05-08-2010, 11:29 AM | #1 |
Rep 1,624
VS Motorsports Introduction
Hi Guy,
Just wanted to introduce ourselves and our services to the members of Great Lakes. Many of you guys might know us and many of you may not. We have been working on and building BMWs and many other cars of a couple of years now. If there is anything you need done from the smallest as wheels being mounted to a full custom fabrication of a roll cage please feel to contact us. Be on the look out for our special pricing each month, and we are in the beginning stages of fabrication parts and will be offering many group buys and deals for our local members. Thanks again, Matt |
05-09-2010, 10:11 PM | #2 |
Rep 63
Welcome guys!
Folks, these guys are terrific. They did my brakes lines and pad installation prior to going to Autobahn last week. when you want a group buy on the 410 differential just let me know! ; ) Best of luck, Carson
E90 SSII // MT6 // Prem // Tech // Cold // PDC // Prem Sound // Black Interior // CF Trim // 19' // etc. // etc. // ED Delivery Date: 5.28.09 |
05-10-2010, 03:35 PM | #3 |
Rep 1,624
Thanks Carson! I actually just had a customer come in asking about the 4.10. We will check to see if we can work up a group by special! If we get something organized we will let you know as soon as it happens.
Thanks,Matt |
05-10-2010, 05:44 PM | #4 |
Rep 1,624
Here are some pictures of around the shop and services we offer.
Below is a picture of our mounter&balancer, and nitrogen machine. Picture of the waiting room. With lap tops and Tv. Picture of us welding a cage for a EVO VIII running in NASA Below is a picture of a track prepped e46 M3 car getting an alignment Here is our specials for the month of May. Special Rates for Mondays & Tuesdays Only $10.00 off Labor Rate NO MINIMUM HOURS REQUIRED! Standard Alignment $75.00 & Custom Alignments $90.00 Wednesday, Thursday, & Friday Rates: $125.00 Mount & Balance + Standard Alignment 10% off Labor (2 Hours Minimum) Engine: ** Need a part installed? VS Motorsports can perform all your install needs. We can perform a small install of an intake all the way to a full engine build to fulfill your every needs for your vehicle. VS offers the following installs and Engine build: Exhausts - Intakes - Shifters - Clutches - Flywheels - Headers - Downpipes - Turbo Chargers - Engine Swaps - Engine Builds (Pistons, Rods, Cams) - ECU Wiring - Electronic Tuning -and more** Full Build ** VS Motorsports has a vast amount of experience with building the finest performance vehicles to hit the track. Check out Full VS Evo Race Car, Evo Sponsor Race Car, and our E46 M3 Race Car. VS Offers the following in Build Services - Safety Inspection (NASA or SCCA) - Full Race Vehicle Preparation - Wheels/Tires ** Need your new rims and tires installed? Scared to have your rims scratched up and mangled? VS Motorsports has the best machines to prevent any damage to your wheels and tires. VS Motorsports uses Road Force Measurements System equipment for wheel balancing and we use an Automatic Swing-Arm Tire Changer with Patented Bead Press System for tire mounting. VS Motorsports can also provide you with the highest quality Rims and Tires for your needs. VS Offers the following Wheel & Tire Services: - Tire Mounting & Balancing - Wheel Alignment - Corner Balancing - Tire Rotation - Tire Repair - Suspension ** VS Motorsports can perform all your suspension needs. From a daily driven street setup, to a full out Race car setup for either the track or the street. VS Offers the following in Suspension services: - Springs - Sway Bars - Coilovers - Brake Upgrades Fabrication ** VS Motorsports can fabricate anything and everything you can imagine. VS Motorsports has the latest and greatest tools to fabricate intakes, roll cages, and any other accessory or part that you can imagine. Some of the VS Fabricating Services: - Custom Welding - Tube Bending - Also check us out at our blog www.vsmotorsportsinc.blogspot.com Last edited by VSmotorsports; 05-10-2010 at 05:51 PM.. |
