06-18-2010, 08:24 AM | #1 |
525
Rep 1,440
Eibachs not available for 2011 M's yet.....
As per Eibach themselves, their springs have yet to be tested on ANY 2011 M3's yet. I called simply because every vendor that sells them has a drop down for make/model/year and 2011 has not been available as of yet. They told me they have yet to test the 2011 M's but do plan to do so. There are supposedly several cars in line ahead of the M3 that are bigger revenue generators for them and they take precedence. I asked the tech this question specifically: "If the specs on the M3's havent changed from model year 2010 to model year 2011, is it safe to assume that I can use the springs currently offered for this car?" His answer was NO. They may or may not make adjustments to the specs of the springs for the 2011 models. He did say you certainly wont hurt your car at all but he will not officially condone the use of springs on a model year they have yet to test. The more requests they get to make the product available for 2011 models, the sooner they can justify testing it. Ive called several times to see if they've made any headway. They are very nice people. I ask that anyone with a 2011 M3 thinking about installing eibachs please call. They may just get it done sooner than later. Again, it may not be ANY material change from whats currently offered but I dont plan to purchase the springs until they officially offer them for 2011 cars. The number is 1-800-507-2338. They are in Corona, CA. Call them.
All the best
2022 Individual M5 Comp
Venetian Violet 2021 X6M Comp 2024 i4 M50 on order IG @purpleM5Comp_NY |
06-18-2010, 05:22 PM | #5 |
Rep 3,246
had one crappy iphone pic, doesnt really show the drop. having wheels put on among other things and should have back next week, post pics and all then.
06-18-2010, 05:29 PM | #7 |
Rep 1,203
Drives: 2021 M2C
They also need to test the springs on the comp pckg. I was going to buy a set but I'll hold off for now.
07-26-2010, 01:52 PM | #8 | |
Rep 112
07-26-2010, 02:05 PM | #9 |
Rep 246
If its a comp pck car i would not change the suspension. Personally im goinf to add the Dinan strut brace for looks and eventually upsize the back tires to 285/30/19. Comp pkg suspension is dialed in perfectly, i think any aftermarket spring is just gonna ruin the rise, wear out the shocks and struts and cause underbody damage.
07-26-2010, 02:44 PM | #10 | |
Rep 112
07-26-2010, 03:52 PM | #11 |
Rep 2,991
I have Eibachs on my 2011 e90 m3. I am actually pulling them, I know many people swear they are a "stock-like" ride, but they are a little floaty to me. I'll probably swap them out for the ZCP stuff later on.
07-26-2010, 05:06 PM | #12 |
Rep 1,653
i just ordered a set of Eibach springs for my 2011, it should be here this week and on my car in a few weeks.
2011 E92 Space Grey/black + Tech + Premi + Heated Seats
07-26-2010, 05:37 PM | #13 |
Rep 246
If you guys really wanna play with aftermarket spring kits....i suggest going with Dinan. They will cover your warranty which really would only be benificial if you had EDC.ZCP or not, thats the way i would go.I cant see Dinan's spring kit to be any better than ZCP other than a little bit more lowering in the front of the car.The rear you will not see any difference.
07-27-2010, 08:22 AM | #14 |
525
Rep 1,440
So Ive spoken to Eibach several times since this thread and the tech told me (off the record of course) that there will be no change to the springs for 2011 cars. I ordered mine.
07-27-2010, 05:33 PM | #15 |
Rep 246
Persoanlly if i was going to install lowering springs, i would just do Dinan just to be on safe side. But if you dont have EDC, then i guess it really wouldnt harm anything.
