10-30-2010, 10:04 PM | #1 |
Rep 193
Drives: 2009 Black 135i
Anybody Have The Active Autowerke Methanol Kit
Im Having Trouble With The Install? Can Anybody Help
10-31-2010, 05:56 PM | #3 |
Rep 193
Ive Almost Finished Everything But Im Confused On Some Wires I Need To Find
YELLOW wire from controller that splices with the (memory wire in the ecu)?b4 it is connected to other side of the On & Off switch, which should source power from ignition I Have No Idea Where On The Switch I Hook Up The Yellow Wire? And The Yellow Wires With The Black Netting That Go Through The Firewall Under The Steering Wheel That Need To Be Spliced With The Ignition Wire But Where Is The Ignition Wire? I couldnt find with a voltmeter Here is a bunch of pictures i hope they explain my situation Last edited by NewlyWedMan; 10-31-2010 at 07:33 PM.. |
