01-13-2010, 07:23 PM | #1 |
Rocky
413
Rep 3,085
Has anyone lowered just the front?
Hello, I have considered lowering only the front because I believe the rear is low enough for my tastes. So has anyone only lowered the front? Thanks in advance. Urban Legend out!
22 Audi RS E-Tron GT
21 Model S Plaid |
01-13-2010, 07:35 PM | #2 |
Rep 5,069
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Garage List 2009 Porsche 911 997.2 [10.00]
2019 Hyundai N (Sold) [10.00] 2013 BMW M3 (Sold) [10.00] 2011 1M Coupe (Sold) [8.78] 2008 E90 M3 (Sold) [8.60] 2007 Z4 Mcpe (Sold) [9.50] 2005 BMW M3 (Sold) [10.00] |
I actually did that on my E36. E46 was left at stock heght. With the sedan it might not be a bad idea, if you have 4 people and a trunk full of luggage, the back can seem a bit too low. Currently lowered on Dinan f&r, might consider what you are mentioning on this car.
01-13-2010, 08:41 PM | #3 |
Rep 3,833
Get some coils and you can adjust it to what you like, but if you don't do it properly, you will upset the front to rear balance of the car.
01-13-2010, 09:35 PM | #4 |
CMPULSV
20
Rep 359
I was thinking the exact same thing...I like the rear stance, but feel the front needs to come down. I actually have a set of H&R Sport spings in the box sitting here...just not sure I want the back down as far as those will take it. Will be interested in seeing if anyone else has any ideas on just lowering the front.
2009 Alpine White DCT E92 M3 - Tint, Hood M Stripes, Eibach Springs,
Gloss Black Rims, Vorsteiner Lip, BMW Performance Trunk Spoiler Fabspeed x-pipe & Megan Race Exhaust 2006 Imola Red 6-speed E46 M3 - Retired |
01-14-2010, 04:29 AM | #5 |
yodog
197
Rep 5,025
I would do Eibach
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
01-14-2010, 07:02 AM | #7 |
Rocky
413
Rep 3,085
Describe how so.
21 Model S Plaid |
01-14-2010, 07:02 AM | #8 |
Rocky
413
Rep 3,085
21 Model S Plaid |
01-14-2010, 10:10 AM | #11 |
Rep 3,833
You would be changing the weight distribution of the car by lowering just the front.
01-14-2010, 10:16 AM | #12 |
Rep 5,069
You definately will change the handling dynamics a bit with the slightly stiffer/lower springs up front, but not necessarily for the worse. There is no way that lowering your car just in the front by .5-.75" is going to make any significant weight distribution changes.
01-14-2010, 11:21 AM | #13 | |
Rocky
413
Rep 3,085
The front is where I have a very small issue with. I could always go Mustang shade tree mechanics and cut the front springs.
21 Model S Plaid |
01-14-2010, 01:47 PM | #14 |
Rep 2,339
The height might be similar to stock in the rear for Eibach but the spring rate might be different to ensure proper handling and balance of the car due to the changes in the front. There are so many variables that go into suspension design its borderline idiotic to try and mix and match different components from different manufacturers unless you have the ability to fully customize all the necessary parameters.
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
01-14-2010, 03:19 PM | #15 | |
Rocky
413
Rep 3,085
21 Model S Plaid |
01-14-2010, 03:24 PM | #16 |
Flying First Class
30
Rep 582
Remember that the cars front half is closer to the ground than the cars rear half.
The front fender gap appears larger because of the larger space cut inside between the top of the front tire and the fender allowing for suspension travel while the wheels are turned, for example. You can see this by viewing the car at stock height on a flat surface from a crouched position. You will see that the car as a whole is slightly angled downward toward the front. Conclusion: lowering just the front will give the car a significantly more downward "hot-rod" look. Correct me if I am wrong. These are just my observations. |
01-14-2010, 04:36 PM | #17 | |
Rep 3,833
Suspension tuning is complicated and everything must work in sync together.
