02-27-2010, 06:35 PM | #1 |
Connoisseur of Velocity
10
Rep 140
Squeaking Stock Suspension???
Started the other night.....very faint squeak...squeak (sounds like a small parakeet or something) when I had the windows down and rode over an expansion joint on the highway. Several days later, now the sound is much louder (I can hear it with the windows up or down) and it seems to make the noise with every movement of the suspension....small bumps, big bumps, any undulation in the road.
What gives? The car has around 11,000 miles on it and starts squeaking already. The only changes made to the car thus far is a set of new rims (RAC Monolite RG63 - No Spacers) and the addition of a catback exhaust (Meisterschaft GT). Could it be the connections on the exhaust? Anybody else have their suspension start to squeak so soon? |
02-27-2010, 10:54 PM | #2 |
Rep 176
I have a similar prolem. mine only usually happens at mid speeds around 30-50 when I go over a row of road reflectors or an expansion joint. Kind of like a high rebound situation in the shock. its a metal clacking noise. One guy says the shock was bad but both sides do it. I have Dinan springs. The dealer says the shocks are fine and it could be because its stiffer now and the brake caliper is making the noise. Makes no sense to me. Thinking about putting coilovers on the car and dumping the stock suspension. The noise sucks.
02-28-2010, 02:08 PM | #5 |
Rep 2,874
Not long at all why? Apparently humor isn't appreciated, so you have two choices. Try and track it down yourself and use said spray, or go to the dealer and let them figure it out. The reality of the deal is that there are many parts on your car that connect/rub/squeak in some way and often all the dealer will do is lube them where they touch.
02-28-2010, 10:14 PM | #6 |
10
Rep 140
Part of me doesn't think it is the suspension, as I stated it may be the connections in the exhaust or the exhaust mounts themselves. I was attempting to see if anybody else had experienced squeaking from the chassis. Apparently, this not to common an issue, which leads me to back to the exhaust.
I have a decent sense of humor and laughed when I saw your reply. That was my way of ribbing you back. |
02-28-2010, 10:43 PM | #7 |
Rep 3,574
Only in turns of in general?
In turns my makes a click click click noise.. When driving hard core only, but the noise I describe is normal.
2015 Porsche 991.1 GT3 2015 F80 M3 -- Individual; Space Grey |
03-01-2010, 09:54 AM | #8 | |
Rep 2,874
03-02-2010, 07:52 AM | #9 |
Rep 2,665
Drives: Goggomobil
Very interesting observations. I recently had some alingnment done and since then at lower speed have been experiencing a very faint squeak. I thought I was hearing things but no it is always there. Don't know what caused it. By the way I have 17,000 km on a Nov '07 delivered car.
F86 X6///
03-02-2010, 10:01 AM | #10 |
Rep 1,339
I have been getting a faint squeak when the car/suspension is warm going over expansion joints. I first noticed in a parking garage with the driver's window down after ~14K. It hasn't squeaked since it has been cold. The dealer couldn't repeat the noise of course... I am twitchy about the suspension after an EDC failure 400 miles in after a f**ked up LoJack install (long story, no need to repeat)
If you have an update, I would love to hear it. |
03-07-2010, 12:56 PM | #11 |
10
Rep 140
No update. I went under the car yesterday and checked to make sure the exhaust connections were tight and weren't the issue. Everything looked good. As soon as everything warmed up on a drive, I could hear the squeaking again. Can't seem to isolate it, unless the exhaust connections are getting loose once they start to expand due to heat.
Very annoying little squeaks |
