08-16-2011, 03:12 PM | #1 |
269
Rep 6,093
Drives: E90 M3
Location: 1460 White Oaks Rd. Suite F Campbell, CA 95008
Jlevi SW | Active Autowerke N54 Blow Off Valve Kit
The Active Autowerke Blow Off Valve provides greater capacity for high boost 135, 335, and 535i's with the N54 twin turbo motor. Active Autowerke's single blow off valve sports a huge venturi, designed to handle excess pressure build-up against the turbo compressor impeller blades. That pressure can cause the impeller to stop spinning (a.k.a. Compressor Surge),which can damage the compressor wheel and shaft. With the Active Autowerke Blow Off Valve in place, the stock turbos are protected as the boost is raised – you can take HP to the stratosphere, enjoy the spoils of all that performance, and get that cool “whoosh” sound as your machine spits out excess inlet pressure. All hardware & fittings on the Active Autowerke BMW Blow Off Valve have that quality factory look you demand, and are built to perform flawlessly under the most aggressive boost conditions. These kits are back in stock and shipping direct from Active! Active Autowerke BMW Blow Off Valve Key Features:
For Pricing and Ordering Information: P: 1.888.JLEVISW (553.8479) E: sales@jlevisw.com Retail Location: Jlevi Streetwerks, Inc. 2942-2944 Scott Blvd Santa Clara, CA 95054 Operating Hours: M-F 9am-5pm PST Payment Options: Follow Us: |
08-17-2011, 10:04 AM | #2 |
Rep 718
Drives: N/A
Will this fit the 1M?
2021 F87 HS M2C
2018 F80 SO M3 (SOLD) 2016 F80 AY M3 (SOLD) 2014 F10 M5 LCI (SOLD) 2011 VO 1M (SOLD) |
08-22-2011, 07:24 PM | #3 |
269
Rep 6,093
Drives: E90 M3
08-22-2011, 08:18 PM | #4 |
Rep 174
Best price shipped to 34667 please
BMS JB4 PnP / RPI scoops / BSH OCC / BMS DCI / H&R Super Sport Springs / Nitto INVO 225f 255r / CP-e axle back / BMWPerf. CF rear spoiler, iCarbon CF sideview mirror covers / CF grills / BMWPerf. Front rotors / EBC slotted rear rotors / SS Braided lines / StopTech performace pads / E93 M3 Front Sway / BERK resonated mids / BMS 12mm spacers
08-23-2011, 12:28 AM | #6 | |
Rep 1,783
Best Regards, |
