04-18-2010, 05:15 PM | #1 |
Rep 2,233
No ignition position 2?
The only way I can get my electric tire pump to work from the cigarette lighter is with the engine running. If I push the key in once, twice (acc. and radio on) I get nothing. Is there no ignition position 2 with a push button starter?
04-18-2010, 05:40 PM | #2 |
Rep 1,001
Ooh good question, I noticed this too. I was waiting for my wife in the car and wanted the fans to run while I was parked with the engine off, I couldn't figure out how to turn the accessories on, and I didn't see it in the manual.
04-18-2010, 06:17 PM | #3 |
Rep 5,627
Interesting. I just tried it on my '08 and it works as specified in the manual. With one press of the start button, the radio will operate, but the lighter will not. With a 2nd press - clutch pedal out so the motor doesn't start - the heater fan comes on and the lighter heats up and pops out. So there are clearly two ignition switch positions.
Maybe this has been changed for later years, but it works fine on mine. Tom |
04-19-2010, 06:34 AM | #5 |
Rep 3,547
At least on mine that works but not forever. I have tried running my tire pump this way and I can do one, maybe two tires, and then the outlet stops working. Hitting the start button again does not make it start working again. I guess BMW does not want to risk running the battery down or something. So I purchased a cigarette lighter socket with clips to go directly on the battery. I will keep it with the tire pump. Cost was about $7 from Amazon.
Jim
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09 |
04-19-2010, 08:44 AM | #6 | |
Rep 293
Drives: '21 M2C 6MT, '21 Charger Scat
04-19-2010, 08:52 AM | #7 | |
Rep 5,627
Tom |
04-19-2010, 09:01 AM | #8 |
Rep 1,001
This is my first BMW and first car with a starter button, and also the first auto I've had in over 10 years, so I just didn't know.
But I figured it out after reading your comment Tom K. With the auto you just put the key in and press the start button without your foot on the brake. Duh. |
04-19-2010, 02:04 PM | #9 | |
Rep 5,627
Since I haven't owned an automatic since a land yacht '73 Plymouth Fury, I'm always trying to remove the key in my wife's car prior to putting the selector lever into Park! Tom |
