KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
09-20-2010, 01:23 AM | #1 |
Rep 3,668
Need help with setup.. rubbing
Hello
Im running a 10.5 rear wheel with a 22 offset with 295/30/19 advan ad08 tires. front is 9 inches with 13 et and 245/35/19 Suspension: kw v3s on lowest setting front and rear Im having a rear rubbing issue where its not rubbing the top(eventhough very very close maybe 3mm) its the lower quarter panel (near driver not rear bumper) where its rubbing. Its literally maybe rubbing 2MM or so. What can i do to address this? Also the front is rubbing on the fender liner minorly. Im honestly very scared to drive car as i feel like the front on a big dip can come up and break the fender and the rear might mess up my quarter panel as its so close! If i raise the car a 1/4 or more of an inch will the rubbing stop? Im trying to figure out if this will happen no matter what height or if i need to replace my front/rear tires as the advan ad08 run very agressive! Im sure if i was a running a tire without such a square setup i would have no problem. NOTE: i had these tires on my car with rd sport springs and i had no rubbing problems at all, i took some agressive turns and it never rubbed. Will getting 295/30/19 michelin pilot sports fix this problem? thx Last edited by 1cleanm6; 09-20-2010 at 01:29 AM.. |
09-20-2010, 01:46 AM | #2 | |
Rep 2,339
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
09-20-2010, 02:00 AM | #3 | |
Rep 3,668
I dont want to play with camber more then i have too, im trying to do my best not to change the tires as its just too much hassle. I need to go see westend to help me out... |
09-20-2010, 06:34 AM | #5 |
Rep 751
Your rears are simply too wide for the suspension/wheel setup. With that amount of stagger, the understeer is going to be substantial too. As for ride height, the big advantage in having a coilover suspension is the ability to corner balance the car, and that will determine final ride height. But if it is at the lowest setting, it's probably too low by a good margin.
09-20-2010, 12:23 PM | #9 |
Rep 6,918
Curious why you messed with the setup...josh wasn't rubbing? Advan are known to "Run larger" than others...they're very square.
2022 Dravit/Fiona M3cx - Dinan midpipe w/VC, NW Carbonhaus CF, AST Springs, FC Spacers...more to come!
2016 Indi F80 M3 - SMB|Amaro | Mode Carbon | ESS | Akra EVO | KW HAS...SOLD 2012 MR e92 M3 DCT, ESS SC, Brembo BBK, BBS FI... GONE but not forgotten! 2008 AW e92 M3 6MT, ESS SC, BBS LM's...SOLD! |
09-20-2010, 12:42 PM | #10 | |
Rep 3,668
I wanted to make the car a better handler. I believe im very close. Very has VERY minimal body roll, suprising VERY little oversteer, and it just grips like a mofo! Im very happy with it, Yoko doesnt make 285s or else i wouldnt have any problems, the big problem here is i cheaped out on not getting ps2's . Couldnt justify spending 2g's on tires. If i had ran a 245/295 with its round sidewall i wouldnt have any issues. Its a little too much hassle to get my tires replaced now. I just have to live with them. Im confident Darin @ westend will fix this issue. |
09-20-2010, 01:38 PM | #11 |
Rep 5,482
If people are able to fit 275's on the front without rubbing there's no good reason you should have problems fitting a 245 unless you went with "bling" offsets for "stance" instead of focusing on how to fit the most tire under the fender. A 13mm front offset tells me there's tons of room toward the inside of the wheelwells. Take advantage of it.
09-20-2010, 02:09 PM | #12 | |
Wheel Whore
159
Rep 937
09-20-2010, 03:26 PM | #13 | |
Rep 5,482
09-20-2010, 03:30 PM | #14 | |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
BTW for reference I am running 255/30 and 325/25 Pirelli tires on my 20" wheels and Eibach springs without any rubbing issues. |
09-20-2010, 03:32 PM | #15 |
Rep 5,482
Out of curiosity, what is your rear wheel width and offset?
09-20-2010, 05:25 PM | #19 | |
Rep 1,245
If I were you I would just keep the tires and raise the car a bit. The handling probably isn't great with the kw's at their lowest setting either... if you do end up raising the car, make sure to snap some pictures before. It probably looks amazing as is.
2011 AW/FR Extended E92 M3... fully loaded
09-20-2010, 07:21 PM | #20 |
Rep 3,668
pictures of my drop
this was first day kws were on im sure they have settled a little more I hope this gives everyone a better idea Last edited by 1cleanm6; 09-20-2010 at 09:55 PM.. |
09-20-2010, 08:40 PM | #21 |
Rep 1,245
wow, your car looks gorgeous! let me know if you end up selling that lip
09-20-2010, 10:22 PM | #22 |
Rep 6,734
20" Flat Black Volk G2 F: 20 - 9 et20 R: 20 - 11 et29 Last edited by slicer; 09-21-2010 at 10:45 AM.. |
