04-06-2007, 05:07 PM | #1 |
Rep 10,407
M3 vs M5 0-60 - GEARING!
Guys if you missed it we have all of the gear ratio information for the new beast including the final drive. This makes for some fun spreadsheeting! As you probably know the E46 M3 did not have all that great of a power to weight ratio. It did still manage a pretty impressive 0-62 (5.2 s quoted by BMW but many found more like 4.8 s). It accomplished this through a few things but mostly by low gearing (torque multiplication). The new M3 has a significantly larger final drive than than M5 3.846 vs. 3.62. Taking into account each gear ratio, the final drive, the wheel size, an estimate of drivetrain loss and weight the M3 has a significant advantage in acceleration at almost all rpms in 1st gear (the M5 gets a very slight advantage from 6k- 7k rpm from its pronounced torque peak there).
The % advantage looks something like this:
(Note: Things missing in my fairly simple analysis: rolling resistance and air resistance. These should be fairly close though for both vehicles) OK what's next? If that was it the M3 would be the clear winner. The traction from the M5s 285 tires and the .3 - .4 second advantage from SMG vs 6MT on the 1st to 2nd gear shift will also make quite some difference. It is nearly impossible to estimate how much the stronger acceleration in the M3 will be offset by these advantages. Put some 295 or 305 width tires on the M3 and get it with the dual clutch system and I'd place my bets on the M3 besting the M5 0-60 mph. As it is released, 6MT and stock tires it is going to be really interesting. |
04-06-2007, 05:24 PM | #2 |
Rep 3,044
Drives: 2011 Dakar Yellow M3, 2018 M5
well done swamp. here's hoping you're right =)
[ESS VT2-625] [Akrapovic Evolution Exhaust] [KW Clubsports] [OSS Angel Eyes] [Revinora r-CRT Lip] [Vorsteiner Boot] [Challenge Race Diffuser] [See the Build Thread HERE] |
04-06-2007, 05:43 PM | #3 |
Commander-In-Chief
2196
Rep 8,944
Drives: 2023 M2 Coupe, 2020 GLE 450
Gearing
swamp2,
Did you take tire diameter into account? The E92 has larger tires than the E46, and I think the E60 M5 has larger tires still.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 Last edited by GregW / Oregon; 04-06-2007 at 06:42 PM.. |
04-06-2007, 06:17 PM | #4 |
Rep 10,407
All tire diameters are in my spreadsheet. Although the effect of tire size can be seen it is the individual gear ratios, final drive, torque curve and weight that are the dominant effects.
04-06-2007, 06:29 PM | #5 | |
The World is Not Enough
167
Rep 1,088
04-06-2007, 07:00 PM | #6 | |
Rep 3,592
'08 E92 M3 6MT | IB | FR | RAC RG63's | VRS Ti Exhaust | Fabspeed HFC & Xpipe '09 X5 35d SG/SB '11 X3 28i AW/CN/FW (wife's car |
04-06-2007, 10:55 PM | #7 |
Reincarnated
245
Rep 4,227
Was going to make a thread about the gearing. What is everyone's take on the numbers and what do you think it correlates to?
04-07-2007, 03:16 PM | #8 |
Rep 10,407
Is this admiration of science or dising me for being too technical?
04-08-2007, 04:05 AM | #9 |
Rep 112
Also note that the new M3 uses the exact same gearbox as the 335i, but of course with a much more aggressive final drive ratio (3.846 vs 3.08).
Of course, this is referring to manual 6-spd in both cars. If you want to verify this, look at the recently-released press kit PDF (all the way down) and then look up the 335i manual ratios on bmwusa.com, for example (under technical data). |
04-08-2007, 10:32 AM | #10 | |
Rep 10,407
Noticed that
04-08-2007, 12:39 PM | #11 |
Reincarnated
245
Rep 4,227
So, does the gearing lend itself to low-end acceleration?
