04-25-2011, 05:36 PM | #3 |
Rep 246
I think its good to use time to time. It does help clean out the engine and you can see a small increase in power. I would mix 2 or 3 gallons of 100 octane with the rest being 93 or 91 if 93 is not available in your area.
04-26-2011, 01:36 PM | #4 |
Rep 246
i can tell you personally that running higher octane fuel, does burn better and will help clean out the combustion chamber, by burning complete, hence running better. sorry.
04-26-2011, 02:00 PM | #5 |
Rep 2,991
Obviously, he opened up his cylinder head and licked the combustion chambers and tasted less gasoline or something.
I've actually seen high octane unleaded gasoline (100 Octane) leave MORE deposits, because it typically doesn't have the same detergents/additives that regular street gas does. I'll leave leaded race gas and avgas out, because obviously it does the same. |
04-26-2011, 02:01 PM | #6 |
Rep 1,379
First off race fuel DOES burn better than regular fuel simply due to higher engineering tolerances. You can expect to see gains of 4% at the same octane, which isn't useful for real life because it still costs $7-$30 a gallon but is useful for racing. I've studied this from an engineering perspective.
Whoever says race fuel or 100 octane cleans out the engine is absolutaly wrong though, 100 octane will actually cause your engine to be much dirtier. I've killed cars by running higher octane fuel by accident in just a few thousand miles due to build up. 100 octane literally does the opposite of what you think. TrackRat summed up what you can expect with horsepower gains, but I also want to add that most modern engines tend to benefit at least a bit up to possibly 100 octane fuel with the proper tune with regard to modern street engines. I cannot stress enough that you need the proper tune though.
Clean cars are happy cars! CANON PHOTOGRAPHER |
04-26-2011, 04:17 PM | #8 |
Rep 16
Almost all cars made today could get more power with 100 octane.
Almost every car made today has to significantly retard ignition at high power setting to keep the fuel from detonating. If you look at the compression ratio of older cars compared to new cars, and then look at the fact that the available octane of fuel has actually gone down, you can see that modern cars are designed with a different philosophy regarding detonation and fuel economy. In the "day" car were designed to run high enough octane and low enough compression ratio (among other things) so that the engine would never detonate at any power setting. Today cars are designed to not detonate at normal power settings where the vast majority of driving is done. This allows the designers to build highly efficient engines for normal driving. But the result is that at high power setting virtually all engines retard the timing (and sometimes increase fuel air ratio) to keep the engine from detonating. The result is less than optimal timing, and therefor power, at high power settings. If you run 100 octane in an unmodified car you will see zero (or near zero) power increase, because the engine computer isn't designed to run on anything higher then the specified octane fuel. However if you tune for 100 octane, so that the timing and fuel mixture are optimized for 100 octane, you can see significant performance gains.
Anecdotally; I have an Audi A6 2.7t (I am still waiting for my M3 to arrive from the prep center in SoCal). I have been running a chip that allows me to switch from the stock engine map to a 1 bar map, but also allows me to specify 91, 93, or 100 octane fuel (with the same boost). I also have a VagCom device that allows me to monitor virtually every engine parameter in real time, and graph. When I switch from 91 octane to 100 octane the HP goes from about 310 to 360 (according to APR) but the boost remains the same. What does change (according to the VAGCom graphs) is the ignition timing. With 91 octane I often see TDC or even past TDC timing at high power, but with 100 octane the timing is maybe 20+ degrees before TDC. There is a quite noticeable improvement in power throughout the RPM range, and the engine simply "feels" better (even I don't know what I mean with "feels" better). I cannot imagine that the M3 engine, with 12:1 CR, doesn't need some serious ignition retard at high power settings to keep detonation in check. I would love to see a 100 octane chip for the M3 but it seems like nobody does such a thing on non-turbo cars. I know many racers who run 100 - 115 octane in their cars and do significant retuning as a result, I don't know why it wouldn't work in a M3. |
04-27-2011, 12:06 AM | #9 |
Rep 195
I've seen posts on this forum referencing Pencil Geek's tests with 100 octane race fuel yielding dyno gains of 30HP. Is this incorrect? I recently added VP race 100 to my tank and honestly noticed nothing in terms of butt dyno.
What is the real expected advantage of increasing octane on a basic stage 1 Dinan tuned E92 motor? 10HP? 0HP?
2009 Silverstone II E92 M3 Coupe - DCT
Dinan Exhaust, RPi scoops, Dinan Tune, Dinan Pulley, BMC filter, LCI Taillights, MS 15mm spacers, Huper Optik tint. |
04-27-2011, 06:09 AM | #11 | ||||
Rep 1,379
What I meant was that testing has shown that consumer grade fuel can vary in it's energy content several percent from the factory. Racing fuel is made more selectivly so you get the fuel with higher energy content than the consumer fuel on average, but still within the range that consumer fuel falls into. Does that make sense? Think of it like this, if a store selling car batteries sells consumer and racing batteries. The consumer batteries are sold with an initial voltage of between 12v and 13v. The racing batteries are the same model, but the manufacturer controls the quality better to make sure you only get the 12.5v-13v batteries. Quote:
04-27-2011, 11:54 AM | #12 |
Rep 3,984
First off most racing unleaded fuel that is street legal is oxygenated and does run detergents. Also, the point of diminishing return comes into effect here as once you go past 95 octane there isn't that much more to be gained.
However, I remember PencilGeek ran straight 100 octane in his car and dyno'd and ran a 361 rwhp on a dynopack while the car ran 333rwhp with just plain jane 91 octane. Here's the graph.. Hey PG..hope you don't mind if I used this.. I personally run a blend of 100 octane just to get me back to 93 octane and offset the piss water we get here in Cali. Dave
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
04-27-2011, 12:35 PM | #13 | |
Rep 3,984
Dave
04-27-2011, 04:05 PM | #14 |
Rep 195
I think we all appreciate the input but with due respect, a Dyno chart from a respected member of the forum classifies as data and supporting facts for me. While I do believe you are offering a valid point of view and you appear to be far more knowlegeable than many (inlcuding me) you only provided theory. So your point is that the dyno chart is wrong or misrepresented? Keep in mind that CA cars must run on crappy 91 so the bump in octane may have a different non linear result.
In God we trust - everyone else must show the data.
04-27-2011, 07:14 PM | #15 | |
Rep 3,984
Dave
04-28-2011, 08:24 AM | #16 | |
96
Rep 1,064
We dyno test M power cars every day and focus on the gains made rather than trying to tell people this is the HP at the crank. We dyno a car stock until we see consistent numbers, do what ever upgrades and then retest until we get consistent figures. Everything is kept equal and we have no problem is seeing consistent changes in graph shape time and time again. If the correction factors are displayed then you have transparency and this is the problem in the US... no one wants to give out the correction factor data before and after the test...... I wonder why. I totally agree that a dyno graph without correction factors displayed is for the bin. As for octane on the E92 M3. We have conducted this test many many times. A car on 95 Euro will produce around 15HP on average less compared to 99 Octane. We have seen 30 sometimes but this is strictly not purely down to the fuel but the correction factors being so different on the two test days. The dyno either over or under compensates as it assumes the engine will be making more or less power based on the conditions and the reality of it is that it doesn't react like that. SAE corrections work only within a small range. |
