      03-30-2010, 01:00 PM   #1
romeo26
Drives: e30 325 (no lette)
powerbox and oil change...
i have a powerbox on my car, and my car is telling me ive got 600 more miles till my next oil change. its giving my service on sign when i start it up.
do i have to take out the powerbox before i take it to the dealer?
      03-30-2010, 01:41 PM   #2
RaceTime
Auto X'er
Drives: 2009 Space Gray 135i
"Powerbox"??? If it is a tune, absolutely take it out. It will be well worth it...
2009 135i SGM, Premium, Sports, Nav.
Dinan Stage 2 software, Injen intake, RR Oil Catch Can, H&R Pro-coilovers and springs, H&R front sway bar, Vorshlag camber plates, Vorshlag comp studs, BMW strut brace, BMW performance pedals, G-Force harneses, BMP tow hooks, Breyton GTS-R wheels with 255-35R18 (square set up) and custom axel back exhaust with muffler delete.
      03-30-2010, 02:54 PM   #3
SV Concepts III
Drives: BMW Duh
You don't have to take it out but I recommend it.
      03-30-2010, 03:10 PM   #4
tgxmike
tgxmike's Avatar
Drives: '21 M2C 6MT, '21 Charger Scat
2021 BMW M2  [0.00]
Just take it out. Some dealerships don't car, but most will try to void all your warranties if they find something like that. There is no reason they should be near the ECU for your first oil change, but I still would take it out.
Also how do you like the power box?? thinking about getting it for my car.
      03-30-2010, 04:59 PM   #5
Xyloft
Xyloft's Avatar
34
Drives: 2008 AW 128i
unless that are you doing a ECU firmware upgrade, which they may do depending on what they find out when they scope your car.
i say take it out, just to be careful
      04-05-2010, 10:02 AM   #6
supraking
supraking's Avatar
49
Drives: 128i Coupe 6MT
2009 128i Coupe  [0.00]
Couldn't you just get your oil change done somewhere else (you'd pay of course)? This is more a general question for everyone, but does BMW care if you get your service done with them or not? Will the service light go off when it detects fresh oil or do you still need to take it to the dealership to reset that?
      04-05-2010, 10:38 AM   #7
italiantank26
Drives: BMW 128i
2008 BMW 128i  [0.00]
Just put the map setting at 0. When on map 0, only way to detect pbx, the act of physically opening up and looking at your ecu. At least what I've heard from others.
P.S I have a pbx in my car, got inspected, left map at 0 and everything turned out fine
      04-08-2010, 08:33 PM   #8
janus77
Drives: 125i coupe
Sorry to Hijack, seems a good place to ask this.
I've had issues with my tacho needle going "spaz", reading weird and not showing correct revs.
Am taking in to the dealership next week.
I have an injen intake and also BMS powerbox.
I'm going to need to remove both, aren't i?
125i, stick shift, M pack w/ 18's, 225/255 Z1's, saphire black, BMW CF rear spoiler, black interior, Midnight tint, business nav, sunroof, Injen intake, H&R sways.
      04-08-2010, 09:59 PM   #9
wmj73
wmj73's Avatar
Australia
25
Drives: M2 Comp, 440i GC
2008   [0.00]
2020 BMW M2 Comp  [0.00]
I left my intake in when I first had to have the inspection done, they had no problems with it, got my SA to talk to them about it before I brought it in. Not sure about the PBX though
      05-14-2010, 03:42 PM   #10
M II
Drives:
Although you can just hope for you dealer to not notice, but that's not usually the case with most dealerships.
Remove it completely and make sure that you're on the stock map before taking it back in.
This way you can remove all variables which the dealer can use to fight against you.
1addicts
