05-30-2011, 09:21 PM | #1 |
Disillusioned bourgeois capitalist pig!
22
Rep 488
Does an LSD affect the DSC?
So I'm out of warrenty and am considering an LSD (Hi Andrew!). My question is - is the programing of the DSC capable of dealing with the change in traction bought about by the LSD? Surely BMW program it to the existing parameters of the car and an LSD would change these,
Your thought/experiences appreciated.
You can lead a fool to knowledge but you cannot make him think!
05-30-2011, 09:37 PM | #2 |
Rep 58
I have an LSD in my car and it is 100% compatible with the DSC.
135i Sport | Black Saphire Metalic | Boston Black | 6speed | 10 Speaker Hifi | Sunroof
05-30-2011, 09:38 PM | #3 |
Rep 1,993
+1 on the above.
Vishnu PROcede V5 | VK Motorworks FMIC | AR Design OCC | Forge DV's | Bilstein PSS9 | M3 Lower Control Arms & Caster Rods | Quaife LSD | HiTech Exhaust | BMW Performance Illuminated Door Sills | BMW Performance Gear Selector & Boot | BMW Performance E-Brake Cover
05-30-2011, 11:58 PM | #4 |
Lord Captain Commander
110
Rep 3,093
Not sure there would be any detrimental effect since the LSD just limits the difference in rotation speed between your two rear wheels. It just means that the DSC system will not have to cut in as much due to the fact that you won't be doing 1 wheel burnouts anymore.
E82 135i M-sport: SGM/6MT/Black |
05-30-2011, 11:58 PM | #5 |
110
Rep 3,093
Also are you 6MT or 6AT? Us manual drivers have a welded diff which costs an absolute fortune to replace
05-31-2011, 12:08 AM | #6 |
Rep 286
I've had a Quaife LSD in my 130i, and a Drexler and Wavetrac in my 135i and they've all been compatible with DSC in my cars. All 6MT.
Modded 135i RHD Bumblebee |
05-31-2011, 12:10 AM | #7 |
110
Rep 3,093
YOU HAVE A CAMARO DAAAMNNN. Performaxx?
05-31-2011, 01:05 AM | #8 |
22
Rep 488
Mines a 6mt and as it was one of the first batch, it has the old computer and bolted rear diff. I believe any thing after 3/08 has the newer computer and welded diff.
05-31-2011, 02:02 AM | #9 |
110
Rep 3,093
Lucky bugger! Go for it mate, it won't cause issues.
05-31-2011, 02:56 AM | #10 |
Rep 2,695
Collecting the set? :-)
.-=[ Kenny ]=-. 1999 BMW M Coupe 10.775 @ 134.35 mph w/1.600 60' (Best 136.07 mph) 25th August 2004. +2010 X5 35D+
Check out the 1Addicts Drag Racing Standings and Drag Racing 101. |
05-31-2011, 11:43 PM | #13 |
Rep 286
Not quite. Sold the 130i and had to replace the drexler in the 135i.
The drexler requires frequent maintenance (eg: diff oil changes) and its difficult because there is no easy way to get the oil out. You have to open the "in" plug and get a pump to pump the oil oiut. I waited too long, and after 10000km, the diff oil was jet black. THEN, look what happened to my half shafts (on the 135i) at the drags... So, then I went with the wavetrac. No issues thus far.
06-01-2011, 12:26 AM | #14 | |
Rep 602
BMW Performance Exhaust, Michelin Pilot Supersports F-225/40, R-255/35, BMW Performance Suspension, BMW Performance black kidneys, Quaife LSD, M3 rear sub-f bushings, M3 front control arm, rear guide rod and rear upper link kits, BMW Performance cross-drilled/slotted rotors, AFE Cold Air Intake. |
