ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      08-28-2010, 04:54 PM   #1
blender
Custom User Title
blender's Avatar
Drives: black
UPDATED: Noisy KW spring coils and loose KW spring perch - both fixed.
Hello All -
I'm passing along this advice/experience in the hopes that someone else may benefit from our discovery via long period of trial and error.
I had a recurring thunk/clunk coming from the left rear corner. It made a 'gronk' noise that was rather loud and very annoying. Easily replicated in a quiet parking lot at 10-15mph by first loading and then unloading the left rear corner. Even a small bump would do it.
I suspected worn bushings in the Rogue RSMs; bought a new set and replaced them. Noise abated for around 50 miles then returned. Both Rogue and KW were helpful and responsive on support questions but we could not find the cause.
I Went through much trial and error with my smart and very patient mechanic (Plug for Bruce Barthel, bmwmd.com). We inspected and verified torques on all the bolts of the rear end (frame, suspension, differential, exhaust, etc) but noise persisted. We eventually tracked the problem to the uppermost two coils of the KW spring rubbing together when loading/unloading that corner. The friction had worn through plastic outer coating of the KW spring, allowing the plastic/metal of the coils to bind/rub against one another, especially when that corner got unloaded.
Wrapping the individual coils of that spring with two layers of 3M electrical tape has so far totally eliminated the noise. Not sure yet about the long term reliability on the tape. It will probably last a while here in SoCal. I plan to replace the tape with a synthetic rubber coating product like Plasti-Dip, or some other permanent rubber tubing that I can slip over the coils.
Also, we noticed also that the KW threaded collar was loose enough to wobble slightly on the threaded perch post. This seems odd and not very "German" if you get my drift. We used two passes of plumber’s teflon tape to snug up the fit between the collar and the threaded post.
So far so good with both improvised repairs at 94 miles.
      08-29-2010, 03:31 PM   #2
silversprint
Drives: Z4M
Did you put the rubber OEM spring seat back in with the KW? Without that it will make noise.
MR-S Track -2100lbs/300hp
Miata
Z4M Coupe (Sold)
      08-29-2010, 09:24 PM   #3
blender
Custom User Title
blender's Avatar
Drives: black
Yup. The whole setup was quiet for the first three months before the plastic wore through.
      09-24-2010, 06:44 PM   #4
blender
Custom User Title
blender's Avatar
Drives: black
Revised my fix with spiral-cut 'coil flex' cable minder, 1/2" size. Goes easily around the next-to-bottom-most coil and eliminates coil binding/noise.
      02-01-2011, 10:35 PM   #5
blender
Custom User Title
blender's Avatar
Drives: black
Pic of coil wrapping, before & after, as req.
Someone requested this:
Note the KW-furnished plastic boot has already split. Not pleased with their material choice in that case.
Attachment 481200
      02-02-2011, 08:54 AM   #6
Beedub
Drives: 2007 Z4 M roadster vt2-500
i would have hoped KW would have sorted this by now, ive read about this complaint reguarly!!
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com
Tags
kw_v3, springs, suspension
zpost
