05-25-2010, 08:23 AM | #1 |
Rep 3,547
Rolling windows down with key fob
I have a non comfort access 2009 128i convertible. I got a mailer recently stateing that all recent BMWs will roll their windows down if you hold the open the door button on the remote. I've tried it several times without success.
Is this something you have to enable with the turn signal stalk programming? Is there some other "trick" I do not know about? I realize I can't put the top down this way because I do not have CA but the little brochure says I should be able to roll the windows down. It's warm enough in SC now that this would be a nice thing to do as I walk up to the car. Jim
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09 |
05-25-2010, 10:07 AM | #3 |
Rep 5,970
05-25-2010, 10:09 AM | #4 |
Lucky Lefty
Rep 746
Drives: on twisty roads
Garage List 2019 BMW M2 Comp [0.00]
2017 Porsche Macan GTS [8.00] 2011 M3 [10.00] 2013 bmw F25 msport [10.00] 2011 335iS [9.60] |
Yeah, what he says. Also, you can close the windows from outside by using the hidden L shaped key inside the key fob.
The Power of M |
05-25-2010, 10:09 AM | #5 |
Rep 4,528
Drives: M2 CS
05-25-2010, 10:42 AM | #6 |
Rep 3,547
Mostly I have just held the button down. I thought I tried unlocking and then re-pressing the button but I will try that again. I tried it again with my normal fob and no luck. I will also try the other fob. Thanks.
If all else fails, I will come up on a year and get a free oil change in less than 2 months. I would like to have this but probably not enough to make a separate trip to the dealer. I couldn't see anything definite in the manual, I looked, but the little thing that came in the mail seems to say it is all BMWs. Jim Last edited by JimD; 05-25-2010 at 02:49 PM.. |
05-25-2010, 11:24 AM | #7 | |
Rep 135
05-25-2010, 12:43 PM | #8 | |
Rep 5,970
Ahhh....you may be onto something there. There's definatly a difference in the way the coupe and covertable deal with the CA key fob, so maybe it won't work on the 'verts. |
05-25-2010, 01:14 PM | #9 |
All your 1 are belong to us!!!
20
Rep 658
There was a big thread on this a while back, and there were some bizarre conclusions about how the coupes and 'verts behave completely differently.
I think it was something like: Coupe (no CA): Windows can be rolled up and down with fob. Coupe (with CA): Holding fob buttons does nothing, windows can be opened/closed with the door handle ridges. 'Vert (no CA): S.O.L. 'Vert (with CA): Holding ridges does nothing, fob can be used to raise windows when top is up and windows are down, raise top and windows when both are down, and lower top and/or windows together when either/both are up. I expect that's not completely right, but the whole way that BMW chose to do this was pretty much nonsensical. Last edited by Angry3; 05-25-2010 at 01:19 PM.. |
05-25-2010, 03:45 PM | #10 | |
Rep 135
I agree, it makes so little sense...why decrease the functionality on the coupe w/ CA? Why not give the vert and coupe the same features? I don't understand it at all. |
05-25-2010, 04:28 PM | #11 | |
Rep 504
On my no comfort access coupe, i need to have both doors unlocked and be within a certain distance for this to work. it will also open the sunroof |
05-25-2010, 04:45 PM | #12 |
Rep 1,477
If you have a non-CA convertible, you need to get a SmartTop module. Very slick device for rolling up/down windows and raise/low the top with the remote. Search and you will find some threads.
05-25-2010, 05:12 PM | #13 | |
Rep 5,970
I have a coupe with CA, and you can roll the windows down using the key fob, and you can roll them back up by holding the locking surfaces on the door handles with your fingers. I'm not sure why the 'vert is different, but I don't think there's any difference between a coupe with CA and one without, except that the one without doesn't have the lock buttons on the door handles. On those cars, as mentioned above, you can use the emergency key and roll them up from outside by holding the door lock to the right. BMWs in the US have had that feature since before remote entry was standard, so that's probably why it's there. |
05-25-2010, 07:00 PM | #15 |
Rep 504
05-25-2010, 07:13 PM | #16 |
Rep 1,540
Drives: '14 EBII M235i & '06 R53 GP
Nope, sorry ... hit the UNLOCK button once to unlock the doors. Then press the UNLOCK button a SECOND time, and hold it down until the windows have rolled down and sunroof have opened. As said before this is for a coupe. CA or non CA. I have had both, it works with either.
05-25-2010, 09:28 PM | #17 | |
Rep 7,047
But, on the E46 I could use the fob to both open the windows AND close them. So, if you forgot to roll up a window, you don't have to use the key to close it. You simply hold the "lock" button, which locks the doors AND rolls up the windows and closes the sunroof. The 1 only rolls the windows down and opens the roof. But, now you can't roll the windows and roof closed. You have to use the key, as the poster above states. I asked a dealer tech, today, as we were doing a drive in my 135i, if he could program the system to allow closing the windows and roof with the fob, but he said they are no longer allowed to program this. Something about it being dangerous. I think I've read that this can be programmed in our cars, by a BMW dealer or someone with the OBD software and access. Anyone know for sure? I LOVED that feature in my 325i. With a sedan, it was really handy to be able to close the windows and roof and lock all the doors by holding 1 button. |
05-25-2010, 09:31 PM | #18 | |
Rep 7,047
I don't recall that you have to unlock the doors, release the button, then press it again. It should work by simply continually holding the unlock button. Hmmm...I'll have to check again to make sure, as I don't recall pressing, releasing, then pressing again. |
05-25-2010, 09:37 PM | #19 |
Rep 7,047
05-25-2010, 10:45 PM | #21 |
Rep 135
And yet somehow they manage to let you open and close the windows AND the top from the key on the vert w/ CA?
I could understand the logic behind it being dangerous, although I do think it's a sad statement concerning the US legal system. But they aren't even consistent with it. |
05-26-2010, 03:45 PM | #22 |
2010 135i Coupe, M Sport, Premium, Titanium Silver
Rep 17
I'm glad I read this thread. Came out to the carport the other morning and the windows were down and the sun roof open about a forth of the way. No way did I leave my car like this the night before. Must have been butt keying it.
