01-08-2010, 04:26 PM | #1 |
Rep 924
Drives: Ford Falcon Ute, Ducati 1198S
Brembo BBK rubs on rear 19s
I just installed a set of 380mm Brembos on the M3 and they work fine with my VMR V713s.
I just tried to install some VB3 CSL-reps and the lower caliper bolt on the rear calipers rubs on the inside of the rim. Any ideas? Are there low-profile caliper bolts? Should I file the head of the bolt down the 2mm or so required for clearance?
BMW E92 M3 6MT, G-Power SKII supercharged, custom exhaust with 100 cell cats and Remus Sport mufflers, Brembo 380mm BBK, BMW Performance steering wheel, LUX H8 angel eyes, CF CSL boot, Hamann CF diffuser, Vorsteiner CF lip, CF grilles, CF gills, CF bonnet vents, BMW Performance stripes, RAC RG63 wheels, Eibach lowering springs, camber modifications.
01-08-2010, 05:26 PM | #3 |
Rep 924
Tried that but no luck...
Here is the mark: Here is the offending bolt (with rub mark where it hit the VMR VB3, a VMR 713 with 10mm spacer is currently fitted):
01-08-2010, 06:52 PM | #4 |
Rep 3,157
the smaller bolts are available just ask your shop.
Past: Gintani stage3 M3, Cayman GTS present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW |
11-07-2011, 11:25 PM | #6 |
Rep 1,105
This does not make sense. You spend thousands on a BBK and have an m3 yet you put ultra cheap VMR wheels on? A whole set is like 900 bucks and I had them on older bmw's that were not driven hard but I take it you go to the track if you are putting a BBK it and you are really taking a chance with a 900 dollar set of wheels.
11-08-2011, 12:12 AM | #7 | |
Rep 3,293
You're also a hypocrite, you drive a relatively expensive vehicle (M3) yet have a 2 cent attitude. Sorry I couldn't be of help OP, not my area of expertise. |
11-08-2011, 12:53 AM | #8 |
11818
Rep 23,187
how did you get the wheel on without noticing there wasnt clearance?
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
