BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      08-30-2010, 12:27 AM   #1
M3Rolly
19"AlloyS iDrive TechColdWeatherPak MDM
Drives: 2008 M3 Alpine White Coupe 6MT
Rev-Matching for Up-Shifts?
Still learning the heel-toe downshift. I decided to try rev-matching for up-shifting. When i shift up into the next higher gear, for example from 1-2, 3-4, or 5-6, (i.e. 2-3; depress clutch pedal, lightly depressing the gas pedal to keep revs in 2-4k rpm range, shift from 2nd to 3rd gear while revs are still in the 2-4k rpm range, release clutch pedal) I'm not going WOT but these are techniques i am applying to my daily driving.
I notice that acceleration times are a lot quicker as opposed to regular up-shifting. Has anyone tried this approach? Does it cause wear to the clutch, synchros, tranny? Is this recommended? I thought I read somewhere that it might.
Thanks for your advice,
M3Rolly
      08-30-2010, 08:32 AM   #2
M3 Pilot
M3 Pilot's Avatar
Australia
74
Drives: 17' F80 M3 ZCP
I think you would be more mechanically friendly if you allow the revs to drop a couple of hundred rpm before getting back on the gas.
For quicker shifts, theres Flat shifting.
Basically you keep your throttle mash to the firewall while you clutch in, upshift and dump the clutch without lifting off the throttle.
Again, its not mechanically friendly. Unless it is a track car and you are chasing thousandth of a second.
2013 E92 M3 ZCP
2014 F06 M6 GC
2017 F80 M3 ZCP
      08-30-2010, 08:40 AM   #3
J08M3
J08M3's Avatar
Drives: 2011 M3 COUPE
You don't want to cut power totally to the engine in between shifts.
m3post
