12-05-2009, 03:57 AM | #1 |
Rep 4
Sport/Sport+ ?
Hi guys
I have owned a z4 35i for 3 months. Loves it so much. But what exactly does the car do when i switch from normal to sport? I can feel my steering get harder, the suspension is harder, i feel like there is more horse power too. Anyone has the exact information of what sport does ? |
12-05-2009, 05:48 AM | #2 |
Rep 176
Does exactly what you say above. Except, it doesn't give you more hp, it simply changes the throttle response so that it will feel more urgent/have more "get up and go".
It will also hold the gears longer (if you have an auto transmission), and possible make the gear changes faster. Other than that, that's it I think. Oh...."Sport+" mode will also turn down the traction control (you should see the appropriate symbol on your dash) and make the suspension stiffer still than "sport" mode |
12-05-2009, 08:01 AM | #3 | |
Rep 519
12-05-2009, 08:14 AM | #4 |
Ed
18
Rep 298
12-05-2009, 08:25 AM | #5 |
Rep 103
Sport+ turns off DSC, you can then turn off DTC by pressing the "traction" button right above the "norm/sport/sport+" button.....which basically means you are in total control of the car and can get "stupid" if you like
(look at page 65 to 67 in the US manual) |
12-05-2009, 09:20 AM | #6 |
Rep 1,264
Drives: 2010 Dinan S3 Z4-35i
Thanks for clarifying that as I wasn't sure why they had the traction control button when I thought putting it in sport + does the same thing?
2015 BMW i3 REX
12-05-2009, 10:34 AM | #8 | |
Rep 2,602
Note for the OP no one has mentioned that for suspension differences in Sport or Sport+, you must have the adjustable suspension, which only comes with the sport package in the U.S (both 3.0 and 3.5). The throttle response and steering changes are standard across the board.
2020 X3M non-comp, Alpine White over black : Exec Pkg, ventilated M Sport seats, 20"s
2020 M2 Comp, Sunset Orange/Blk: Orange stitching, DCT, exec pkg, bicolor rims Gone '18 M550i, '16 X4 M40i, '15 M5, '13 X3 35i, '12 335is, '11 X5 50i, '09 Z4 35i, '08 550i, 06 X3, 06 650i, '02 M5, '99 540i |
12-05-2009, 11:05 AM | #9 | |
Ed
18
Rep 298
In the Dutch manual, SPORT+ has a limited stability control and dynamic traction control is active. |
12-05-2009, 11:52 AM | #10 |
Rep 188
i love how the stability control thing is always debated...is it on? oh, no wait...it says its on when i hit sport+, so is it always off...does it even exist? lol, people are funny...by the way, I saw a dude driving an SLK in Munich today! It isnt just a myth!...yep, my bets are that he had rainbow underwear...
12-05-2009, 01:12 PM | #11 | |
Rep 1,838
12-05-2009, 06:53 PM | #12 |
Rep 362
for automatics, it also keeps it in a lower gear, imho, too long. for instance, lets say you are doing a steady 65. in normal mode you'll be in 6th gear, in sport/sport+ you'll be in 5th. even if you put the car on cruise control, the transmission will stay in 5th gear for sport/sport+ and will keep it there. most cars "sport" mode recognize that you are holding at a steady mph (or on cruise) and will changes gears to a more fuel efficient gear after a period of time has elapsed. in the above example, bmw will keep it in 5th even after an hour of steady highway driving in cruise control mode.
12-05-2009, 06:56 PM | #13 | |
Rep 519
12-05-2009, 07:18 PM | #14 |
Rep 2,602
With the DCT, the Sport button doesn't change shift speeds, only the sport mode on the DCT does. When I'm crusing in D7 and kick the lever left, it drops into S4 or S5.
12-05-2009, 08:01 PM | #15 | |
Rep 1,838
12-06-2009, 06:39 AM | #16 |
Rep 2,602
However I prefer manual mode so that I can be in top gear when cruising. I then anticipate a situation, downshift a gear or two, and I'm ready when I need the power. I do this on the commute into work. There is a steep hill on the inner loop around Charlotte. Most folks slow way down in the left lane, waiting for an opportunity to move right and exit. As they are moving over, I drop a couple of gears and can kick it back up to speed. As soon as I reach that speed, I upshift and am back to cruising mode.
12-07-2009, 05:43 PM | #17 | |
Rep 22
Once you're loose on a freeway, Sport Mode all the way as you can feel the handling tighten and the throttle reponse/acceleration definitely becomes improved. |
12-08-2009, 02:14 AM | #18 |
Rep 546
Sport+ only partially turns the traction off. It lets you slide but interferes and goes on when it senses that you are about to paint 8s and lose control. If you press the DSC button longer than 2 seconds regardless of mode (normal, sport, sport+) the traction gets completely off and you are totally on your own.
12-08-2009, 02:37 AM | #19 |
Rep 220
12-08-2009, 03:10 AM | #20 | |
Rep 157
Best regards Mick |
12-08-2009, 04:09 AM | #21 |
Rep 561
personally i do not agree. normal to sport+ is not very different i think. other cars have a more noticeable difference when putting the car in sport mode.
12-08-2009, 05:18 AM | #22 |
Rep 119
I suspect it also matters how long you have had the car, or how experienced you are with roadsters. When I first got my Z4 I couldn't really tell the difference between normal and Sport, having owned it for 4 months now I could probably spot it from the passenger seat... My driving has definitely modified.
You particularly appreciate 'sport' in a city of mad Balkan drivers where you never really get out of 3rd gear. Sometimes the only way to avoid the craziness is to put the foot down and leave them squabbling in your wake : ) |
