04-12-2010, 11:43 AM | #1 |
BimmerPost Supporting Vendor
520
Rep 3,612
▀▄ eas | Macht Schnell - Competition Wheel Spacer kits for BMW
In order to give your BMW a much more aggressive stance while increasing handling, we offer our line of Macht Schnell Competition Spacer Kits.
Machined from 6061-T6 aerospace aluminum, these adapters are strong as well as lightweight to limit unsprung/reciprocating weight for maximum performance on or off the track. Spacer edges are also chamfered to allow for easy installation/removal if needed. After machining, the spacers are then anodized for additional strength, anti-corrosion & wear resistance. Here is a recent article in European car: -An additional online article in European car's Tech section: http://www.europeancarweb.com/tech/e...gineering.html -Macht Schnell spacer reference thread with photos and spec details: http://www.m3post.com/forums/showthr...schnell+spacer -Macht Schnell DIY on how to properly install spacers: http://www.m3post.com/forums/showthread.php?t=272915 A wider track stance increases lateral stability as well as giving your BMW a much more aggressive appearance after installation. Spacers also are used to correct wheel gap normally seen on otherwise stock suspension setups, pushing the wheels outward - filling the fenders. Included with our Competition Wheel Spacer Kits are a full set of extended lug bolts in black OEM finish. All wheel fasteners are hardened and tempered to strength class 10.9 or 10 according to DIN/ISO standard 898 and meet the statutory requirements of all countries - including the US. Competition Wheel Spacer kit Features: - Machined from 6061-T6 aerospace aluminum - Chamfered edges allows installation & removal quick and easy - Black anodized finish for additional strength and corrosion/wear resistance - Improve handling by reducing body roll with a wider wheel base - Included black extended-length corrosion-resistant wheel fasteners Macht Schnell - Competition Wheel Spacer kit for BMW - 03mm http://www.europeanautosource.com/pr...oducts_id=2197 Macht Schnell - Competition Wheel Spacer kit for BMW - 05mm http://www.europeanautosource.com/pr...oducts_id=2198 Macht Schnell - Competition Wheel Spacer kit for BMW - 10mm http://www.europeanautosource.com/pr...oducts_id=2199 Macht Schnell - Competition Wheel Spacer kit for BMW - 12mm http://www.europeanautosource.com/pr...oducts_id=2200 Macht Schnell - Competition Wheel Spacer kit for BMW - 15mm http://www.europeanautosource.com/pr...oducts_id=2201 Macht Schnell - Competition Wheel Spacer kit for BMW - 18mm http://www.europeanautosource.com/pr...oducts_id=2202 Models Supported: 2008+ 1-series 1992+ 3-series, including M3 (e36, e46, e90, e92) 2004+ 5-series, including M5 (e60) 2005+ 6-series, including M6 (e63, e64) 2004+ X3 (e83) 2000+ X5 (e53, e70) 2003+ Z4, including M-Roadster/Coupe (e85) 2001-2003 Z8 1996-2002 Z3, including M-Roadster/Coupe All sizes are currently in stock and available for immediate shipment. Last edited by brandon @ eas; 04-12-2010 at 11:58 AM.. |
05-02-2010, 12:13 PM | #6 |
8310
Rep 18,878
All sizes in stock and inquiries replied.
Thanks for choosing the best - orders will be shipped out first thing Monday morning.
05-20-2010, 10:58 AM | #11 |
Rep 55
I posted this in the Cosmetic forum but didn't get any responses.
For OEM 19's on stock suspension, I'm having trouble deciding between 18mm front/15mm rear, or 15F/12R. In some pics, the 18/15 looks flush, but in other pictures, it looks like it sticks out a bit past the top of the fender. On the other hand, in some pics the 15/12 looks flush, but in other pics, it looks not quite flush. What do you recommend? Thanks in advance. |
05-20-2010, 11:27 AM | #12 | |
257
Rep 4,048
http://www.m3post.com/forums/showthr...schnell+spacer I suggest going with 15mm-12mm mainly because that's just my preference, but 18-15mm is extremely flush and we've seen a number of forum members run with this as well. It's all up to you! |
05-20-2010, 03:38 PM | #13 | |
Rep 55
I am going to need new tires pretty soon, and will likely upsize with the Vreds, 255 and 275, so do you think I should for sure go with the 15/12? I've heard the Vreds are pretty square cornered, plus the upsize. |
05-28-2010, 03:11 PM | #14 | |
549
Rep 5,695
06-01-2010, 10:20 PM | #15 |
Rep 4,092
Drives: 21 X6MC
how much for 12mm shipped to 98101?
06-02-2010, 12:00 PM | #16 |
520
Rep 3,612
The price can be found here: http://www.europeanautosource.com/in...ath=67_203_394
If you are in CA, there will be tax added to the order. Shipping via UPS will generally run about $10 |
06-10-2010, 05:20 PM | #18 |
2875
Rep 11,374
best ones on the market!
