04-09-2011, 04:19 PM | #1 |
Rep 571
questions about DCT....
How much torque the DCT can handle?
is there any mods to make it handle more? how long it take to change gears in ms? (the lexus ISF takes 200 ms) is the DCT same in m3 and 135i....?? |
04-09-2011, 04:23 PM | #2 |
Rep 347
well in the M3 u have a M-dct in my mind its like .3or.4 faster than 135 dct but you would never know if you didnt drive the M3. Torque wise I hear it can handle upwards of 400wtq
"you blink I shift" DCT
04-09-2011, 07:14 PM | #6 |
Rep 611
From my understanding it is a different transmission. The reason why the transmission cannot handle past 360-400wtq is completely due to the clutch slipping from my understanding. There was a whole post about it that I cannot seem to find.
2011 AW 135i - DCT - M Package - BMW Performance Suspension Kit - Berk Street Midpipes - Evolution Racewerks FMIC - JB4 - BMS Intake - BMS Downpipes
04-10-2011, 10:36 AM | #7 |
Rep 1,041
in manual mode why does the dct change the gears automatically in red line ? it should not change until when i want to chenge the gear thats a proper double clutch trans !?
is it the same on the m3 ?
2016 YMB F80 M3
04-10-2011, 11:30 AM | #8 |
Rep 741
My understanding is that it doesn't change gears unless you hit the paddle. |
04-10-2011, 11:34 AM | #9 |
Rep 1,041
no i tried it changes in red line
2016 YMB F80 M3
04-10-2011, 12:36 PM | #10 |
Rep 146
Buy a manual instead and redline it till your moter blows up.
04-10-2011, 12:41 PM | #11 |
Rep 1,041
didnt ask ur opinion about buying a manual !
most of the dcts doesnt change automatically ! when u are going sideways and it changes to 2nd its a big problem !
2016 YMB F80 M3
04-10-2011, 01:04 PM | #12 | |
Rep 611
So I am not sure about your experience, but if you are going sideways and it shifts it is basically like backing off the throttle. The cars back end will just come straight or if you are not drifting you will just slow down. Not exactly the biggest problem, but it would most definitely jack up your lap times. However regular automatics work in the same way with regards to shifting.
04-10-2011, 01:17 PM | #13 |
Rep 741
Yes it will down shift automatically if your foot is off the gas and slowing down. I haven't tried it but I suspect if it automatically up shifts at the red line it is more like the engine hits the rev limiter and then it shifts.
04-10-2011, 03:17 PM | #14 | |
Rep 1,041
anyways someone told me that its not good to use manual mode all the time he says the transmission gets hot. is this true because 99% i use manual mode !
2016 YMB F80 M3
04-10-2011, 03:21 PM | #15 | |
Rep 847
If you're going sideways in first gear it's not really doing to do much. Now third gear to 4th could be an issue. |
04-10-2011, 10:15 PM | #16 | |
Rep 611
Also it is better to shift yourself according to what shiv said in his testing. He said if you let the car shift itself at redline you will see boost loss/throttle closure...but if you shift yourself you will see zero boost loss/throttle closure.
04-10-2011, 10:55 PM | #17 |
Rep 347
The m3 dct does the same thing if u ever push the paddle down all the way u can feel a click that click pretty much shifts you into next gear . Going side way lets see i havent had any issues i have 4,500 miles on my tires and i almost need new tires on the 135 so im going sideways alot you see. =)
04-11-2011, 03:58 PM | #19 |
Rep 347
your questions make no sence your are talking about apples and oranges yes apples fall under the fruit catagory and oranges are orange. Like self explantory stuff here read a lil live a lil. jeez =)
04-15-2011, 10:30 AM | #21 |
Rep 269
BMW only needed to make sure the DCT could handle the power levels they threw at it. They either didn't put a DCT on the 1m because of price or because they felt it couldn't reliably handle the extra power and overboost. I doubt M or bmw would tell you either way in an official manner. If you you did the ED like one of the 1addicts members, they could probably be a little more open about it in person since it wouldn't be official.
