05-20-2010, 07:22 PM | #1 |
Rep 331
If BMW voids your warranty . . . .
If your 135's warranty is voided (whatever the reason), what is the best option to take up:
Would purchasing an aftermarket warranty company be attainable if miles are still under 50,000? What is your best solution if you are flat-out voided on powertrain basically? |
05-20-2010, 07:32 PM | #2 |
Rep 3,547
I do not understand the term "void the warranty". Do you mean they told you that you did a mofication and they will not cover the impact of the modification to the car? Regardless of what you do to your car, the manufacturer has no legal right to change the term of the warranty. If it is 4 years and 60,000 miles, then it stays for this period regardless. But if you put a chip on a turbo motor to increase boost and horsepower and you blow a head gasket, it would be reasonable for the dealer to claim that the added boost caused the blown gasket. But it would be unreasonable for him to claim that the boost caused a switch turning the lights on when you open the door to go bad. If a bearing went out in the transmission, it would be more grey but I would think you could successfully defend the improbability of that damage resulting from the modification.
Dealers can claim anything they want about the status of your warranty but courts do not typically view very favorably an attempt to dis-honor an obligation voluntarily entered into based upon a frivolous claim. On the other hand, the dealer would have a pretty good case if they could relate the damage to something you did. If your warranty has just expired, then you may be able to get extended coverage somewhere. But those deals are typically pretty bad deals for the car owner. Jim
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09 |
05-20-2010, 10:26 PM | #3 |
Rep 2,080
Well said JimD. People need to understand that you have to push back when a dealer says to you 'your warranty is voided because you have x/y/z after-market modification." The burden of proof is on the dealership to prove to the court/judge that the modification that was installed directly caused failure of a part.
All to often people hear the dealer says that they have voided their warranty and people don't push back. Many will say its not worth the hassle, but sometimes all it takes is a little push back.... I'm just saying..... |
05-21-2010, 01:10 PM | #5 |
Rep 1,609
I would do the following things:
Challenge their decision Try to take it to another dealer Learn how to fix it yourself if you can Sell your BMW for something else
7/08 135 Coupe, Crimson Red, 6 SP, Sport, Taupe Lette/Aluminum. Performance Mods: JB4 on Map 5, BMS DP Fix V3, Injen polished intake, AR Catless DP, Maddad resonated mid-pipes, aFe exhaust polished tips, ST Suspension Coil Over and Hotchkis front sway bar. Others: BMS OCC, BT Scanner, Mud Flap. Next Mods: AA Front Strut Brace.
05-21-2010, 01:44 PM | #6 | |
satch
39
Rep 1,040
"The federal minimum standards for full warranties are waived if the warrantor can show that the problem associated with a warranted consumer product was caused by damage while in the possession of the consumer, or by unreasonable use, including a failure to provide reasonable and necessary maintenance." This set precedence for courts to disallow warrantor claims that alteration (modding) of any particular part is sufficient cause in and of itself to deny coverage. A direct correlation between the alteration and the damage or failure, must be established. This also offers protection against the age old practice of a warrantor denying coverage if the consumer failed to replace a part with an OEM or OEM recommended part. Used to be that Magnavox would deny your TV warranty of you did not use a Magnavox vacuum tube.
"The Dingo ate your Mustang" |
05-21-2010, 02:26 PM | #7 |
Rep 331
Yeah my dealership is saying that if i take my intake off they would be willing to replace fuel pump and powertrain issues, otherwise they will deny and possibly void. I was just about to get an intercooler so now I am a little reluctant to do so even though it has zero effect on HPFP. I will try another dealer and see if they are more liberal.
05-21-2010, 02:39 PM | #8 |
European Editor
10633
Rep 22,992
Has anyone gotten this voided crap from someone who works for BMW NA? Like a regional service manager? BMW NA is the people you need to talk too... not some smuck in the service dept.
I use to work for a Volkswagen dealer in Washington DC area. We worked on about 150 cars per day! A big service department so say the least. You might get some SA(service advisor) to say that voided bs crap... or even a service manager... but when push comes to shove... the regional service manager from the manufacture will approve the work. They will cave in! It is simply cheaper for the car manafacture to FIX the car, then to fight it out in court! Even for stupid things that should not be covered "under warranty" or even a "good will" - the regional service manager (RSM) will approve the repairs. I can remember a few cases where it was silly stuff that we should have had teh customer pay for... but RSM told us "just fix it"! Case one). This guy drove his car for 48K miles. He NEVER changed his oil. It came in three quarts low on oil! And the engine only hold 4.3 quarts! The engine was ticking like you would not believe! it was low on power and in bad shape. It needed a new engine to the tune of $8K! but since the car was still under the powertrain warranty... and EVEN though two dealers had told him no proof of oil changes and no stamps in his maint book... no warranty!!! BUT.... our RSM approved the repair! The RSM told us... even though we are correct, in that the customer did not do ANY service to the car... other than put gas into the car... VW corperate would loose money trying to fight this in the courts. SO... VW paid us to repair the car under warranty. Case 2). We had a customer who drove the car until the timing belt broke. At that time VW called for a 60K mile change of the timing belt and rollers. The car had like 72K miles. When teh belt breaks you need a new cylinderhead and MAYBE an engine too! Pistons get damaged. Well... this car only needed a new head. It was several thousands as well. But VW ate the repair. Because.... they would have to provide experts in court... provide tests data from engines that were driven with NO maintance vs ones that got serviced. In the end... it is just cheaper for the car maker to eat the repair and call it: "Good Will". Now sometimes after the warranty period is over... the RSM would also cover repairs. That is the good flip side. This was mostly pro-rated, but miles out of warranty and time/months. But that is the good side of the car makers. So... I seriously doubt a dealer can void or even denie a warranty covered part. 1. Talk to the service manager. If that fails, arrange a meeting with the RSM from corperate HQ. Normally he comes once per month. 2. Read your warranty book! Go seek teh advice from a law firm that specializes in these things. Norammly a firmly worded letter to the Service dept AND to the corperate HQ - will make them shake in their boots - and cave in. 3. Stand your ground and do not buy into this "your warranty is voided BS". Good Luck, David |
05-21-2010, 07:59 PM | #9 | |
satch
39
Rep 1,040
If you believe in your case, a good attorney or consumer advocate could review it for you and if the concur, and if the prevailing party is entitled to recover resonable costs and legal expenses, I'd be all over it no hesitation.
