10-13-2011, 12:52 AM | #4 |
///M-fanatic
193
Rep 3,885
I have fronts that are pretty close to the sensor. However....I'm not sure how much you're willing to buy them for? And shipping will cost a slight bit too. Gotta tempt me with an offer lol otherwise it wouldn't be worthwhile for me to take the pads out
edit: yeah on second thought...too much hassle. If you were local, I'd help you out though! Sorry, and good luck! |
10-13-2011, 09:35 AM | #5 |
Rep 1,855
I think he's looking to get new pads from a warranty claim?
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust |
10-13-2011, 02:34 PM | #7 |
///M-fanatic
193
Rep 3,885
Yeah, I'm well aware of what his intentions are. They're the exact same intentions I had several months ago prior to my warranty expiration. I, however was not so lucky in finding worn-down brake pads. And the stealershit also failed on me in the end by not giving me ANYTHING
10-13-2011, 02:54 PM | #8 |
Rep 159
Yes, you are correct. My rotors are well below minimum thickness, but the dealerships will not do anything until pads are toast as well. Not looking to get into a discussion on the ethics behind this, just trying to find some worn pads.
Elerner61: any idea how much is left on the pads? |
10-13-2011, 03:32 PM | #11 | |
Rep 1,855
10-13-2011, 03:44 PM | #12 |
Rep 987
Is it written anywhere that the pads have to be low for them to service other parts of the brakes? Maybe you should go to another dealer. Perhaps you could exaggerate a bit and say that there is a lot of vibration under hard deceleration.
10-13-2011, 06:59 PM | #13 |
Rep 159
Both dealers I've tried have responded the same way. I believe it might be written somewhere if I remember correctly. It is also extremely difficult to find a dealer I would even trust to work on my car in the Houston area.
10-13-2011, 07:23 PM | #14 | |
Dog Listener
707
Rep 7,850
This policy left me with no choice but to buy new front rotors since I was well below spec on that front, planning on tracking my car (which I did do after I had the rotors replaced, not before), and had 80% of the pads left. There's no way at 30K miles the pads hadn't been replaced at Inspection around 24K miles--that effectively forced me to shell out of pocket for the rotors. Now, when it comes to actual warranty coverage I have nothing but good things to say. I've never had an issue on the warranty front, and I've had several things (headlight, diff leak, shift knob, a couple other minor things) replaced or fixed under warranty. But the maintenance program leaves a lot to be desired on the brake front given changes and how it's set up. However, if I have to pick (maintenance or warranty) I'll take BMW's warranty approach over Porsche's any day of the week. Last edited by Finnegan; 10-14-2011 at 12:42 AM.. |
10-13-2011, 10:43 PM | #15 |
///M-fanatic
193
Rep 3,885
Yes, it is documented under a more "recent" amendment to the BMW "free maintenance" plan
In it, they clearly state that a stealershit may not be reimbursed by BMW NA if they decide to honor a customer's brake pads prior to the required 3mm minimum thickness before replacement. This is why a lot of stealershits are afraid of not getting paid, and so they turn you away even if your rotors are ready to be swapped out... Lame, I know Sigh, I'll eventually get new front rotors out of pocket. For now though, since I'm not planning any track days in the near future, I'll just wear my current fronts down until I get that "brembo squeal" And when people ask, "hey, why are your brakes squeaking?" I'll answer with: "because RACECAR !" |
10-13-2011, 11:44 PM | #16 |
Rep 159
Maybe I can offer to pay for the pads and see what they say. I'm planning a track day in about a month and do not want to run with the rotors at or below minimum thickness.
10-14-2011, 12:45 AM | #17 |
Dog Listener
707
Rep 7,850
Worth a try, and I totally understand why you wouldn't want to run below the minimum thickness (I didn't either).
