06-26-2011, 10:43 AM | #1 |
Rep 40
Raising rev lim to 8600
I've herd on the older m3s that if you don't have engine work you will blow your motor raising the rev to 8600. But what about the e9x m3 I really don't think raising it 300rpm would be that big of a deal. Just curious if anyone has had any issues
06-26-2011, 10:49 AM | #2 |
Rep 3,574
how would you raise it?
tuners that know what they're doing take persuasions in raising rpms.
2015 Porsche 991.1 GT3 2015 F80 M3 -- Individual; Space Grey |
06-26-2011, 01:11 PM | #3 |
Rep 1,348
if that were the case, why would dinan do it?
06-26-2011, 01:20 PM | #4 |
Digger
209
Rep 2,619
Dinan only does that on the 6MT for reasons someone else can hopefully chime in on....
2009 E92 M3 /// Melbourne Red /// Fox Red /// M DKG
Full Innotech Exhaust - DINAN Intake - IND Engine Bay Appearance - IND Hand Stitched Boot Covers - and much more.... |
06-26-2011, 01:40 PM | #5 |
rev limiter abuser
Rep 274
Dinan tune raised my DCT to 8600. It is for a little more time in the power band of the car. I could say it doesn't make that much of a difference in the first couple gears but 3rd and up it helps slightly.
Showing or promising no abatement of severity, intensity, strength, or pace.
06-26-2011, 01:49 PM | #6 |
Grown Azz Man
430
Rep 3,021
Not true.....I too have DCT and mine is 8600 as well................Phil
2016 GT4.....Sapphire Blue Metallic, Platinum stitch Leather/Alcantara interior, Carbon Fiber Trim, PCM w/Nav, Guards Red Belts, 2 Zone Climate, Sport Chrono, LWB, Smokers Pack, Big Gas Tank, Light Design Pack, Bi-Xenon w/PDL, Auto Dim Mirror, Clear Side Markers, GTS Clear Taillights
06-26-2011, 01:50 PM | #7 |
Digger
209
Rep 2,619
You are correct. I just re read the description on the site and I read it too fast. It is only raised when in S not D
06-27-2011, 09:32 AM | #9 |
Rep 6,007
+1
Did mine as well. Pulls much harder as it crosses 9k
06-27-2011, 09:35 AM | #10 |
Rep 5,482
I went for an even 10,000. It's best to shift at about 9,500 but it's always nice to have the extra room on the tach in case you want to hold a gear until the next stoplight without shifting.
06-27-2011, 11:18 AM | #13 |
Rep 2,736
Drives: 2008 E92 ///M3 Alpine White
I raised mine to 40,000. It helps prevent carbon deposits from forming.
06-27-2011, 11:27 AM | #14 |
Rep 1,278
I swapped out the S65 for a battery. I have no revs.
PAST 2007 Black Sapphire E90 335i, 2010 Jerez Black E92 M3, 2012 Mineral White E92 M3, 2013 Singapore Grey F10 M5, 2016 Azurite Black F80 M3,
CURRENT 2017 Oxford White GT350 |
06-27-2011, 11:42 AM | #15 |
Rep 2,736
So much torque.
06-27-2011, 11:48 AM | #16 |
I like cars
331
Rep 5,052
Mine is over 9000.
My photostream: http://www.flickr.com/photos/racelap/
06-27-2011, 10:12 PM | #17 |
Member BMW CCA Los Angeles
32
Rep 470
Drives: 2022 M8 GC Comp
I got two engines. One redlines at 2000 for the valet.
Current Rides:
2022 ///M8 GC Comp Much enjoyed: 2018 ///M4 ZCP || 2014 ///M5 ZCP || 2011.5 ///M3 Sedan || 2007 ///M Coupe || 2008 550i Sport || 2006 ///M3 ZCP || 2008 X3 3.0si || 2006 325i || 2003 Z4 3.0 Roadster || 2003 330ci || 2002 325i |
06-27-2011, 11:54 PM | #18 |
Rep 5,012
I'm going to raise mine to 18K so it sounds like an F1 . Seriously, raising the limiter is the stupidest thing you can do to a stock engine. Plus your engine warranty is no more (yes, max revs are permanently recorded on the DME). Just crazy, but to each his own.
06-28-2011, 04:44 AM | #19 | |
Rep 2,190
This engine costs how much again? Crate motor is 20k+? |
06-28-2011, 05:38 AM | #20 |
Rep 148
300rpm on an engine like this is nothing... and if it is BMW has some serious issues for releasing a car with a rev-limit so close to the limit that if you go another 300rpm the engine will fail... not going to happen... The M3 GT4 also has the rev-limit raised and from what I understand the engine internals are stock.
Hell even my Integra Type R a measly Honda mind you had the rev-limit 1000rpm higer then standard and after thousand of miles even on track never had an issue, so I donīt think it is an issue on the E92 M3. Just wish people would stay on topic instead of making funny remarks on a serious issue. |