05-21-2010, 08:15 PM | #10 |
European Editor
10633
Rep 22,992
One must DOCUMENT this BS. Every RO(repair order) is considered a legal document. IF you were ever to go to court... the RO's (front and back sides) would be evidence. This is why most SA's will write things like... "customer says..." and NOT "car does this..."
IF a dealer says they have voided your warranty... get that in writting on your RO! Then when you present your case to the RSM or worse... a court of law... you have a leg to stand on. I think my main point is this... the dealership or BMW NA must prove in a court of law that the mod caused the failure. NOT could have... or what ever.. BUT DID! And then BMW NA will have to provide evedence for their side. This all will cost way more than just fixing YOUR car. And I think in most cases the RSM would just fix your car under good will. I highly doubt BMW has a national data base with voided VINs/customer cars. I personally believe this vioded warranty talk is an urban legend. More likely it is a way for a dealership to blow problem customers out their dealership doors and put a little fear into their tuning car hearts. lol |
05-21-2010, 09:20 PM | #11 | |
satch
39
Rep 1,040
05-22-2010, 04:20 AM | #12 | |
European Editor
10633
Rep 22,992
I want to see some written PROOF that someone's warranty was voided. Not just told that by some SA! I still think this is all BS. No one can void your warranty. |
05-22-2010, 11:27 AM | #13 | |
Rep 331
05-22-2010, 02:20 PM | #14 | |
Rep 331
05-22-2010, 02:57 PM | #15 | |
Mbira
30
Rep 1,011
Drives: Sedonna Red 09 135i SOLD
05-22-2010, 08:12 PM | #16 | |
satch
39
Rep 1,040
2) Not asking BMW to warranty a part they did not make. Just asking BMW to PROVE the non BMW part in question CAUSED the malfunction of the BMW parts/system that failed rather than arbitrarily witholding coverage merely because the non BMW part is IN the system. A whole different scenario yet the most litigated.
05-22-2010, 08:55 PM | #17 |
Rep 2,040
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
Sbefar, I've discussed my case on here a few times. I have been modding my car for a while. When I went in for my first hpfp related evaluation the service department where I bought my car (funny enough United BMW where Dan works) recorded my suspension and drivetrain mods and it was entered into the database. The SA came off a little hard and liked to use the term voided warranty. He acted like they did me a favor to not charge me for that service visit.
I took it in stride knowing my rights and also knowing that you really may have to pay if you play. When the hpfp finally got where I was pretty sure it was on it's last leg I phoned BMW NA. They confirmed that my car was written up in the database so any dealer I'd go to would react the same. After minute or two and a mention of the known flawed hpfp and how I was sure that was not related to my mods and a court would agree then my call was referred to a higher person. This person set it up so that whenever I took my car in a national service person would check the car at no charge and we'd go from there. They treated me fine the whole way and did replace my hpfp at this second visit. Somehow it's also wrote up that my hpfp extended warranty is still intact. But my suspension and drivetrain are listed as modded in the database. I agree with others, it's really not a voided warranty, but for example if my turbos go out, it will be very hard to prove that my downpipes etc are not responsible so I'll probably have to pay. I'm not a big warranty/insurance type of person. It doesn't bother me and now I don't have to run around hiding my mods. It may cost me but I doubt it, as stated the warranty only covers you for 50k anyways. Still, if you can avoid being written up then you should do it.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
05-23-2010, 12:20 PM | #18 |
satch
39
Rep 1,040
Things must have changed at United if your story is based on recent experience. I bought my E46 from them in 2003 at thier Roswell location and continued to bring it to them for service for 5 years. Over those years the can became highly modded and they knew it. When I used to pull in back to the parts department all the parts guys and a couple techs would come out and shoot the shit about how much they liked what I had done. I went through a couple of recalls and TSB's with them and never a word from them.
This was before they started selling aftermarket stuff and I had to go to Global Imports for my Dinan stuff. But I had mods from a lot of the local shops and most of the usueal parts suspects (UUC AA Stoptech etc). But if they had tried anything I would have done what you had and let them know thet were not going to win the battle of innuendo and intimidation.
05-23-2010, 07:28 PM | #19 |
Rep 2,040
I'd actually assume a service tech could get in trouble with BMW if he just ignores mods. I don't mind at all as long as BMW does not try to get out of fixing a part that is obviously a manufacturers flaw.
05-24-2010, 12:49 PM | #21 | |
Mbira
30
Rep 1,011
You want to play...be prepared to pay |
05-24-2010, 10:50 PM | #22 |
Rep 331
if i have an intercooler installed and a cat back exhaust, and they are functioning properly, i cant see the logic or possibility of that causing engine issues, of course my dealer just might decline service repair anyways. I guess that's where u call up BMW NA and have the RSM take care of the issue.
