08-31-2010, 01:40 PM | #1 |
Moderator / European Editor
1545
Rep 6,754
1M to use twin turbo N54 - or so tell these pictures
Following Bimmerfile's report and Scott's confirmation, I thought it might be worth to have another look at this picture M3roar brought up:
It's hard to see in this picture, but the 1M's exhaust system appears to have center cats in the mid section. Here's a better picture of this: Zooming into the center cats section (center cats section enhanced for more clarity): In case you guys are wondering why I'm stressing this, the same center cats in the midpipes appear on the N54 powered 135i (one on each exhaust pipe, marked with a red arrow each): The N55 powered 135i however doesn't have these center cats as you can see in these pictures, courtesy of black e (see here). Again, the red arrows show where the mid cats would be on the N54 powered 135i: Hence, I'd say it's not only safe to assume that Bimmerfile's correct on the N54 being used in the 1M, it's also safe to assume that there won't be any change to the turbo layout, i.e. it will keep the N54's (single scroll) bi-turbo. That being said, I have no idea what Scott could have meant then by saying the 1M engine would be a hybrid between N54 and N55. Any thoughts (or corrections for that matter)? Best regards, south
08-31-2010, 01:59 PM | #3 |
Rep 133
Didnt scott mention early on about a "trick manifold"??? this is the only place where i could see something new and cool in this engine. perhaps a 6-1-2 or 6-2 tubular equal length manifold of some sort? looking at pics of the N55 manifold, you can definitely see that its a mass production design...
08-31-2010, 02:07 PM | #4 |
aiming for 450.....
304
Rep 2,910
Is there a reason that the N55 doesn't have the second set of cats??
Quote from Ezeedee regarding car mods:
"you're only done when you sell the car " |
08-31-2010, 02:16 PM | #5 |
Rep 335
Did SCOTT specifically say it would be a 'hybrid' between the N54 and N55? I didn't remember he specified those two engines. Is a 'hybrid' between the N54 and something else possible?
08-31-2010, 02:18 PM | #6 | ||
Rep 188
Drives: 1M / M3 E36 3.2 6MT
I also tried to figure out what Scotts two posts about the engine/powertrain beeing a hybrid could mean:
Still trying to figure out how it's possible to feed the 4 intakes of 2 twin-scroll chargers from 6 cylinders ... |
08-31-2010, 02:19 PM | #7 | |
1545
Rep 6,754
Best regards, south
08-31-2010, 02:23 PM | #8 |
Rep 133
08-31-2010, 02:26 PM | #9 |
Rep 188
08-31-2010, 02:32 PM | #11 |
Rep 294
I did read a while back that BMW was working on a quad turbo 4cl. Could they have slapped more turbos on the 6 or maybe how about twin sequential, taking the turbo off the N55 and adding another (one N55 turbo on each side).
Z4M Coupe 6MT Monaco Blue #13/36 ...Keeper... Z4 3.0 6MT ...Keeper... 2OO2 5MT ...Keeper... 335i 6MT Montego Blue M-Sport (Retired),X535d Vermillion Red/Saddle (Retired) |
08-31-2010, 02:34 PM | #12 |
Rep 188
This Wikipedia article about Variable Geometry Turbochargers is worth reading. Especially the first section that mentions the problem of exhaust pressure at high rpm ...
08-31-2010, 02:36 PM | #13 |
Rep 3,262
The 1M will surely have a modified air intake compared to the regular N54, because the Z4 35is also has this in order to produce 340hp. But is this enough to use "hybrid" ? I don't think so...
08-31-2010, 02:37 PM | #14 |
Chemofski
54
Rep 1,295
I'm betting it's going to be a standard N54 single scroll, twin turbo, but with better cooling (larger center intercooler and maybe an additional engine bay one, plus an oil cooler), and a new special intake system like the one used on the X6M. Those changes in addition to the remapped software would likely net the ~345 hp that's been suggested. Right?
'13 Individual Frozen Brilliant White ///M3 Coupe
Ordered 2/15/12 | Euro Delivery on 9/21/12 | U.S. Redelivery on 12/6/12 | Motor Dead on 7/15/13 '13 Space Gray/Mugello Red X5///M Pavement Punisher | Snow Muncher | Family and Board Hauler | Roadtripper |
08-31-2010, 02:44 PM | #15 |
Rep 38
I don't see why they would revert back to the N54. They have put so much into the development of the N55 and have discussed using it in other future vehicles. Theoretically in our 135's N55 produces the same BHP and Torque as the N54. I think it would be easier to make the reliable power gains that should be necessary to put an M badge by using the N55. Just my thought.
08-31-2010, 02:48 PM | #16 |
Rep 254
I spoke while before the 1M was confirmed with some BMW insiders/experts and they said that the n54 engine was very likely designed by m gmbh because of its complexity and it was a come back to turbo engines for bmw after a while so they invested quite heavily into it to make sure its a good one (didn't want to fail at this attempt)
So I would assume M gmbh used this engine again as a basis for the 1M The N55 as I was told is not as good as the N54 and represents cost cutting for mass production engine from BMW. Just the thought
135i Performance
08-31-2010, 02:58 PM | #17 | |
Rep 615
1M Hybrid engine... logical hypothesis
Could it be between an N54, and turbos from BMW turbo diesel engines?
Technically if it's still twin turbo (since we saw exhaust pipes from the pictures), then it would only make sense to go either - variable vane or - different size so that top end power isn't shot due to the small snails unable to provide sufficient air..... which comes to this page: This is from bmw tech guide Quote:
VO 1M - everything except sunroof
RIP BSM 135i 2009-2011 |
08-31-2010, 03:13 PM | #18 | |
Rep 4,190
Maybe because this is going to be a short production run and the N55 will be reserved for the upcoming M3? |
08-31-2010, 03:34 PM | #20 | |
Rep 615
M also takes into account the requirement for longevity etc..
08-31-2010, 03:51 PM | #21 | |
Rep 10,200
Drives: 2024 Golf R / 2022 718 Spyder
He did confirm though that the N55 is still slated to be the basis for the F30 M3....
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
