      05-18-2010, 09:45 AM   #1
ulrichd
ulrichd's Avatar
Drives: 128i M-Sport
AFE 128 intake?
Came across this online but can't find it anywhere else not even on AFE's website? Sent an email to a few vendors but haven't heard back. Anyone have info?
      05-18-2010, 12:31 PM   #2
SV Concepts III
Drives: BMW Duh
It's the same intake for the E90 non-Turbo 6-cyl. We have it listed on our site for the E90s but it does work for the 128 since it's the name engine.
      05-18-2010, 02:58 PM   #3
ulrichd
ulrichd's Avatar
But will it fit under the hood and work with our engine layout? Since it was not listed on AFE's site my concern was that there was no specific application for us.
      05-18-2010, 09:37 PM   #4
YROF1
YROF1's Avatar
Drives: Black 128i
i ordered one at the beginning of may and was told it was on back order or somthing it is suppose to ship next monday so when i will hopefully be installing that weekend and will report back
      05-18-2010, 10:30 PM   #5
White1
White1's Avatar
Drives: 08 128i AW/Prem/PremAudio
I got the Injen intake from Vivid Racing, which is very simmilar...minust the top cover, and ive been quite pleased with it.Due to the open filter it does sound loud arround the 4k RPM, but the car feels way more lively at higher rpm than with the stock airbox.
Scream till you like it.
      05-19-2010, 08:59 AM   #6
ulrichd
ulrichd's Avatar
I was set to order the Injen but several people commented on the "drone" at certain rpm levels. I just want a little more growl while keeping it sounding like a BMW.
      05-19-2010, 11:40 AM   #7
M II
Drives:
Let me check with AFE on this one. I know with some of their other kits, the slightest difference in model had completely different mounting requirements and etc.
Will report back to you as soon as I confirm.
Intake resonance is what you're describing. Part of it has to do with how the Injen DCI was setup.
      05-19-2010, 02:24 PM   #8
ulrichd
ulrichd's Avatar
Thanks for checking.
      05-19-2010, 02:35 PM   #9
M II
Drives:
I just got a chance to discuss this with AFE and it turns out that it is the same part for both vehicles. However, there are two part numbers for: (1) Vehicles equipped with active steering - 54-11862 or (2) Vehicles without active steering - 51-11012.
      05-23-2010, 10:53 PM   #10
sb335is
Drives: fast
doesnt a drop in do the same thing
      05-24-2010, 01:20 PM   #11
SV Concepts III
Drives: BMW Duh
No this is a full intake replacement so it is less restrictive than the factory box.
      05-24-2010, 03:34 PM   #12
JimD
JimD's Avatar
369
Drives: 128i convertible
I think it probably is less restrictive but how much of that is due to the carbon filter built into the factory box would be interesting to know. In other words, how much hp/torque gain would be achieved if you took out the carbon filter and maybe dropped in a K&N or similar low restrictive filter. Probably not all the gain of a complete intake but less cost too.
Jim
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09
      05-24-2010, 05:29 PM   #13
M II
Drives:
Jim
The restrictions are taken out by smoothly taking out the bends and mandrel bending the intake pipe to increase flow. More CFM into the car is going to equal more power and torque.
      06-03-2010, 08:49 PM   #14
YROF1
YROF1's Avatar
Drives: Black 128i
put mine on today it was kinda difficult and you dont need to use the AFE bracket that supports the power steering fluid, but with that said take the bracket off when trying to install. I am not really certain but i think i have seen that you hav to break the intake in in order to achieve the maximum gains? This is my first intake, and I felt as though the car is slower? I dont know if that is possible or if I am imagining it because of the new loud sound I feel as though it should go faster if that makes any sense.... looking for input on if this is possible or if i installed something wrong.
      06-03-2010, 09:52 PM   #15
ulrichd
ulrichd's Avatar
"...that you hav to break the intake in in order to achieve the maximum gains."
Can you explain what you mean by that. Also some pics might help.
      06-03-2010, 11:30 PM   #16
YROF1
YROF1's Avatar
Drives: Black 128i
idk i saw somewhere on this form i think that you have to break in the intake like 500 miles or somthing...i think it has to do with the magflow sensor but iam not really sure it doesnt make sense to me...i will try to get some pics up tomorrow
      06-04-2010, 03:03 AM   #17
Yvette
Drives: M
if your butt dyno tells you feel slow...... I am done talking....
      06-04-2010, 12:54 PM   #18
ulrichd
ulrichd's Avatar
Sorry about that, I misread. I thought you said you have to break the intake.
      06-04-2010, 06:11 PM   #19
Blacky
Drives:
I am presuming by "breaking in" you mean letting the OBC recognize the change and adjust fuel air rates, ignition timing etc, this will maximize HP.
I am not sure but I think this can me helped by disconnecting the battery to rest the previous learning by the OBC. As I say I am not 100% sure about this bit.
      06-04-2010, 06:28 PM   #20
M II
Drives:
The ECU relearns the fuel trims - short term fuel trims (STFT) and long term fuel trims (LTFT).
This process can take 50 miles or it can take 300 miles to finish depending on driving style, altitude, load conditions, and etc.
Modern BMWs have thousands of sensors all of which pulls data to the ECU and compensates quickly and effectively. I've had to do this on my Evo before and same with my BMWs as well.
1addicts
