12-05-2009, 04:48 PM | #1 |
Just1MoreMod
354
Rep 712
FS: JB3 Tuning Tool/Boost Gauge
Description THIS IS THE PLUG-IN BOOST GAUGE / TUNING TOOL FOR THE JB3. DO YOU KNOW IF YOU'RE MAKING 8 LBS OF BOOST? 11? 16? PLUG THE BMS GAUGE DIRECTLY INTO THE JB3 AND KNOW HOW MUCH BOOST YOU'RE HITTING. CURIOUS HOW HOT OR COOL YOUR IAT IS, HIT A BUTTON AND FIND OUT. EVER WANTED TO EXPERIMENT WITH MAKING YOU'RE OWN CUSTOM MAP? THE BMS TUNING TOOL NOW GIVES YOU ACCESS TO MAP 15 (THE BLANK CUSTOM MAP) TO MAKE YOUR OWN UNIQUE MAP. MAKE A WEAKER MAP 1 IF YOU WANT, OR AN EVEN STRONGER RACE MAP. MAKE A LOW TORQUE/HIGH HP MAP, WHATEVER YOU WANT. INCREASE OR DECREASE THE AMOUNT OF "LAGFIX". ALL THE ADJUSTABLE SETTINGS ARE ON A SCALE FROM 1-15. ALWAYS KNOW WHAT MAP YOU'RE CURRENTLY ON BY A TOUCH OF A BUTTON. AND THE BEST PART, CHANGE FROM ONE MAP TO ANOTHER ON-THE-FLY WITHOUT TURNING OFF THE CAR AND COUNTING PEDAL PUMPS! The company website is: WWW.BURGERTUNING.COM Features/Specs: - DIRECT PLUG-IN DESIGN. (NO TAPPING OF LINES/VACUUM/BOOST) - CAN MOUNT ANYWHERE (SMALL ENOUGH TO VELCRO UNDER THE DASH TO HIDE FROM VIEW WHEN NOT NEEDED) - MEASURE CONSTANT VARIABLE BOOST ON THE FLY - RECALL LAST HIGHEST PEAK BOOST - MEASURE IAT (INTAKE AIR TEMPERATURE) - ACCESS TO BLANK MAP (MAP 15 FOR CUSTOM SETTINGS) - WORKS WITH JB3 VERSIONS 1.3 & 1.4 MSRP $ 279.00 + SHIPPING Selling for $189
Stage 3 - Pure Turbo F80 M3
Dinan Infested F48 X1 |
