09-06-2010, 02:44 PM | #1 |
Rep 60
WTB Premium HI-FI Right Side Subwoofer
Somehow, I managed to blow the subwoofer under my passenger seat If anyone has an extra that they are willing to part with, please let me know Thanks in advance! Dan Hays |
09-06-2010, 09:32 PM | #2 |
98
Rep 792
We offer the Earthquake SWS-8, Plug & Play subwoofer. It can be powered with an after market Amplifier, or with your OEM amplifier.
Increases the quality of the bass and fit's right where OEM is. Very inexpensive too! Good luck with your choice! |
09-07-2010, 07:43 AM | #3 |
Rep 3,969
For clarification, the SWS-8 is NOT plug-and-play.
1. You have to cut off the OEM speaker connector and solder the wires to the SWS's terminals (or use crimp-on terminal connectors). 2. The bottom of the subwoofer enclosure requires modification and there is a spacer required on the baffle in order for the SWS-8 to fit. Also, there is NO improvement in bass response when the SWS is installed with the factory amplifier. It may actually be a bit less since the SWS is likely much less efficient than the OEM woofers. |
09-07-2010, 03:29 PM | #4 | |
Rep 13,012
Get you facts straight or you are going to blow a lot of OEM amps... |
