08-24-2010, 11:12 PM | #1 |
Rep 320
downpipes??
i just put my downpipes and i have notice that am wasting alot more gas is this normal or can it be that the fuel pump is getting mess up?? I already replace a new fuel pump??
Current- 2009 M-Sport 135i
SOLD-2008 135i(Jb4-15ohm-FSB)map 3 @ 19psi, Active Autowerke Charge Pipe with Dual meth nozzle cm5 & cm10, Active Autowerke Intercooler, AFE Intakes, Active Autowerke DP with RR Catback exhaust and KW V2 coilover. |
08-25-2010, 09:36 AM | #2 |
Rep 1,925
Drives: 2010 135i,1989 PRO3,2001 530i
you are probably driving faster! :->
135i coupe 6MT TiAg ///M sport http://www.rhominnovations.com www.musicarNW.com www.unitedBMWonline.com |
08-25-2010, 10:19 AM | #3 |
Rep 320
Am driving the same i shift at 2,000rpm what i have notice is that by 1,700rpm the turbos are spooling already? Maby is that?
08-25-2010, 10:44 AM | #5 |
Rep 320
using what??
08-25-2010, 11:28 AM | #7 |
689
Rep 6,854
DP's equal quicker spool. Quicker spool mean's less throttle, thus the same throttle movement from before actually means more. Also, your probably driving a bit more enthusiastically, you probably don't even realize it. Lastly did you replace the o2's? That will help mpg if your car is over a year old.
08-25-2010, 01:41 PM | #10 |
AKA HISSMAN
34
Rep 888
I am not sure what effect it has on these cars, but I know that a lot of turbo cars that I have tuned or been tuned can really richen up when being lugged around with a high load @ low RPMs. Ideally 2800-3000 rpms would be where I would shift one of these during normal driving. Like I said though, I have yet to datalog a N54 in the light chassis of the 1 series.
08-25-2010, 01:52 PM | #11 | |
Rep 3,177
08-25-2010, 05:09 PM | #13 |
Rep 320
Am getting 15.2mpg and am not a fast driver? this happend when i install the dp with out them i would get 21.2 mpg?
08-25-2010, 05:35 PM | #14 |
Rep 3,177
unless something went wrong with your install (damaged o2 sensor, etc.), you should be getting the same or better fuel mileage. try resetting your computer for mpg and start shifting at 3-4k rpms instead of 2k. if that doesn't work to increase your mpg, trouble shoot to see if something was damaged or incorrectly installed when the dp's went in.
08-25-2010, 05:40 PM | #15 |
Rep 5,689
Wow, why did you put dp's on if you shift at 2 lol
Seriously though, you probably either damaged a o2 or just have too much city factored in the new mpg estimate.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(1addicts.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
08-25-2010, 05:43 PM | #16 |
Rep 1,147
Drives: 02 E46M3 15 F80 M3 16 X5 35d
i'm getting better fuel milage with my downpipes. Not alot but better.
08-25-2010, 05:48 PM | #17 |
TwinTurbo Top Hat
22
Rep 252
Anyone know what the gains would be alone with just DP? Maybe done a before and after dyno and can post the results?
AW 2008 135i - Auto, Prem, with Sat Radio
BMW CCA # 417107 |
08-25-2010, 05:54 PM | #18 | ||
Rep 3,177
the gains of downpipes are best when you turn up the boost. you'll notice decent gains at stock boost levels (15-30 whp and tq), however. personally, i wouldn't go through the pain in the ass install, risk the emissions implications, or have dealership concerns if i was just going to run stock boost levels after the dp install. |
08-26-2010, 09:57 AM | #19 |
Rep 883
Aaaand... since we don't have those on this side of the pond... I got two words - Track Day!
'12 E92 M3 | 6MT | ZCP
08-26-2010, 06:41 PM | #21 |
Rep 320
I put on dp for the car can have a deeper tone and to gain hp I shift at low rpm for it wont wast gas!!!! And no o2 sensor got damage!!!!!
08-26-2010, 10:58 PM | #22 |
Rep 42
i'd like to change dp as well but it will void my 5 years free service + parts
so pretty much im stuck with stock for 5 years or so.... not to mention potentially hpfp failure.. dont really wanna void the free service+parts...... |