04-08-2007, 02:04 PM | #12 |
Rep 319
09-04-2007, 06:23 PM | #14 |
Rep 5
09-26-2007, 07:54 PM | #16 |
Rep 4,484
Why do people really care about 0-60 mph times? They meant something way back in the day when that was a big test of performance for cars.
Now, 1/4 mile is what you need to look at for acceleration from a dig. And I wish their would be more tests of acceleration times of 30-100 mph starting in 2nd gear for all cars and for faster cars a 50-130 mph starting in the best gear for each car. BTW, to the OP a 0-62.1 mph (0-100 kph) time in 5.2 seconds would be about right for a car that did 0-60 in 4.9 seconds. Now back to the topic at hand, I think the M5 will beat the e92 M3 in acceleration, especially as speeds climb into triple digits. The M5 is a beast above 100 mph. But the M3 won't be too far behind |
09-26-2007, 09:17 PM | #17 |
Rep 10,407
Follow up
I agree 0-60 is more like bragging rights and is seriously launch/traction limited. I did however, just run some E92 6MT vs. E60 M5 SMG simulations with CarTest (have you seen my other posts on this topic - the software has been shown to be quite accurate and predictive). It shows the M3 getting the jump in time to distance (not necessarily time to speed) vs. the M5 up to about 80 mph (rougly 8 or so seconds). Then as we might say "intuitively" the M5 really pulls ahead. Of couse the M-DCT will likely stay physically ahead in a drag for quite a bit longer, perhaps up to even the 150 mph territory, if it can get a good launch with that system.
09-26-2007, 10:31 PM | #18 |
Rep 4,484
yeah, I have had CarTest for years.
But unless you adjusted the shift speeds of the SMG, that will be off. Also, I noticed, CarTest doesn't do well with Forced Induced engines ( I know that isn't relative with the M cars). And lastly, many engines are underrated (like the 335i) so it's hard to use CarTest accurately in those cases. But granted it is pretty accurate a lot of the time, at least the ET's in the 1/4 but for some reason the 1/4 mile traps (and speeds into the triple digits) are often listed on CarTest as being a decent amount slower than what the car's really do. Sill, I don't see the e92 doing 0-60 times better than 4.4 seconds (like the M5) The M5's are also doing the 1/4 in the low 12's @ 115+ mph I think with the E92 M3 you'll see the following best times: 12.6-12.7 @ 111-112ish for the manual 12.5-12.6 @ 112-113ish for the DSG version |
09-27-2007, 01:37 AM | #19 | |
Rep 10,407
CarTest, etc.
I also noticed the same problems with FI engines. The 335i is particularly difficult to get right as it is not only FI but under-rated as well. AFA besting the 4.4 0-60 time I suspect we will see it. It won't be the average time reported by mags but C&D already got 4.4 and they claimed the road surfaced sucked and was quite slick. With M-DCT we will definitely see that number as you'll save about .25 seconds on the 1-2 shift before 50 mph. I think your predictions of the 1/4 mi times are pretty close although the best yet for the MT seems to be only 12.9 thus far (but again same slick surface here from C&D). |
09-30-2007, 09:58 PM | #20 | |
Rep 4,484
Just to be clear, the 335i I think you're speaking of (Sherwin's car) had a lot more than just the PROcede v2.0 and an exhaust. It also had Downpipes, larger intercooler and I can't remember what else is on Sherwin's car. And it only kept up until about 120 mph from a 50 ish mph roll), after that the lightly modded E60 M5's pulled away. I think a PROceded v2.0 335i with just exhaust would keep up with a stock e60 M5 until about 120 mph too, but the little screaming V10 would pull after that. I also think a 335i with PROcede v2.0 alone will run side by side with the e92 M3 |
10-01-2007, 01:07 PM | #21 |
Rep 10,407
Drags
Brisk, Driver72P: As I have stated (too many times to recount). If all you want is a drag car you will be able to spend less than the price differnce between the M3 and 335i and best the M3. However, the if all you really want it the best drag time you should spend a lot less on a used Mustang and supercharge and nitrous it!
The M3 is about A LOT more than draging. |
