New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      02-23-2010, 08:20 AM   #1
SquireG
Drives: Z4-SDrive35i
HPFP Warranty Extension
Is it possible? Could it be? BMW heard us and did the right thing. Just got a letter from BMW advising that they are aware of issues with the HPFP on 2009 Z4 and get this, they are extending the emissions warranty to cover the HPFP for 10 years or 120,000.00 miles. Its a Festivus miracle.
P.S., my HPFP died after 1,500 miles.
      02-23-2010, 08:32 AM   #2
Vintage
Vintage's Avatar
Drives: BMW G80 (MT), 718 Spyder
Yes sir - I received my BMW Letter on this in the US mail yesterday!!! That still doesn't make me too happy as this problem could strand my wife. I guess there is just no making me happy - maybe they could fix the problem on future model years???
      02-23-2010, 09:34 AM   #3
alan64
alan64's Avatar
20
Drives: z4
i wonder if it will apply to canada? so far havent gotten anything about it
      02-23-2010, 12:15 PM   #4
deepseabluez
Drives: 2009 BMW Z4
Does the HPFP problem exist for both the 3.0 and 3.5? I ask because when we received the letter yesterday, the letter specifically stated that the 3.0 had the problem but didn't say anything about the 3.5
      02-23-2010, 12:47 PM   #5
Memphis1
Memphis1's Avatar
Drives: Z4 SDrive 35i
the letter is sent to N54 engine owners, the N54 is a 3.0 liter engine with twin turbos.
      02-23-2010, 12:48 PM   #6
SquireG
Aren't they both 3.0 engines? The 35i is a twin turbo. The letter also says that it applies to my vehicle and I have a 35i, so, I will keep the letter in my file and pull it out if needed in the future.
      02-23-2010, 12:55 PM   #7
Memphis1
Memphis1's Avatar
correct, i was just trying to explain that the letter refers to the N54 and not the N52, since they're both 3.0 liter engines, hence deepseabluez's confusion.
      02-23-2010, 05:22 PM   #8
rmorin49
rmorin49's Avatar
Drives: 11 335d/10 Z4 s30i
It is only the TT engine. The normally aspirated 3.0 does not have a HPFP like the TT version. I received the letter yesterday for the 09 335i that I traded in. This was one of several factors I considered when deciding to get a S30i. I don't think BMW has fully resolved this issue and expect to hear about more HPFPs failing as time goes on. This is a real shame. It's not a big deal as they are, of course, being replaced under warranty. But if you are in the middle of the Everglades or Death Valley and it fails it can be rather irritating. Good luck to all of you with the TT engine. I think the failure rate is rather low but if it happens to you it really is a bummer. Some think it is related to the fuel in the US, others say no way it is a manufacturing defect with the pump. Not sure BMW will ever tell us what it is or perhaps they don't know. I do know it is costing them a pretty penny to keep replacing these pumps. I know several 3 series owners that are on their 3rd or 4th pump. This is pathetic.
Colonel (Retired), US Army/Hagerstown, MD
2016 518ixdrive/MSport AW/Ivory White
ED-01-10 2010 Z4s30i AW/Beige/Burl/ 6MT/SP/PP/CWP/NAV/ipod/USB/CA (retired)
2011 335d BS/Oyster/PP/CWP/NAV/ipod/USB(Daily Driver) 30+ mpg(retired)
      02-23-2010, 06:50 PM   #9
Marc45
Drives: 2015 i8
Since it appears that there are folks here who have experienced the HPFP problem, would y'all mind describing the symptoms for us and if there was any warning before it crapped out?
I too don't want to be stranded somewhere if I could have had the thing fixed when it started acting up.
Cheers
      02-23-2010, 07:00 PM   #10
rmorin49
rmorin49's Avatar
Not first hand experience buit based on reading numerous posts from those that have experienced failure, it usually starts with longer cranking times, followed by stumbling and a check engine light with the engine going into "LIMP" mode. This will limit you to a speed of about 25 mph. Complete failure will result in the engine failing to run.
      02-23-2010, 07:15 PM   #11
solidgold
Drives: Z4 E89
Read from some of the Bimmer forum posts that you may also get high pitch whining noise while cruising between 40-70mph especially after gear shifts.
At low revs, it get less alot less responsive and the need to step on the pedal alot more to get the car moving. Understand there are 2 HPFP. The rear one is the most problematic.
