03-17-2010, 12:01 PM | #1 |
Rep 561
Eisenmann Quad Tip Exhaust Fitting
Hi guys,
I am about to order this quad tip exhaust from Eisenmann. http://www.eisenmann-sportauspuff.de...e35i_225kW.php 4x76mm tips. I measured the rear bumper space, and its about 140mm, so the quad tips wont fit the standard bumper as far as I can tell. How would I go about fixing this problem? Anyone who installed this exhaust, what did you guys do? |
03-17-2010, 02:19 PM | #2 |
Rep 448
Installed the Quad tips on a 30, and had to cut the right side out to match the left side, see My Garage for pics, but having looked at a 35, you will need to widen both sides and may trim up a bit to the top of the raised portion. My cutouts are 21cm wide by 8 cm high [8.25" by 3.2"], hope this helps.
The dual 35 tips use the same mufflers as the Quad tips and a "Y" pipe to shrink them into 1 outlet |
03-17-2010, 10:14 PM | #3 |
Rep 2,588
godius - good decision on the Eisenmann; I solved this problem by not cutting the bumper and ordering the 2x90 mm Race Exhaust. i really like the 4x76 mm but I was scared to cut the bumper
03-18-2010, 10:23 AM | #4 | |
Rep 486
Drives: Tanzanite M4 2018
03-19-2010, 11:48 AM | #6 |
Rep 886
Godius, not to hijack but as long as you're talking exhaust.. have you seen/heard this?
http://e89.zpost.com/forums/showthread.php?t=363912 |
03-20-2010, 04:54 AM | #7 |
Rep 561
Sounds like a great plan. Any links, where can I order this diffuser? I found this one http://www.3ddesign.jp/english/product_aero_E89Z4.htm but im not sure if its competable wit the eisenmann exhaust. I could not find any measurements.
You guys who have already installed the Eisenmann, is it worth the money? I mean is there definite improvement in sound? Last edited by mrboon; 03-20-2010 at 06:30 AM.. |
03-20-2010, 08:24 AM | #8 |
Rep 1,499
Drives: 2010 BMW Z4 3.5i 6spd
The 3d Design rear diffuser is actually made directly for the Eisenmann exhaust. We actually had the Eisenmann exhaust installed, did all the measurements and 3d Design then use those dimensions to create the 3d diffuser.
So that piece will be 100% compatible with the Eisenmann quad. |
03-20-2010, 10:05 AM | #9 | |
Rep 2,588
03-24-2010, 08:34 AM | #11 |
Rep 432
Drives: Z4 E89
can we get other exhaust tips for this quad system
DTM Le Manns double walled slanted tips Perforated inserts inward rolled tips
