      06-20-2010, 08:49 AM   #1
wolfe
wolfe's Avatar
135
Drives: e82 / e70 / r56 / r60
fuse/relay to let engine crank without starting?
I'm wondering if there is a specific fuse or relay that can be pulled which will allow me to crank the engine over without starting it?
Or, is this likely to cause a code to be thrown?
      06-20-2010, 09:45 AM   #2
HondaGoneRogue
They like my Swag...
HondaGoneRogue's Avatar
433
Drives: 15 GSM 435i GC
Are you trying to prime a system or something? We have DI. I'm not sure what you could pull, maybe the coilpacks?
2015 435i Gran Coupe - Current
2008 AW 135i - Sold
      06-20-2010, 09:46 AM   #3
HondaGoneRogue
433
Oops, 128.... my bad.
2008 AW 135i - Sold
      06-20-2010, 10:02 AM   #4
wolfe
wolfe's Avatar
135
I want to generate some oil pressure before the engine has started if it's not a huge hassle to do so.
      07-15-2010, 09:16 AM   #5
trabi
Drives: 128
Fuel pump fuse.
Is one that is not assigned on the legend, 20 Amp
      07-15-2010, 04:50 PM   #6
Evice
Evice's Avatar
194
Drives: E92M3
what do you really wanna achieve at the end?
      07-16-2010, 07:37 AM   #7
wolfe
wolfe's Avatar
135
After changing the oil, I want to spin the engine over without cranking it so it can fill the filter housing and build oil pressure.
It's probably splitting hairs in the extreme, but if it's a case of just pulling a fuse or relay it's worth it to me.
Thanks trabi, I'll check for that 20a fuse.
1addicts