Will be good if some of the folks who experienced a faulty HPFP shared their side of the story.
      02-23-2010, 07:30 PM   #12
Chuck76
Chuck76's Avatar
19
Drives: 2009 Z4 3.5i
I had the rear fuel pump making a whine noise on idle. From what I know the rear is not a HPFP. It started whining at idle, no check engine light, no limp mode, no lack of throttle response. I took it into BMW, and they did diagnose a problem with the rear and replaced it. I had around 500 miles new when this happened on my 09 35i
      02-23-2010, 07:35 PM   #13
rmorin49
rmorin49's Avatar
This was probably the internal fuel pump inside the fuel tank, the HPFP is in the engine compartment. I have not read that the HPFP is noisy, it just stops working.
      02-23-2010, 07:58 PM   #14
Rubber Ducky
Rubber Ducky's Avatar
47
Drives: 2020 M340i
2010 models? Does the warranty extension extend to the 2010? And has anyone heard of HPFP failures in the 2010? I haven't.
      02-23-2010, 11:03 PM   #15
teagueAMX
teagueAMX's Avatar
Drives: Some are road worthy
Cheers
As some have mentioned BMW cars w/ the N54 twin turbo engine with direct injection are experiencing premature fuel pump failure. These cars have two fuel pumps - one in the fuel tank behind the seat and a 2nd one mounted on the engine that increases the pressure of the first pump, hense the designation High Pressure Fuel Pump, or HPFP.
Surprisingly these fail at relatively low mileage. Normally, a fuel pump will last anywhere from 75,000 to 120,000 miles. BMW's N54 HPFP has been known to fail within 2000 miles for new cars. This is unique to BMW as other manufactures are using HPFP and not experienced this problem.
Although some speculate that it's a fuel additive related problem, logically that is highly unlikely. 1) As noted there is a fuel pump in the tank that uses the same fuel but they don't fail at anywhere near the same rate. 2) Fuel additives are not new but these pumps have been around a while, so making resistant seals would have been worked out long ago, 3) The same company makes other HPFS for BMW, and other manufactures, that aren't failing at the same rate. IMHO, it's design flaw that has something to do with how the pump itself is mounted on the N54 engine. The BMW X6 4.4 L v8 has Direct injection and uses a HPFP but isn't experiencing the same failure rate.
      02-24-2010, 08:12 AM   #16
SquireG
MY HPFP failed around 1,500 miles. Symptoms included long crank times (3 to 5 seconds) and then finally, check engine light. I did not experience a total failure. I was able to drive the vehicle normally to the dealer. It took them 2 days to fix the HPFP citing that they needed authorization from BMW (WTF)? So, in my case, there was a diagnostic code generated. Have 5,500 miles now and all seems okay so far.
      02-24-2010, 04:58 PM   #17
rmorin49
rmorin49's Avatar
Is your Z an '09 or an '10?
      02-24-2010, 11:12 PM   #18
flpnout
flpnout's Avatar
Drives: 2010 Dinan S3 Z4-35i
2010 E89 Z4  [7.83]
Did they send this letter to people that have had theirs replaced? So far I have close to 3k miles without this issue. I've been seeing so many with this issue happening. Although mine is a 2010 model, not sure if that makes a difference as I have yet to receive that letter.
2015 BMW i3 REX
      02-24-2010, 11:23 PM   #19
teagueAMX
teagueAMX's Avatar
They did this for the 3 series folks before.
      02-25-2010, 05:49 AM   #20
alan64
alan64's Avatar
20
Drives: z4
so are you saying it was the rear one or the front one?
      02-25-2010, 08:41 AM   #21
SquireG
I have a 2009. My hpfp failed after 1,500 miles. Symptoms were long crank times and then check engine light. HPFP I believe is in the engine compartment. I think the letter said that the warranty extension applies only to 2008 and 2009 models. I assume everyone who has a 2009 35i would get the letter and it would not be contingent on a prior failure. In the letter they cite a very low failure rate but in the interest of customer service....blah blah...they are extending the warranty. Clearly the failure rate is something more than "very low" or they wouldn't be doing this.
      02-25-2010, 08:54 AM   #22
teagueAMX
teagueAMX's Avatar
My sense is this BMW's way of saying we've dealt with this problem until they phase out the n54, the high tek engine of the year award winner. Given that BMW has already issued the extended warranty to n54 3 series owners, IHO they will issue it to 2010 and 2011 Z4 owners as well.
zpost
