hagerstown, MD
2016 518ixdrive/MSport AW/Ivory White ED-01-10 2010 Z4s30i AW/Beige/Burl/ 6MT/SP/PP/CWP/NAV/ipod/USB/CA (retired) 2011 335d BS/Oyster/PP/CWP/NAV/ipod/USB(Daily Driver) 30+ mpg(retired) |
01-01-2010, 10:54 PM | #16 |
Rep 362
the "ethanol" issue for the hpfp has been disproven. even if 100%, you could not destroy the seals in < 200 miles. bmw has been using these pumps for years, redesigned about 5 times and changed suppliers as well. if it were as simple as ethanol content, it would have been fixed many years ago as that is something extremely easy to design for, test, verify and produce.
01-01-2010, 11:11 PM | #17 | |
Rep 2,087
Only the Z4 35i, but other BMW models with the 3 liter twin turbo n54 engine have this problem as well.
Does anyone have an idea why the pumps are failing or what part of the pump is going bad? It's interesting there's a lot of discussion about the HPFP, but it sounds like based on reading posts here and elsewhere about a third of the pump replacements are are actually the rear in-tank pump. I talked to a mechanic who routinely repairs BMWs and he confirmed this, and said that the HPFP is often mistakenly replace the HPFP when in fact it's the rear pump. |
01-02-2010, 05:07 AM | #18 |
Rep 5,756
Drives: '24 iX50; '23 Audi RS etron GT
My HPFP was replaced on my '08 E92 335i at around 7k. Only indication of trouble was a few long cranks at start up. No problems afterwards and the warranty for the part was extended as previously mentioned.
'24-I20 iX 50; '23 RS etron GT; '23-G26 i4 M50*; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
01-02-2010, 11:31 AM | #19 | |
Rep 1,162
01-02-2010, 12:23 PM | #20 |
Rep 2,087
Your right, the pump in the tank is not a HPFP (note my lengthy post above), and I have read the rather extensive posts on this subject.
What he was saying is that the HPFP failure was occurring so frequently that mechanics automatically assumed the problem was a HPFP failure, and sometimes mistakenly replace it. They inadvertently ended up replacing both pumps, requiring longer shop time or in a few cases requiring the owner bringing the car back for another repair. It was happening often enough that BMW had to develop a code in the ECU to positively identify which pump was actually failing. The point is that the already infamous HPFPs reputation was made worse and owners further inconvenienced by poor diagnostic work. |
01-02-2010, 02:01 PM | #21 |
Rep 362
keep in mind though, like any car, the fuel pump (normal one in the gas tank) can fail like any other part of the car. for the normal pump to fail though, it would basically just be bad luck. i believe it has actually already happened to one member of this forum, but again, just bad luck.
01-02-2010, 04:23 PM | #22 |
Rep 236
I had the fuel pump replaced on my 335 twice.
That's one of the reasons why I went with the 30i Z4 instead of the 35i.
2007 e92 335i
Alpine white/black leather/aluminum trim Mods:aluminum pedals, 35% tint, carbon fiber roundels, painted side bumper reflectors, Hoen Xenon Match Angel Eye bulbs, 19' Axis Penta Wheels, Eibach Pro kit |
