08-09-2011, 02:17 PM | #1 |
432
Rep 4,650
♦ Sonic MS | Verstraβe Motorsport Technik Wheel Spacers for BMW
Sonic Motorsports 1045 West El Camino Real Mountain View, CA 94040 tel: 650-733-6506 fax: 650-691-9009 email: info@sonicms.net We at Sonic MS are proud to present a revolutionary new type of wheel spacer that is now available to the BMW community. Precision milled in the United States out of T6061-T6 aircraft grade aluminum, Verstraβe (pronounced Verstrasse) weight optimized wheel spacers utilize an industry first pentagon shaped design in order to minimize weight without sacrificing the structural integrity of the spacer itself. Furthermore, Verstraβe's Motorsport Technik Wheel Spacers for BMWs utilize machined pocketing in order to further minimize unpsrung weight for maximum performance. These spacers also use chamfered edges to allow for easier removal and are anodized in a matte silver finish for additional strength and corrosion resistance. Verstraβe spacers are machined with surgical grade precision utilizing tolerances within 1/1000th of an inch, this guarantees a perfect fitting spacer that is hubcentric and virtually eliminates any risk of vibration issues. In addition, Finite Element Anaylsis (FEA) simulations are run to ensure the weight optimized design of the spacers does not sacrifice structural integrity. Wheel spacers are used to give a car a wider stance, which increases lateral stability in addition to giving the car a more aggressive stance. Stock suspension and wheel setups are fairly conservative in regards to the amount of gap between the wheel and the fender, and wheel spacers help correct this by pushing the wheel towards the fender well, filling the gap. Each Verstraβe Motorsport Technik Wheel Spacer set includes matching extended lug bolts which are dacromet coated in an OEM black finish for corrosion resistance. Features:
Verstraβe Motorsport Technik Wheel Spacer Package Includes: QTY 2 - Weight Optimized Wheel Spacers QTY 10 - Extended dacromet coated wheel bolts MSRP Pricing: 5mm - $114.99 10mm/12mm/15mm - $174.99 As an introductory special, we are offering the first batch at a special price. Only while supplies last! To order, simply visit our web store in the below link. https://www.sonicms.net/index.php?ro...product_id=443 Store Hours: Mon-Fri : 10AM-7PM PST Sat: 12PM-5PM PST Payments: We accept all major Credit Cards, in addition to PayPal and Certified Cashiers Checks / Money Orders. |
10-21-2011, 03:46 PM | #2 |
432
Rep 4,650
Gentlemen,
The moment of truth has arrived. First test was done on a typical shipping scale, measured in lbs. Traditional Rounded Wheel Spacer - 15mm 5x120 72.56mm CB End Result - 1.0 lb Verstraβe Motorsport Wheel Spacer - 15mm 5x120 72.56mm CB End Result - 0.6 lb Traditional Rounded Wheel Spacer - 10mm 5x120 72.56mm CB End Result - 0.6 lb Verstraβe Motorsport Wheel Spacer - 10mm 5x120 72.56mm CB End Result - 0.4 lb Traditional Rounded Wheel Spacer - 5mm 5x120 72.56mm CB End Result - 0.2 lb Verstraβe Motorsport Wheel Spacer - 5mm 5x120 72.56mm CB End Result - N/A (scale not sensitive enough to record such light weight) Note that this kind of weight scale is not the most ideal for measuring items that weigh less than 1 pound. As such, for the next test - we performed on this more sensitive scale, measured in ounces. Traditional Rounded Wheel Spacer - 5mm 5x120 72.56mm CB End Result - 4.5oz / 0.28 lb Verstraβe Motorsport Wheel Spacer - 5mm 5x120 72.56mm CB End Result - 2.8oz / 0.175 lb Traditional Rounded Wheel Spacer - 10mm 5x120 72.56mm CB End Result - N/A (spacer weight end result out of available range on this particular scale) Fortunately, the Verstraβe spacers in 10mm / 12mm / 15mm were light enough to be measured on this scale, so without further ado - here are the rest of the results! Verstraβe Motorsport Wheel Spacer - 10mm 5x120 72.56mm CB End Result - 6.075 oz / 0.379 lb Verstraβe Motorsport Wheel Spacer - 12mm 5x120 72.56mm CB End Result - 7.495 oz / 0.468 lb Verstraβe Motorsport Wheel Spacer - 15mm 5x120 72.56mm CB End Result - 8.925 oz / 0.557 lb And here are a few more pictures detailing direct comparison of the traditional rounded wheel spacer versus the Verstraβe Motorsport Weight Optimized Wheel Spacer. |
