XBimmers.com | BMW X6 Forum X5 Forum
TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > X6 Engine / Exhaust / Drivetrain Modification
      04-27-2011, 09:04 PM   #1
motex
2020 Mineral White 30d MSport
motex's Avatar
Costa Rica
525
Drives: 2020 Mineral White 30d MSport
Cheapest way to get a better sound on X6M
I know this thread belongs more to the exhaust forum, but since this is the most visited between all sub-forums, just wanted to share the experience with you
Yesterday I did a small mod to the 2 vacuum valves on each one of the inner exhausts of the X6M, now all 4 exhaust tips remains open at all times ( when stock the 2 inner valves don't open until the car reaches some speed about 3000 RPM's)
The result is a real low frequency "V8 sound" when you start the car and drive at very low RPM's, is more like a "subwoofer sound" nothing loud.
Here some links to YouTube videos I made before and after the modification, also a couple of pics for better understanding. I'm VERY satisfied with the new sound results. Now my car sounds like it has BIG-balls......sound from video does not make justice, was taken with my iPhone.
Before and after videos here:
Before:
After:
      04-27-2011, 09:16 PM   #2
tonymac1
tonymac1's Avatar
Drives: 2021 X5 40i, 2011 E90 M3
im also looking for a good exhaust for my x6m, don't know which one to choose though
      04-29-2011, 05:21 PM   #3
djer
Drives: 2019 X3 xDrive30i
You could do the zip-tie mod. Look underneath the exhaust and there should be a "valve" connected to a tube. Undo all the screws then zip tie the end of the valve toward any nearest "hook" or any openings. Go with a high-temp zip tie if you're concerned.
I did a zip-tie / golf-tee mod on the 35i and it sounds wonderful.
2019 X3 xDrive30i (anytime now)
2016 X3 xDrive35i
2013 X5 xDrive35d Sport Activity
2011 X5 xDrive35i Sport Activity
2007 X5 3.0si
      04-29-2011, 06:20 PM   #4
Mb23
Mb23's Avatar
14
Drives: It's a BM
Can you explain this better? Any video by chance?
      04-29-2011, 11:16 PM   #5
Kanuc
Drives: 2013 X6M Melbourne Red
Google
Type in golf tee mod in google and you will see. Looks pretty easy. People have raised question about warranty...
      05-02-2011, 12:39 PM   #6
Sharpie12
Drives: 2013 F10 M5 SG/SO
motex, it'd be the same for a 50i, right?
      05-02-2011, 12:44 PM   #7
motex
motex's Avatar
Costa Rica
525
I will say YES because my X6M is almost identical to a 335i, so I asume that your 5.0 must be the same.
You can do a sound test to check the difference, just get a set of pliers and turn the lower mechanism 1/4 in order to open the valve, inmediately you will notice the difference, if you get a person to help you, you will be able to open both and see how great it sounds in low RPM's
Good luck !
      05-02-2011, 01:39 PM   #8
Sharpie12
do you turn it counter clockwise?
      05-02-2011, 02:18 PM   #9
motex
motex's Avatar
Costa Rica
525
Don't recall but you will find the way in 1 second don't worry, there is no way to make any damage, the mechanism is made out of steel, with a plier, piece of cake
      05-02-2011, 07:27 PM   #10
djer
sweet!!
2016 X3 xDrive35i
2007 X5 3.0si
      05-03-2011, 12:52 AM   #11
vet927
vet927's Avatar
Drives: 10 Carbon Black Metallic X6M
even though you're getting a bit better sound by disfunction the vacuum value, you're losing low end torque for sure, the acceleration is obviously much slower from my past experience
and also the vacuum value is powered/activated by a tube connecting to the vacuum head, won't it be easier just unplug that and zip tie the tube?
      05-03-2011, 09:43 AM   #12
DK35
DK35's Avatar
Drives: The MONSTR
2010 X6 50i  [9.34]
sawzall makes everything better....quick and easy
      05-03-2011, 11:40 AM   #13
motex
motex's Avatar
Costa Rica
525
You were right, after more than a week of use, I felt that lower end torque was low, so today I reversed the job. One more thing that found is that if Eisseman is doing the X6M exhaust including the vacuum valve, it most be for some reason......at least I enjoyed the low subwoofer sound for a couple of days.......
      05-17-2011, 03:42 AM   #14
vet927
vet927's Avatar
what i've done is cut off the vaccum valve from the stock exhaust and weld it on the Eisenmann, having the lower end power back and the sound now~
      05-17-2011, 04:29 PM   #15
motex
motex's Avatar
Costa Rica
525
well, good job, looked like original from Eisenmann
      07-28-2011, 08:53 PM   #16
SKFORZA
Drives: sleek murderd out
that is crazyy
      03-31-2013, 06:54 PM   #17
raducu
raducu's Avatar
Drives: 2010 X6M
any updates on this mod? I doubt you lose torque because the flap opens when you press the M button, so it's designed to open for louder exhaust when the M button is pressed.
2010 X6M Space Gray
2007 335I Black
      04-03-2013, 05:38 PM   #18
MaX6
Drives: 2011 BMW X6 50i
The 50i sounds pretty sweet stock... deeper growl then the M. I swapped out the pipes on my big V-Twin for a much better sound and have also done the muffler/header swap on a couple of cars but I have to say the stock sound on the 50i is pretty cool.. The only reason I would swap is performance gain..
      04-18-2013, 01:11 PM   #19
Spaceballs
Spaceballs's Avatar
Drives: 2010 Space Grey X5M
Thank God someone else understands this! A turbo needs as little back pressure as possible to run at its optimum, which is why the "M" setting opens this valve up.
'10 Space Gray, Cinn Int.
      04-22-2013, 04:50 PM   #20
hj826
Drives: X6
nice!
      05-04-2013, 03:26 AM   #21
Boosteeddc
Drives: 2010 x6m
i have the eisenmann race 4x90 and I couldn't have mad a better choice. 0 interior drowning noise. Idling sounds like a real v8 but acceleration definitely sounds different and loud from the outside (neighbors hates my cold start)
      05-08-2013, 09:32 AM   #22
reihani
Drives: 2011 X5M
it sounds like a machine gun. So loud and nice. but i couldnt take it for long..had it taken off after a couple of weeks. there is definitely droning, and that "expensive quiet ride" quality was taken from the car. If I were to change it again id go for the sport so i can use the M button to open the flaps..uknow more choice. but damn she sounds good with the race.
xbimmers
