02-14-2011, 10:28 AM | #1 |
Rep 263
Oil Change Nightmare
So I had my Z4 dropped off at a mechanics which has worked on my Z3 many times to do a routine oil change. I recieved a phone call saying the mechanic didn't know how to do it because the car didnt have a dipstick. I offered to walk him through it. I was 90% sure the engine took 6.9l but decideded to google it real quick. As I did he started the car!! I asked what he was doing, he said, "I put 5 L in and we can see if that is good or not." I said stop and turn off the engine right away and that I knew the car didnt have enough oil.
Did this Dbag damage my engine?! |
02-14-2011, 10:32 AM | #2 |
Rep 2,703
Drives: 2009 335i - Sport PKG
I dont think this has done any damage to the engine. it would have damaged engine if he had taken it for test drive.
02-14-2011, 10:46 AM | #3 |
Rep 483
You should be good. The little six engine doesn't need all 7 quarts to lubricate for a few min.
Do your own oil changes! If he couldn't find the dipstick did he replace the gaskets on the oil filter housing and drain plug? Prob made a mess when he took the cartridge out. |
02-14-2011, 11:00 AM | #4 | |
Rep 263
02-14-2011, 11:08 AM | #5 |
Rep 12,570
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.08] |
one thing I've learned is alot of non-BMW indy shops can't work on modern cars, things have changed so much just from the last few years. or better yet, you need to go out of your way and give him the facts, diy guide, etc when working on your car.
02-14-2011, 11:14 AM | #6 |
Rep 4,365
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
Thought you just said you recieved a phone call? Why did he call you if you were there watching him and walking him through it?
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4 2017 Harley StreetGlide • Denim Black • V&H Tune 2021 BMW x30i • Phytonic Blue Metallic • Fully loaded |
02-14-2011, 11:21 AM | #7 |
Rep 374
02-14-2011, 11:24 AM | #8 | ||
Rep 12,570
so did you F up your oil change? if so just come out, we won't judge, haha. |
02-14-2011, 12:17 PM | #10 |
Rep 263
I dropped it off and got a call 5 mins later so I turned around to walk him through it.
I checked his work and topped it off. I checked the oil life and it says "ok" after this clock icon comes up. Anyone know what I mean? And why does it do that? I think he reset it wrong.... |
02-14-2011, 12:24 PM | #11 | |
Rep 1,772
Drives: 2007 Z4M Coupe
Gruppe M CAI / Euro Headers / Rogue Engineering X-pipe / RE Diablo Exhaust |
02-14-2011, 01:55 PM | #13 | |
Rep 12,570
What county are you from? I might be able to suggest few good shops in NJ... |
02-14-2011, 01:57 PM | #14 |
Rep 263
I live in Hunterdon County. I have heard of a AK Motorwerk in Hillsborough which I am thinking about going to to have my trans fluid changed. Any other places you can suggest?
02-14-2011, 02:09 PM | #16 |
Rep 4,060
Is the dealer crazy expensive for an oil change? For example, if you strip the drain plug, you're effed.
But if the dealer strips the drain plug, you're not!
Huz-Z
BMW Z4 3.0si Roadster. Montego Blue Metallic. Premium and Sport Package. Last edited by Huz-Z; 02-14-2011 at 02:09 PM.. Reason: spelling |
02-14-2011, 02:16 PM | #17 | |
Rep 12,570
http://www.e90post.com/forums/showthread.php?t=437328 http://www.redlinespeedworx.com/ or more closer up to me, but I have personal experience with them and can honestly say they're probably one of the premier shops (and at really competitive pricing) is Bimmer Clinic: 1001 Route 1 (south side) Avenel, NJ 07001 (732) 218-7632 If you decide to go with BC - ask for Bill and let him know Dan with the Z4 coupe referred you. Guarantee he'll take good care fo you. |
02-14-2011, 02:30 PM | #18 | |
Rep 1,772
02-14-2011, 02:43 PM | #19 |
Rep 263
02-14-2011, 02:50 PM | #20 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
The non-M takes MORE. Believe it.
5L is 5.4 quart. It takes only 6.4 liter for the fill (6.9 quart). IT IS SPECIFIED in the BMW TIS to fill to 5 liters, start the engine, then fill if necessary. It's standard operating procedure when changing oil if I'm not mistaken. Even if the TIS does not call for partial fill, start, then check oil level, at 5 liters it is the difference between the MIN fill and MAX fill (1 liter). It's not going to "hurt" anything, especially not the engine, to start up the engine at 5 liter fill. Frankly, if you guys aren't going to trust your mechanics to know what they're doing, then don't take it to a mechanic at all. Do the work yourself, save yourself (and the mechanic) the grief. Also the Si does not have a dipstick. The only way to properly check the oil level is to start up the engine, let it warm up, and use the onboard diagnostics or GT1 hooked up to the car to check the oil level. As far as I can see, the mechanic did it right. Fill 5 liters, check for level, and add as necessary.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
02-14-2011, 03:22 PM | #21 |
Rep 1,772
inspection II specific to M cars. Involves changing all the fluids, filters and mainly adjusting the valves. Very time consuming and relative expensive maintenance item for M engine
02-14-2011, 07:20 PM | #22 |
Roadie B4 Roady
Rep 118
Even with just 5 quarts the oil pump is going to get the oil where it needs to go. I think BMW put 6.9 in our cars so that they can increase their oil change interval to 15k and only have to do 3 of them within the 50k maintenance free service.
I'm not saying it's OK to just have 5 quarts of oil, just that I don't think it harmed your engine by your machanic starting it.
Remus, ZHP, Stubby, H&R Coilovers
