06-23-2011, 06:57 PM | #1 |
Rep 121
Will an aFe CAI throw any codes?
Hey everyone, I am very close to buying an aFe intake for my 128i (2008). My question is, will/does it throw any error codes and assuming it does temporarily, this won't void a warranty at all will it? (unless its proven that it actually damaged something I take it, which would probably be hard to prove).
Does the aFe give any drone like how the injen does? I've never heard the drone but would the active autowerke intake be that much better over the aFe? Thanks. Also, I saw it on autanything.com and with a coupon the aFe one would be $267.71 + shipping (thats using coupon code: loyalty, which is 15% off $150+) |
06-23-2011, 10:01 PM | #2 | |
Vrooom :)
315
Rep 2,602
nope, shouldn't throw any codes. However, be sure to be installing it properly. I'm not sure if this applies to the 1 series, but I know on the 3 series if the cone is not placed correctly, it will not function correctly. Goodluck : )! most of us use injen, but afe is also a good brand and well respected. You should have no problems. Now as for warranty, I am a bit iffy on this. It depends more on your dealership. Mine doesn't care at all for mods unless it causes the problem directly.
2014 C7 Corvette Stringray - Laguna Blue - NPP Exhaust - Competition Seats
06-24-2011, 09:35 AM | #3 |
Rep 6,993
Drives: 15 F80 M3, 22 G01 X3 30i
I have an AFE on my 335i and it's been there since 2 months after I bought the car. Never had any grief from the dealer about it, and there's no way it can "throw a code" unless it gets plugged up and causes the engine to run rough or stop. "Droning" is associated with exhaust resonance, not intake. I also had AFE intake on my '03 330iZHP with no issues from the dealer.
The AFE intake on a 128 is basically just a cone filter to replace the flat filter/airbox. It's either oiled cotton or a "dry" filter element; the oiled cotton filter can be washed and reused. It also will have a noticeable intake sound, but only at higher throttle openings, and while it's louder than the stock airbox, it's by no means intrusive.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
06-25-2011, 03:50 AM | #4 |
Rep 638
Just make sure you buy the correct kit. There is a kit that is for owners with the active steering option and a kit without. As far as warranty is concerned, there is a law in the U.S that unless the aftermarket part is the absolute cause of a malfunction, they can't void your warranty. Of coarse the dealership may give shit about it, but just make sure you know all the facts and you will be fine.
2015 428i Coupe
2009 328i E93 |
06-25-2011, 01:19 PM | #5 | |
Rep 6,993
That said, unless your dealer is a real dick, they will never bother you about an intake, unless your failure involves your engine ingesting some sort of foreign material - which they have to prove was caused by a faulty air filter.
06-25-2011, 04:30 PM | #6 | |
Rep 638
2015 428i Coupe
2009 328i E93 |
06-26-2011, 09:04 AM | #7 |
Rep 6,993
My problem was that I wasn't able to find a lawyer who would take the case here in Austin, and I was getting ready to move to Houston, so I dropped it. But I will never, ever deal with VW/Audi again, and I tell everyone I know not to buy one of their products because of their complete absence of customer service and any sense of integrity.
